Basic Fixed Matrices: Proving Equations with Formal Calculations
  • Thread starter Thread starter converting1
    Matrices
25 replies · 6K views
converting1
for fixed ## m \geq 2 ## let ## \epsilon (i,j) ## denote the mxm matrix ## \epsilon (i,j)_{rs} = \delta _{ir} \delta _{js} ##
when m = 2000 show by formal calculations that
i) ## \epsilon (500,199) \epsilon (1999,10) = \epsilon (500,10) ##
ii) ## \epsilon (1999,10) \epsilon (500,1999) = 0##
hence generalise for ##\epsilon (i,j) \epsilon (k,l)## and find a single equation using the kroneeker delta symbol for the generalisation
my attempt thus far:
i) rewriting this as ##\delta _{500r} \delta _{1999s} \delta _{1999r} \delta _{10s} ## then we note that ## \delta _{1999s} \delta _{1999r} = \epsilon (1999,1999) ## which gives a 0 everywhere except the 1999th ith position and 1999th jth position but I'm not sure how I can conclude that this gives ##\epsilon (500,10)##
that's all Ihave so far unfortunately
hi converting1! :smile:
converting1 said:
i) rewriting this as ##\delta _{500r} \delta _{1999s} \delta _{1999r} \delta _{10s} ## …
nooo …
##(\epsilon (i,j) \epsilon (k,l))_{r,s} = (\epsilon (i,j))_{r,t} (\epsilon (k,l))_{t,s}## :wink:
tiny-tim said:
hi converting1! :smile:nooo …
oh damn I am so stupid, so here is what I got so far let me know if my logic is flawed:
i) ## (\epsilon (500,1999))_{r,t} (\epsilon (1999,10))_{t,s} = \delta _{500r} \delta _{1999t} \delta _{1999t} \delta _{10s} ##
we know that ##\delta _{1999t} \delta _{1999t} = 1 ## if t = 1999, else it will be 0, so we get the required result
for ii) ## (\epsilon (1999,10))_{r,t} (\epsilon (500,1999))_{t,s} = \delta _{1999r} \delta _{10t} \delta _{500t} \delta _{1999s} ## we now see that ## \delta _{10t} \delta _{500t} = 0 ## as if t = 10, then ## \delta _{500t} = 0 ## and if t = 500 then ## \delta _{10t} = 0 ## hence we will get 0 always, the desired result
now generalising,
consider ## (\epsilon (i,j) \epsilon (k,l))_{rs} = (\epsilon (i,j))_{r,t} (\epsilon (k,l))_{t,s} = \delta _{ir} \delta _{jt} \delta _{kt} \delta _{ls} ##
## \delta _{jt} \delta _{kt} = 1 ## if j = k, else it's 0, hence we get ## \delta _{ir} \delta _{ls}## if j = k, i.e. we get ## \epsilon (i,l) ## if j = k, else we get 0.
now for the final part I am not sure how to express it as a single equation, could you give me a little hint?
ah, you're still not thinking in terms of the summation convention:
##\delta _{1999t} \delta _{1999t} = 1 ## :wink:
similary ##\delta _{10t} \delta _{500t} = 0 ##​
once you've convinced yourself of this, you should be able to do the general case :smile:
tiny-tim said:
hi converting1! :smile:ah, you're still not thinking in terms of the summation convention:
hmm, I'm not so sure I understand, what if t = 20? i.e. ##\delta _{1999,20} \delta _{1999,20} = 0.0 = 0 ? ##
also take a 2x2 matrix as an example, ## \epsilon (1,2) _{22} = \delta _{12} \delta_{22} = 0 \times 1 = 0 ##
ah, that's right, you don't understand …
you can't substitute one value for t into δ1999,tδ1999,t
the einstein summation convention means that that's a ∑ …
(over all values of t) δ1999,tδ1999,t :wink:
really? our lecturer defined ## \epsilon (i,j) _{r,s} = 1 ## if r = i and j = s , else it is 0, so I am just using that definition
so how do you know ## \delta_{1999,t} \delta_{1999,t} = 1 ##?
tiny-tim said:
has your lecturer not taught you the summation convention (the einstein summation convention)?
No, not yet, however in my applied mathematics lecturer we just started it today - so I know very little about it (almost nothing).
oooh :redface:
ok: this sort of question is very difficult to do without either the summation convention or a ∑
whenever you see a δr,s, you know it's going to be multiplying something else with either an r or an s (or both)
and since all these things are parts of matrices, you know it's actually going to be a matrix multiplication:
A = BC means Ar,s = ∑(all values of t) Br,tCt,s
you can either write it with a ∑ (like that),
or you can use the summation convention and just write Ar,s = Br,tCt,s (with a "∑" being understood but not written)
that enables you to say "δr,s replaces any s in the thing next to it by r", eg δr,sAs,u = Ar,u
alternatively, use a ∑ : ∑ δr,sAs,u = Ar,u
in particular, δr,sδs,u = δr,u
(or ∑s δr,sδs,u = δr,u)
ok, try all that in the original question :smile:
tiny-tim said:
oooh :redface:
ok using all for part c):
## (\epsilon (i,j) \epsilon (k,l) )_{r,s} = \displaystyle \sum_{t=1} ^{n} \epsilon (i,j) _{r,t} \epsilon (k,l) _{t,s} = \displaystyle \sum_{t=1}^{n} \delta _{ir} \delta _{jt} \delta _{kt} \delta _{ls} = \displaystyle \sum_{t=1}^n \delta _{ir} \delta _{jt} \delta _{jt} \delta _{ls}## if j = k, which then is ## = \delta _{ir} \delta _{jj} \delta _{jj} \delta _{ls} + \displaystyle \sum_{t \not= j } \delta_ {ir} \delta _{jt} \delta _{kt} \delta _{ls} = \delta _{ir} \delta _{ls} + 0 = \epsilon (i,l) ## if ## j \not= k ## then we get ## \displaystyle \sum_{t=1}^n \delta _{ir} \delta _{jt} \delta _{kt} \delta _{ls} = 0 ## as t cannot equal k and j simultaneously
is that ok?
tiny-tim said:
what is part c) ? :confused:
sorry I didn't label in the original post part c is this:
" hence generalise for ##\epsilon (i,j) \epsilon (k,l)##"
no, that last item should be ## = \displaystyle \delta _{ir} \delta _{jk} \delta _{ls}##
and then rewrite that as ##= \delta _{jk} (\delta _{ir} \delta _{ls})##
so now you have ##(\epsilon (i,j) \epsilon (k,l) )_{r,s}= \delta _{jk} (\delta _{ir} \delta _{ls})##
sooo … ? :smile:
(btw, you don't need to write "\displaystyle" on this forum :wink:)
sooo … ? :smile:
## = 1\times \epsilon (i,l) ## ?
is everything else correct that I've written?
tiny-tim said:
nearly :smile:
(what happened to the δjk ? :wink:)
is it not 1 if j = k??
tiny-tim said:
yes, but you want a general formula for ## \epsilon (i,j) \epsilon (k,l) ## :wink:
I'm really not sure what to put
tiny-tim said:
say it (partly) in words, starting "ε(i,j)ε(k.l) is … ", and then we'll put it completely into symbols :smile:
it's epsilon(i,l) if j = k else it's 0,
thanks for your patience
tiny-tim said:
ok, so it's epsilon(i,l) times … ? :smile:
## \delta _{jk} ## ?
thank you tim, really appreciate it.
