- #36
Mark44
Mentor
- 37,615
- 9,845
In which case, you're very far away from modern computers.AdamF said:Hence, my initial interest in models which do not even involve electricity.
Documentation for the C64 isn't missing. You can still find everything online ,Rive said:6502 is a good CPU, but I would rather recommend an available one instead - even if you get an old Commodore or like, it'll still have a few abstraction layers, but you will have to fight the missing documentation too...
In the short lived era of CRT based memories, it could be considered that the computer did store "images", and the CRT's scanning was used to interpret the "pixels" on the monitor screen as bits.PeterDonis said:These are all one question, because the computer does not store numbers, sound, or images; it just stores bits.
I'm not aware of any standard PC keyboard where the scan code equals the ASCII code. For example pushing down on the letter A on a keyboard produces a scan code of hex 1E or hex 1C (depending on scan code set), and doesn't correspond to hex 41 (ASCII upper case A) or hex 61 (ASCII lower case A).PeterDonis said:Keyboards generate scan codes--sequences of bits that tell the computer what keys were pressed and in what order. ASCII and Unicode are interpretations of sequences of bits as text. It so happens that, if you press an ordinary alphabetic key on the keyboard, the scan code (sequence of bits) that gets sent to your computer corresponds to the ASCII code (sequence of bits) for the letter that's on the key.
I don't know about the Commodore 64, but the Atari 8 bit family of computers: 400 / 800 / 65 XE / 130 XE are also 6502 based (they run at 2 mhz), and there are forums at web sites like AtariAge that have a lot of information on the Atari 8 bit systems and their peripherals, and access to toolsets (assemblers, basic interpreters, ...) . There are now Atari peripheral bus to USB interfaces that allow a PC to act as an Atari peripheral (usually as a floppy disk).Rive said:6502 is a good CPU, but I would rather recommend an available one instead - even if you get an old Commodore or like, it'll still have a few abstraction layers, but you will have to fight the missing documentation too.
rcgldr said:I'm not aware of any standard PC keyboard where the scan code equals the ASCII code.
jedishrfu said:Checkout the Turing Tumble toy at turingtumble.com. Its a marble based computer.
Each marble represents a digital pulse. The marble gates represent electronic ones which activate when a digital pulse is input.
The toy can do binary arithmetic as well as solve logic puzzles and play logic games.
This illustrates some aspects of how a cpu works.
jedishrfu said:In general things are very abstracted in computers nowadays. Keyboard scan codes identify the key that is pressed. A device driver maps it to the locale specific code point to be stored in an input buffer.
Some examples of locale specific code sets are ascii or extended ascii or unicode.
Later at display time, the locale code point selects a character from the specified font table and the font data is rendered on screen or printed.
Yes. There seems to be some research on optical computers, in which the signals would be sent by lasers, but there are difficulties converting between optical and electrical signals, so this type of computer seems to be down the road a few years.AdamF said:Is the main reason that electricity is used for the modern computer is because electricity moves so much faster?
I don't think so. The bottom area just collects the marbles that have gone through the various doodads. They don't "remember" what gates they have gone through. A better analogy I think would be a battery that powers a cellphone.AdamF said:By the way, in the Turing Tumble, the bottom area that collects the marbles would be analogous to a form of "memory", right?
This is a better analogy than some you've come up with. The switches in a house correspond pretty closely with the capacitors in a static RAM chip, a kind of memory that preserves its state even when the power is off, such as in solid-state external hard drives. That's in contrast to dynamic RAM, which loses its state when it's no longer powered.AdamF said:Okay, so the idea of the computer memory is kind of like the wiring in a house, where you can turn off the power to the house, but when you turn it on again, the electricity will flow to the areas that were on before because the circuits are still being completed there, regardless of whether or not they have power?
AdamF said:
All well and good, but if I wanted to know about computer architectures and such, I would want to work with some actual hardware.jedishrfu said:In the turing model the tape is the only memory with the machinery reading and writing values to the tape. The tape controls what the machine does.
It is the most fundanental of computers and is used in exploring many fundamental computer science theorems most notably the halting problem.
Mark44 said:All well and good, but if I wanted to know about computer architectures and such, I would want to work with some actual hardware.
A related processor is the Motorola 68000, the processor used on the original Macintosh computer, as well as the Commodore Amiga. A simulator is available at http://www.easy68k.com. There might also be one for the 6800.jedishrfu said:I was thinking that a discussion using the 6800 cpu might help in this thread since it had memory mapped io which eliminates some complexity from the discussion.
It might be too long for an Insights article. The recommended length is ~800 words, although I have exceeded that limit several times. If one could fit a summary into an article, it would have to be very sparing on any details.jedishrfu said:But I am still thinking about how to summarize it in a post even though we know there is so much more to how a computer actually works. It might make a good insight article though.
The label on that machine is misleading, as would be calling any physical machine a 'Turing Machine', because doing so obscures the fact that a Turing machine is a hypothetical machine, wherein lies its usefulness.jedishrfu said:This is true. However, I was responding to the OPs markup of the Turing photo where two memories were identified and i wanted to make it clear that only the tape is the memory.
There's also the Atari ST, and as mentioned for 6502, forums like AtariAge where there is a lot of information about the Atari ST. My preference for the Atari ST is that it is a port of Digital Research's GemDos from PC to 68000, which is a GUI on top of the equivalent of MSDOS ported to 68000. The ST can read and write MSDOS floppy disks.Mark44 said:A related processor is the Motorola 68000, the processor used on the original Macintosh computer, as well as the Commodore Amiga. A simulator is available at http://www.easy68k.com. There might also be one for the 6800.
The MIPS instruction set and syntax seem awkward to me. I'm not sure why it became so popular. I think the other processors mentioned in this thread would be better choices, but this is opinion based.Mark44 said:MIPS 32-bit processor.
I'm pretty familiar with the MIPS instruction set now, having taught a course twice in which it is used. There are lots of registers (32 integer registers, and 16 or 32 floating point registers, depending on whether you use them for doubles or floats), as opposed to the paltry collection available on, say, an 8086. You can use the MIPS registers for whatever -- there's no distinction between address registers and data registers, as on the 68000 (and presumably the 6800 works the same way).rcgldr said:The MIPS instruction set and syntax seem awkward to me. I'm not sure why it became so popular. I think the other processors mentioned in this thread would be better choices, but this is opinion based.
I would prefer some variation of the ARM processor, but it is (or at least was) expensive to get a development took kit with an emulator.Mark44 said:The MIPS instruction set is sparse, to be expected in a RISC processor, but the instructions are straightforward to use, IMO. For example, all of the arithmetic instructions take three operands
True, but you can buy used 6502 "home computers" such as the Atari or Commodore, and I think there are emulators, that don't cost too much. The Z80 has a better instruction set, and Z8 is even better (with 128 or 256 registers), but Z8 was never popular. The worst instruction set I encountered was the Data General Nova, 4 registers, with only 2 of them used for math, and reduced instruction set that required sequences like load r0, load r1, add r0,r1, store r0, ... (no add from/to memory instruction). I recall some Fortran based apps that could not be compiled on the Nova because the code size exceeded 64K, while those same apps could be compiled on 8080 or 6502 based systems within the 64K limit.Mark44 said:I've never written an 6502 code, but I know a little about its instruction set and register set. In comparison to modern CPUs, or even other processors of its time, it had a very small set of registers: A (accumulator), X, Y, PC (program counter), and S (stack pointer).
Thanks again for the Lego model, I understand a lot more of where I was off w/ identifying the memory now.jedishrfu said:Here’s the one I was thinking to post but for some reason couldn’t locate at the time
It’s a true Turing machine built from LEGO with a sliding tape. The machine toggles the bits and the bits control the machines operation.
https://www.wired.com/2012/06/lego-turing-machine/
