U.Renko
- 56
- 1
I have small block of mass m=1kg on top of a bigger block mass M=10kg
The friction coefficient between the blocks μ=0.40
No fricton between the big block and the ground.
There is a spring with k=200N/m attached to the bigger block.
The problem asks what is the maximum amplitude A the system can have in an harmonic oscillation without relative motion between the blocks.
x=A\cos(ωt+\phi)
v=-ωA\sin(ωt+\phi)
a=-ω^2A\cos(ωt+\phi)
well, first I noticed that the maximum static force possible between the two blocks will be:
mgμ which gives: (1kg)(9.8m/s^2)(0.40) = 3.92N
so far no problems I guess.
using F=ma, I calculate the acceleration of the system in the case of maximum friction:
a= F/m = (3.92N)/(11kg) which gives a = 0.356m/s^2
using ω^2=k/m=(200N/m)/(11kg) which gives ω^2= 18.18rad/s^2
Now here is where I got stuck
I plug this to a=-ω^2Acos(ωt+\phi) and try solving for A
the thing is:
I don't know the time
I don't know if there is a phase angle involved or not. or how to find out.
