Why Does a Zero Integral Imply a Function Is Zero Almost Everywhere?
  • Thread starter Thread starter Ja4Coltrane
    Integration
If the integral of a non-negative measurable function f over a measure space (X,m) is zero, it implies that f must equal zero almost everywhere. The discussion revolves around proving that if f is positive on a set A with positive measure, then the integral over A would also be positive, contradicting the assumption that the integral over X is zero. The key argument is that if f is non-zero on a set of positive measure, the integral cannot be less than the integral over that set. Thus, the assumption leads to a contradiction, confirming that f must be zero almost everywhere. This conclusion reinforces the relationship between the integral of a function and its values across measurable sets.
Ja4Coltrane
Let (X,m) be a measure space, f:X->[0, infinity] be measurable.
If the integral over X of f is 0, show that f=0 almost everywhere
Suppose that f is nonzero on A, m(A)>0.
I've reduced problem to proving that the following is impossible:
f is positive on a set of nonzero measure and
{x such that f(x)>epsilon} has zero measure for all epsilon greater than zero.
I don't know how to do that though...
Any help?
Suppose the statement is not true- that there exist a set A, of measure greater than 0, on which f is positive. Then the integral of f over A alone is positive and, since f is never negative, the integral of f over X is not less than the integral of f over A.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 47 ·
