Basic Math Help: Solving (3x+5)^{-4}=64 with Step-by-Step Guide
  • Thread starter Thread starter OrigamiCaptain
The discussion revolves around solving the equation (3x+5)^{-4} = 64, as presented in Serge Lang's Basic Mathematics. Participants are exploring the algebraic manipulation required to isolate x and are comparing their attempts with the book's solution.
  • Mixed
  • Participants are sharing their attempts at solving the equation, noting discrepancies between their results and the book's answer. Some are questioning their algebraic steps, particularly regarding the handling of square roots and signs. Others are discussing the importance of clear notation in mathematical expressions.
There is an ongoing exchange of ideas, with some participants providing guidance on notation and algebraic manipulation. While there is no explicit consensus, several suggestions for clarifying the original poster's approach have been made, indicating a productive direction in the discussion.
Participants have noted the challenge of conveying mathematical work through text rather than images, which has led to some frustration. The original poster expresses a desire to understand their mistakes without being able to attach photos of their work.
OrigamiCaptain
I'm working out of Serge Lang's Basic Mathematics and in chapter 3 section 3 this problem comes up.
[itex](3x+5) ^{-4} =64[/itex]
I keep getting [itex](1-(5±\sqrt{8}))/(3±\sqrt{8})[/itex]
The book says it is [itex](±1-5\sqrt{8})/(3\sqrt{8})[/itex]
It is not exact. I know [itex]\sqrt{8}=2\sqrt{2}[/itex]
Thank you for your help.
I'm obviously forgetting something basic and it is bothering me. Thanks.
The book is correct. How do you expect us to help you find your mistake when you don't show us your steps?
You're taking the square root of each side, then the same again?
This is my attempt. I hope it is legible
.View attachment 74250
Don't attach photos. PF wants you to type out your work.
Ok, but why? That makes no sense. That is much more difficult and time consuming and it produces the same outcome. I would get ride of it, but it is not letting me now. Feel free to remove it if you like.
If you don't want us to attach photos then why included the ability to add an attachment?
It looks like you are doing alright until about 2/3 down the page.
You get to ## 3x-5 = \frac{1}{\pm \sqrt{8}}##. Then you do something I don't understand, and that is where you get off track.
If you are multiplying by a ## \pm \sqrt{8}## please use parentheses so you don't confuse it for adding or subtracting later on.
As far as I can tell, your solution may be off because of what I just mentioned.
You could also take one at a time (either plus or minus) then express the solution with a ##\pm ## at the end. For more complicated algebra, this will help you maintain some sanity, even though it might take more paper.
When I get to [itex]3x+5 = \frac{1}{\pm \sqrt{8}}[/itex]
I subtract [itex]-5[/itex] from both sides
[itex]3x= \frac{1}{\pm \sqrt{8}} -5[/itex]
[itex]3x=1-(5±\sqrt{8}))/(±\sqrt{8})[/itex]
Then I divided by 3.
I think you are trying to write ## 3x = \pm \frac{1}{\sqrt{8}} - 5 ##
Multiply through by ##\sqrt{8}## on both sides to get:
##3\sqrt{8}x = \pm 1- 5\sqrt{8}##.
This is why I mentioned it might be easier to do plus first, then minus. Your expression ##(5 \pm \sqrt{8}) ## appears like addition (or subtraction), but the only way you get there is by multiplying ##(\pm \sqrt{8}) ## onto the 5--so either your notation is wrong or your understanding of algebra is wrong. I assume the former. In any case, that is the only place your answer differs from the book answer you have above.
No my algebra is definitely wrong here. I need help understanding what I did wrong. I divided by ##\pm\sqrt{8}## and I either don't know something or forgot something and my algebra is wrong. What used latex to show is what I did.
It doesn't bother me to be wrong as long as I figure it out.
I apologize for the tone in my earlier post. I meant to say that it looks like you are doing the right steps, but poor notation is killing you.
The signs in the denominator are often easier to keep track of when you pull them to the front.
## \frac{1}{\pm \sqrt{8}} =\pm \frac{1}{ \sqrt{8}}##
However, what you have is not wrong.
## 3x = \frac{1}{\pm \sqrt{8}}-5##
There is no problem multiplying by the ## \pm## but it complicates things.
You could from what you have there just write
##x = \frac13( \frac{1}{\pm \sqrt{8}}-5)##
But I suppose you are trying you get something that looks like the book answer.
So distribute the 1/3 in and pull the ##\pm ## out of the bottom.
##x = \pm \frac{1}{ 3\sqrt{8}}-\frac53##
The book answer is just this put over a common denominator.
You went wrong when you put :
##3x=(1-(5 \pm \sqrt{8}))/(\pm \sqrt{8})## when you should have written ##3x=(1-5 (\pm \sqrt{8}))/(\pm \sqrt{8})## to represent the multiplication.
Note that this is equal to ##3x=1/(\pm \sqrt{8})-5 (\pm \sqrt{8})/(\pm \sqrt{8})## and the ##\pm ## cancel in the second fraction.
It's easier for someone to help when they can use the "Quote" feature to pick out specific steps in your calculation in order to comment on them, instead of having to read them off a photo and type them in, and then proofread for errors in transcription. It's enough work for them to fix mistakes in their own equations!
Ok I see what you were saying now. I appreciate the help.
Ok, fair enough. I'll keep that in mind.
Ok I see what you were saying now. I appreciate the help.Ok, fair enough. I'll keep that in mind.
Ok, all sorted now? ;)
Sometimes you need to attach pictures of diagrams from books or notes, for example, or maybe drawings of geometric figures, etc. Other than that, attachments are discouraged.
Anyway, back to your problem: it can be written as ##X^4 = r^4##, where ##X = 3x+5## and ##r = 1/\sqrt{8}##. For real ##r > 0## the equation ##X^4 = r^4## has two real solutions, ##X = \pm r##, and two complex (pure imaginary) solutions ##X = \pm i \, r##, where ##i = \sqrt{-1}##. Therefore, there should be only two real solutions for ##x##. These are ##x = (r-5)/3## and ##x = (-r-5)/3##.
There's a small learning curve for LaTeX, but it's actually not all that difficult nor time-consuming. I know some of the helpers don't seem to care, but I usually pass over threads where students can't be bothered to type up their work.
