Basic Notation Q's: x, y, z, u, f(x)
  • Thread starter Thread starter The_ArtofScience
    Notation
The discussion clarifies the meaning of mathematical notations such as y(0)=1 and u=f(x,y,z). It explains that y(0)=1 indicates that when x is 0, the dependent variable y equals 1, which can be visualized as a point on the y-axis. The expression u=f(x,y,z) describes a function that assigns a value based on three independent variables, often interpreted as coordinates in space, such as temperature at a point. The challenge of visualizing functions of three or more variables is highlighted, as they cannot be easily represented in our three-dimensional space. The conversation emphasizes the importance of context in understanding functions and their variables.
The_ArtofScience
I don't know if this is a terribly ignorant question but I was wondering what exactly is y(0)=1? Is that like f(0)=1 where the x is 0 and the y is 1?
I'm also curious about the expression u=f(x, y, z). What is that exactly? How is it related to the x, y, z coordinates?
Mathematics news on Phys.org
Since you haven't said what you mean by "f" or "y", it's hard to be precise. IF you have some function f(x) (or g(t), h(u), etc.) that you want to graph on an xy-coordinate system, since it is standard to use the x-axis to represent the independent variable (x or t or u or whatever) and the y-axis to represent the dependent variable (f(x) or g(t) or h(u) or whatever), yes it is standard to y= f(x) or y(x) in place of f(x). If f(0)= 1 and you have assigned x to the independent variable and y to the dependent variable, perhaps for graphing purposes, then you would have y(0)= 1. On a graph, that would be a point exactly one unit above the origin on the y-axis.
u= f(x,y,z) is a function that assigns a value to each possible combination of three independent values. Although, like all of mathematics, it can be used in many different ways, it is a common application to think of x, y, z as coordinates that designate points in space. One specific application would be to think of u as air temperature. A coordinate system would assign three numbers to each point in space. u(x,y,z) would be the temperature at each point.
Thank you, Ivy. I really liked your explanation.
I'm still curious though, if f(x,y) represents z, then what would f(x,y,z) be? Its hard to imagine another coordinate in the xyz coordinate plane, and if there is another coordinate, I might be overlooking it.
f(x, y, z) is a function that gives a value for each point in space, rather than each point in a plane. The example that HallsOfIvy gave, is the function that assigns to every point in the room the air temperature at that point.
The problem with functions of three and more variables is that we cannot draw them because we don't have enough dimensions. A function f(x) of one variable, can be drawn in two dimensions (set up an x-axis, and for each point x draw the corresponding value f(x) directly above it on the y-axis). Functions of two variables can still be drawn: above each point in the plane, draw the function value on the z-axis, like https://www.physicsforums.com/latex_images/96/968788-0.png . But to draw a function of three variables, you would have to have four perpendicular axes. Unfortunately we only live in a three-dimensional space, so it's very hard imagining this (and impossible doing it intuitively, let along projecting it on a two-dimensional piece of paper). Best thing you can do is try to think of the temperature analogy. You can then extend this also to a function of four variables, f(x, y, z, t) which would give the air temperature in the room at a given point (x, y, z) and a time t.
Another way to look at it: consider a function like a slot machine. It has some number of input slots, which we label by arbitrary letters (x, y, z, ...) -- if you put numerical values on these slots the function machine spits out a value. For example, the function f(x) = x^2 has one input slot x: if I insert x = 3 it spits out 9 and if I put in x = 1/2 it spits out 1/4. The advantage of a function of one (two) variables is that it can be graphed, by putting all possible input values on the x-axis (x and y axes) and the corresponding output on the y (z) axis, which gives you an insight in how the number is produced (e.g. if I slightly increase x, what will happen to f(x)), an advantage you don't have in more dimensions (though, in more advanced mathematics there are ways to describe the behavior of arbitrary functions which are almost as good as drawing graphs).
I didn't say "f(x,y) represents z". f(x,y) is a function of two variables and may have nothing to do with 'z'. If could, for example, represent the temperature at some point (x,y) on a heated plate. It depends upon the application of the function.
Of course, you can't have both "z= f(x,y)" and "f(x,y,z)"- but that has nothing to do with z. You are using "f" to mean two different things; it can't be both a function of two variables and a function of three variables.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
