Is the Square Root of a Number Always Considered a Function?
  • Thread starter Thread starter pamparana
    Functions
The square root function is defined to yield only the positive root, making it a valid function according to mathematical definitions. Each input in this context corresponds to a unique output, as the square root of a number like 25 is defined as +5, not ±5. While the concept of multivalued functions exists, they do not qualify as functions in the strict sense because they do not provide a single output for each input. The confusion arises from the common misunderstanding that the square root symbol implies both positive and negative roots. Therefore, the calculus book's definition is correct in stating that the square root function adheres to the principle of unique outputs.
pamparana
Hello,
My calculus book is confusing and I am pretty sure this is an error. It describes a function as one where one distinct input will have one and only one distinct output. Fair enough.
The next example is output of f(x) = square root (x) when input is 25!
Clearly, this is not a function! This relation (obviously) does not result in a unique output for every unique input, right? square root (25) = +5 and -5.
Or am I missing something in function defs. The book does not even consider the negative value of a square root operation.
That's what I get for buying the idiot's guide...
Please let me know if I am missing something here.
Thanks,
Luca
Your calculus book is correct. A function maps each element in the domain to a unique element in the range.
The square root function is usually defined to be the positive square root. Sometimes you can talk about http://en.wikipedia.org/wiki/Multivalued_function" such as 'plus or minus the square root', but they are not functions, strictly speaking. (they are relations)
This is why the +/- is needed next to the discriminant in the quadratic equation formula. If the square root symbol was understood to mean both positive and negative roots, it wouldn't be necessary.
Thanks guys. I always thought that the square root symbol always meant both +ve and -ve roots.
cheers
  • · Replies 36 ·
  • · Replies 16 ·
