Basic Special Relativity (Time Dilation)
7 replies · 4K views
bmb2009
The Concorde traveled 8000km between two places with an average speed of 375 m/s. What is the time difference between two atomic clocks, one on the train and one at rest with respect to the train?
T=AT' where A is the Lorentz gamma factor
Seemed simple enough the distance divided by time would yield the T (the time taken from the rest frame) so (8x10^6 m/s)/(375) and then solve for T' (proper time which would be the time of a clock on the train correct?) but the speed of 375 m/s is so miniscule in comparison to the speed of light the lorentz factor comes out to be 1 (which isn't surprising) but in the back of the book it says the answer is 16.7 microseconds...what am I doing wrong? Thanks
To a good approximation for your problem, you can approximate [1-(v/c)2]1/2 using the binomial approximation (1-x)a≈1-ax for x<<1.
Not using a calculator with enough precision?
How does this help though? that just makes 1-ax = 1 - (7.8125e-13) which still is very close to 1. Where/how do you produce the 16.7 nanoseconds?
Use the binomial approximation in the equation T = AT' without plugging any numbers in yet. Then see if you can rearrange for the quantity T-T'. Then plug in numbers.
I don't think you can )easily) solve for T-T' with the expansion... T=T'/1-ax ==> T-Tax=T'...unless I am missing some simply algebra i don't see how to manipulate to solve for T-T'
Rearrange your last equation as T - T' = Tax
As you said in your original post, you know how to get T for the right hand side.
ahhh finally got it.. Thanks a bunch!
