Basic Statics - A weird outcome. Contradictory?
  • Context: Undergrad
  • Thread starter Thread starter Femme_physics
    Statics Weird
The discussion revolves around the behavior of static friction in a mechanics problem involving a beam resting on a floor with a known static coefficient of friction. Participants explore the implications of applying the static friction formula in different contexts and question the nature of static friction forces.
  • One participant presents a scenario where they calculate the static friction force and questions the validity of using the formula Fs = N x μ with their calculated results.
  • Another participant argues that the formula is not valid for static objects, emphasizing that only the maximum friction force can be considered in static situations.
  • A participant challenges the idea of experiencing a horizontal force from static friction when standing still, suggesting that friction does not act unless there is movement.
  • One participant proposes that either the friction coefficient or the normal force must change, suggesting that the coefficients listed in charts represent maximum values reached only at the verge of movement.
  • Another participant clarifies that the static friction force adjusts to maintain equilibrium and that the maximum static friction force is given by μstatic times N.
  • A later reply confirms understanding of the concepts discussed, indicating some resolution for that participant.
Participants express differing views on the application of the static friction formula and the nature of static friction forces. There is no consensus on the implications of using the formula in the context described, and the discussion remains unresolved regarding the interpretation of static friction coefficients.
Participants reference the maximum static friction force and its relationship to the normal force, but there are unresolved assumptions about the conditions under which these values apply. The discussion highlights the complexity of static friction in mechanics without definitive conclusions.
Femme_physics
This is not a HW question! THIS IS A DISCOVERY that I want to explore. I will explain it as follows:
Suppose I have this exercise, where I know the static coeffecient between the beam and the floor is 0.3, whereas in the wall there is no friction. I want to find out if the beam slides, or stays up. That's easy.
http://img703.imageshack.us/img703/4676/fsmaxtest.jpg
So by doing the calculations, I can see the beam doesn't slide. I solved the problem. Now, let's say I want to experiment further. What happens if I put the result of Fs I got when I didn't calculate Fs_max into the Fs = N x μ equation? I think it's a valid thing to do, since it's in the formula. But what happens then?
I'd get a different result for N. Which doesn't make sense, since N must be 30 [N] to resist the weight of the beam.
The friction coefficient sure can't change, since it is constant!
So, what did I just do? Did I find loop in mechanics theory?
Not valid. If the surfaces were moving, you could use such a formula. In case of static objects, we can only get the maximum friction force.
When we are standing on the floor, there is a normal equal to our weight W . The surface has a μ too. Does it mean we are experiencing a horizontal force of μW on our shoes?!
Of course not. We don't feel friction without moving in the axis it exists.
How come?
If you recall
http://img62.imageshack.us/img62/7107/frri.jpg
So clearly either the friction coeffecient or the normal force haven't reached their max value. One of them must change. Since it can't be the normal force, as that would defy mechanics, it must be the coefficient: This is my new assumption. The coefficients we see in charts therefor are maximum values. We reach that maximum value of that coefficient only on the verge of movement.
How about that for theory?
You will get the minimum N needed to prevent sliding due to Fs.
No, it has nothing to do with the actual N.
Yes, the static friction coefficient tells you the maximal horizontal force for a given normal force, for a static case.
Obviously.In every decent book I read,
they clearly state that Fstatic≤μstaticN
and NOT FstaticstaticN
That is,the friction force adjusts itself to keep the concerned body in equilibrium.And the maximum it can be in order to negate the applied forces is given by μstatic times N.
So the coefficient remains constant,but the maximum force of static friction,ie μstaticN is experienced only on the verge of the movement.
Got it sorted out. Thanks :)
  • · Replies 35 ·
  • · Replies 22 ·
  • · Replies 35 ·
