Why is My C++ Program for the Bateman Equation Returning NAN?
  • Context: C/C++
  • Thread starter Thread starter lapo3399
    C++
The discussion revolves around troubleshooting a C++ program designed to evaluate the Bateman equation for radioactive decay series. Participants are exploring potential issues leading to the program returning NAN (Not a Number) for the mass remaining after 1 million years, despite expected values for certain nuclides.
  • Homework-related
  • The original poster describes the issue of the program outputting NAN regardless of the nuclide selected, expressing uncertainty about the cause.
  • Some participants suggest adding print statements to debug and track intermediate values in the program.
  • A later reply indicates that the first for loop should be adjusted to "i<(iter-1)" and questions the inclusion of a break statement in the second for loop.
  • Another participant inquires about the validity of input values and whether there might be an attempt to calculate a null with an int/double.
  • Several participants express interest in obtaining a copy of the source code for further examination or use in related projects.
Participants have not reached a consensus on the specific cause of the NAN output, and multiple viewpoints regarding debugging strategies and potential code adjustments remain. The discussion reflects a mix of suggestions and observations without a definitive resolution.
Limitations include the absence of the decay constants file, which is critical for running the program, and unresolved questions about the handling of decay constants and the structure of the loops in the code.
Readers interested in programming related to radioactive decay, debugging C++ code, or studying decay chains in nuclear physics may find this discussion relevant.
lapo3399
Hello,
I am attempting to create a program that will evaluate the Bateman equation for radiactive decay series, given several decay constants stored in a text file. I am not sure where this is going wrong, but no matter what chain member I enter in as the desired nuclide to find the mass remaining after 1 million years, it outputs NAN - even when I choose the nuclide that I am certain to have a perceivable value. The equation I am emulating later in the program is shown below, please help to explain why this is not working! All help is appreciated!
http://img515.imageshack.us/img515/5097/screenshotml6.jpg
Code:
#include <iostream>
#include <math.h>
#include <fstream>
#include <string>
using namespace std;
int main(int argc, char** argv)
	string line; //for file input
	int iter; //stores which nuclide will be calculated for
	double dcs[23]; //array for decay constants
	int anum = 1; //counting var
	ifstream deconst;
	deconst.open ("decayconstants.txt", ios::in); //file with decay constants
	if (deconst.is_open())
		while (! deconst.eof())
			getline(deconst, line);
			dcs[anum]=strtod(line.c_str(), NULL); //store as double in decay constant array
			anum++;
	std::cout << "What nuclide in the chain should be evaluated?";
	std::cin >> iter;
        //I separated the equation into multiple parts
	double consts=1; //part one: the multiplied decay constants at the beginning of the equation
	double init = 100; //the intial mass, N(O)
	double time = 1000000; //the variable t, one million years
	double sum=0; // the second half of the equation, the summation
	double totalmass; //the product of consts,init, and sum
	for (int i = 1; i < iter; i++)
		consts=consts*dcs[i]; //multiply all the necessary decay constants
	for (int q = 1; q < iter; q++) //the summation
		double expo = exp(-dcs[q]*time); //determine the numerator in the summation
		double denom = 1;
		for (int w = 1; w < iter; w++) //the product
			if (w==iter) //k can't be j
				break;
			else
				denom = denom * (dcs[w]-dcs[q]); //multiply together to get the product
		sum = sum + (expo/denom); //add up all of the summations
	totalmass = sum*consts*init;
	std::cout << totalmass;
	return 0;
Thanks again!
Technology news on Phys.org
Well, I can't run your program without the file it needs to read, but I'd suggest putting some count statements throughout the code to print out the intermediate values.
- Warren
I've attempted that, and I finally realized what the problems where this morning. Firstly, the first for loop should read "i<(iter-1)", and I shouldn't have included the break statement in the other for loop.
Hi,
I see that you said your program worked. I am working with a few students to develope a detector but i also needed them to study the decan chains of Radon. I think your program will be useful, do you think i could get a copy of it?
have you checked all of the values prior to use?
If so, are you trying to calculate a null with an int/double?
Hi,
would it be possible to get a copy of the source code?
