Battery alone deflects compass needle?
14 replies · 6K views
Ebrightb
I'm an introductory electromagnetism course and in lab we were observing how an electric current could deflect a compass needle. however, i also noticed that the batter itself (with no wire attached, so no current) could also deflect the needle. (for ex, if you brought the the + end of the d cell near the compass the needle would move). These were Duracell alkaline D batteries.
Does anyone know why this might be happening?
My first thought was that since there was a potential difference across the terminals of the battery, that when i moved the battery i was moving charges, thus creating a current and therefore a magnetic field that deflected the compass. However, it can't be just from me moving the battery because I took a magnaprobe to a stationary battery saw the same effect. I also saw this with other batteries, it was not unique to one. What could be causing this? Let me know your thoughts!
I think the explanation is much simpler. The battery casing is probably made out of steel (iron). What does that suggest?
i thinks that...
the battery is charged and every charged particles have a magnetic field.
  • Sad
So your suggestion is that since this battery has at some point been connected to a circuit, that current aligned the (what are they called, territories?)in the metal and thus magnetized the casing? If this is true, would i not expect to see this from a brand new battery?
hafiz ns said:
i thinks that...
only moving charges create a magnetic field!
I'm sure that's NOT what he is suggesting.
There is no need for the battery to be magnetised. Do you know how a compass is made?
Indeed, all the batteries I have tried are attracted by magnets.
Not surprising after reading that the positive pole is a cylinder made of steel.:)
See, for example, http://en.wikipedia.org/wiki/Alkaline_battery
under "Construction".
It has nothing to do with being connected in a circuit or with the electric charge separation in the battery. It's just some steel interacting with a magnet.
yes, I understand any piece of metal is attracted to a magnet, but that would not explain why opposite end of the compass needle are attracted to opposite ends of the battery right?
Yes, it does. Any end of a magnet (the compass needle is a magnet) is attracted by steel.
And both ends of the battery have some steel. At least in my batteries. So any end of the battery is attracted by any end of the magnet.
This is it.
If you would observe some repulsion then you may assume that the steel casing have some proper magnetization.
Even if the battery would have produced some proper magnetic field, it would have been most likely shielded by the steel casing.
Iron very easily picks up magnetization from any stray magnetic field. A few strokes of a magnet on a screwdriver will let it pick up screws. And it only takes a weak magnetic field to swing a compass.
Does either terminal of the battery repel the needle?
yes, one end of the battery attracts one end of the needle/repels the other while the opposite is true for the other end.
Ok then than means the battery has become slightly magnetised. Probably when the cases are manufactured.
This is it.
This is the right answer.
Any ferromagnetic element will attract the magnetic compass needle.
Welcome to PF! FYI, this thread is 9 years old...
  • Love
