aleksxxx
- 23
- 0
1. "lets set the internal resistance, r^_i, of the battery with emf E^_i equal to bE^_i where b is a constant assumed the same for all three batteries.
E^_1=5v
E^_2=10v
E^_3=15v
r1=bE^_1
r2=bE^_2
r3=bE^_3
http://i17.photobucket.com/albums/b51/chs2004/physics1.jpg
2.To decrease internal resistance we can connect the batteries in parallel, although this advantage could be offest by a decrease in net voltage. To test this hypothesis find the current flowing through the 200 ohm resistor, assume 'b' is the same from part one.
http://i17.photobucket.com/albums/b51/chs2004/physics2.jpg
Kirchoffs's (sp) Loop Rule
Ok - For part one i set up the loop rule equation as follows:
E^_1-Ir^_1+E^_2-Ir^_2+E^_3-Ir^_3-I(200ohms)=0
After substituting in the EMFs and resistances i got the equation:
-2.6=-.137bE^_1-.137bE^_2-.137bE^_3
From there i factored out the .137 and brought that to the other side and then factored out the 'b' and got:
19=b(5+10+30)
b=.6Im not sure i did that first part right, because for the second part when i figure out all the currents, I1, I2, I3, they all come out to the same thing because the equation, I=E/R, and R=bE, the EMFs just cancel giving me 1/b for each current, 1.7A=I1=I2=I3.
Then using I=5.1A solving for the deltaV across the 200ohm resistor i get:
DeltaV=(5.1A)(200ohms)=1020V (WAYYY too high)
Im not sure where I am going wrong here...i tried this and another way and i still get a deltaV higher than the combined voltages of the three batteries
