Battery Q&A: Memory Effect & Voltage Depression
  • Thread starter Thread starter mister_okay
    Battery
The memory effect refers to a specific issue in rechargeable batteries where they lose capacity if not fully discharged before recharging, often due to non-uniform electrode plating. Voltage depression, on the other hand, is a mislabeling of this phenomenon and relates to the battery's voltage dropping under load, especially when abused. Even when powered off, devices like mp3 players can still drain batteries, particularly if they have components that consume small amounts of power. A fully charged battery typically provides a voltage of 1.2V per cell, but can drop to 1.0V under heavy load or damage, leading to inaccurate readings of remaining charge. Understanding these concepts is crucial for proper battery maintenance and usage.
mister_okay
Hello everyone:)
I have questions regarding the "memory effect" and voltage depression.
1.) Could someone explain to me in layman's terms exactly what they are? I don't quite understand the explanation on wikipedia.org.
2.) Additionally, my friend told me that when you turn your mp3 player off (samsung YEPP) you should take out the battery because even with the power off, it will drain. Is this true?
1) The memory effect is usually attributed to non-uniform plating of the electrodes inside the battery.
2) Your battery will actually drain even if it's not in the player. It is possible that your player will cause it to drain a bit faster, however, depending upon how it is built (is the power switch mechanical, or electrical?) Some electronics constantly consume small amounts of power. If you really want to know, hook a sensitive ammeter in and see how much current it draws when powered off.
- Warren
But what exactly is the memory effect and voltage depression?
Mister - one is a specific problem and the other is mistakenly labeled as the same. Since you've read the description and likely aren't building a satellite it doesn't really matter if you're using a widely accepted term (even if technically slightly off).
The battery normally offers a certain voltage, let's say 1.2V per cell. Now when fully charged and unloaded this may be 1.3V. When being used at high loads it may be 1.1V and falling as it drains. If the battery is suffering from being abused, it will read much lower, like 1.0V when you try to use it. A new battery fully charged wouldn't read 1.0V until it was say less than half full, so the equipment could mistake this for a battery that is much less full than it actually is.
This is more of a problem with rechargable batteries because an alkaline battery is generally 1.5V and the rechargable is 1.2V, thus meaning the equipment would need to be designed to work this way (and usually is). But when it comes to figuring out how much charge is left in the battery, its an educated guess and can be wrong. Having batteries that can be slowly damaged and change their behavior increases the likelyhood the guess will be more wrong.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
