Beam deflection by superposition
3 replies · 4K views
Jim Newt
In this problem, I'm trying to solve for the Reaction, Rb
I believe for the distributed load, the deflection equation would be:
v = (-qx/24EI) * (L^3 - 6Lx^2 + x^3)
For the support, Rb, the deflection equation could be:
v = (-Pbx/6LEI) * (L^2 - b^2 - x^2)
where L = 3L
total deflection at Rb = db1 - db2 = 0
I could solve for Rb with the proper equations.
For db1:
When I plug in x=L and L=3L, I end up with db1 = (11qL^4) / 12EI.
This answer matches the solution manual.
I can't figure out db2...I think I might be using the wrong deflection equation, but I'm not sure. The correct answer for db2 is db2 = (4RbL^3) / 9EI
How do I go about solving for db2?
Ok, maybe my whole method is bunk. Given the standard beam deflection equations, how would you solve for Rb?
You set up the equations perfectly! You may have made a math error in your db2 equation, perhaps forgetting to convert l to 3L. Note that in using the beam tables, you could have used db2 = (Rba2b2)/3EIl, the deflection at the point of the applied reaction load. The result is the same.
Hey thanks buddy! I went through it again and ended up with the correct answer. Its always the tidbit math that gets me...
