Behaviour of EM-wave near a non-resonant antenna
The behavior of electromagnetic (EM) waves interacting with non-resonant antennas involves scattering rather than simple reflection or transmission. When an EM wave reaches a conductive antenna, a current is induced in the material, leading to re-radiation of the signal and partial reflection, which distorts the local field. Resonant structures, in contrast, can generate higher induced currents and create interference patterns, necessitating that a rod or near-resonant structure be slightly longer than its resonant length to effectively act as a mirror for specific frequencies.
  • Understanding of electromagnetic wave propagation
  • Knowledge of antenna theory and design
  • Familiarity with resonance in conductive materials
  • Basic principles of signal scattering and re-radiation
  • Research the principles of electromagnetic wave scattering
  • Study the design and characteristics of resonant antennas
  • Explore the effects of antenna length on resonance and reflection
  • Learn about interference patterns in electromagnetic fields
Electrical engineers, antenna designers, physicists, and anyone interested in the interaction of electromagnetic waves with conductive materials.
Timothy S.
What will happen with the electromagnetic wave reaching an antenna when this antenna is not resonant on the frequency of the wave: will it reflect from antenna or pass through it?
Thank you
It does not have to be a non-resonant antenna, any conductor will scatter a signal.
A current will be induced in the conductive antenna material, that will, in effect, re-radiate the signal. The partial reflection will add to the incident wave, distorting the field locally.
Resonant structures can build up higher induced currents, forming interference patterns throughout the region.
May I mention that if we want a rod or near-resonant structure to act as a mirror, then it must be resonant at or a little below the require frequency. This often means it should be a little longer than the resonant length, and shorter rods tend to be transparent.
  • · Replies 24 ·
