Behaviour of series (radius of convergence)
The discussion revolves around the behavior of a series defined as \(\sum_{n=1}^{\infty}(-1)^{(n+1)}\frac{(x)^n}{na^n}\) at its radius of convergence, specifically when substituting \(z = -\rho_o\). Participants are exploring the implications of this substitution and the conditions under which the series converges.
  • Participants discuss the monotonicity of the series when \(z\) is non-negative and express confusion regarding the application of the integral test. There are questions about the meaning of symbols like \(\rho_0\) and \(z\), and whether the series can be treated as positive or non-negative for convergence tests.
Some participants have identified the radius of convergence as \(\rho_o = |a|\) using the ratio test and are considering how to analyze the series' behavior at this point. There is a suggestion to substitute specific values into the series to explore convergence, and some guidance has been offered regarding the simplification of the series based on the sign of \(a\).
There is mention of a potential typo regarding the use of \(z\) instead of \(x\), and participants note that the series may not be complete without considering additional terms. The discussion reflects uncertainty about the implications of the radius of convergence and the behavior of the series at that point.
Lengalicious
Series:
[tex]\sum_{n=1}^{\infty}(-1)^{(n+1)}\frac{(x)^n}{na^n}[/tex]
what is the behaviour of the series at radius of convergence [tex]\rho_o=-z[/tex] ?
So I can specify that the series is monatonic if z is non negative as [tex]\sum_{n=1}^{\infty}(-1)^{(n+1)}\frac{(-z)^n}{na^n}[/tex] right?
But then I suppose I have to do the integral test but I am a bit confused because you cannot integrate [tex](-1)^{(x+1)}\frac{(-z)^x}{xa^x}[/tex]?
Thanks, in advance!
It's not clear to me what the various symbols mean. What is ##\rho_0##? What is ##z##? How are they related to the series and ##x##?
Most of the tests you have for convergence apply to positive or non-negative series. You don't have that here, do you? Or do you?
Lengalicious said:
Series:
Thanks, in advance!
I think you should figure out what the radius of convergence ##\rho_0## of the given series is first. The ratio test should work nicely. Then substitute and simplify.
Sorry for being unclear, I found the radius of convergence to be [tex]\rho_o=|a|[/tex] using the ratio test, forgot to include that in the opening post. I am unclear as to how I am supposed to figure the behaviour based on this information, the question literally gets me to find the radius of convergence from the series I mentioned and figure the behaviour of the series when [tex]z=-\rho_o[/tex]. I have added an image attachment of the question to clear things up hopefully.
Lengalicious said:
Sorry for being unclear, I found the radius of convergence to be [tex]rho_o=|a|[/tex] using the ratio test, forgot to include that in the opening post. I am unclear as to how I am supposed to figure the behaviour based on this information, the question literally gets me to find the radius of convergence from the series I mentioned and figure the behaviour of the series when [tex]z=-\rho[\tex]. I have added an image attachment of the question to clear things up hopefully.[/tex]
[tex] <br /> I THINK they want you to substitute -|a| for x in the series and determine convergence of the resulting series. The result will depend on whether you take 'a' to positive or negative. But the series will simplify a lot in either case. Actually since you posted the original problem, it's safe to assume 'a' is positive.[/tex]
Yeah, that was my initial thought, just confuses me why the question uses z.. ooh well thanks I can actually get somewhere if I sub a in.
Lengalicious said:
Sorry for being unclear, I found the radius of convergence to be [tex]\rho_o=|a|[/tex] using the ratio test, forgot to include that in the opening post. I am unclear as to how I am supposed to figure the behaviour based on this information, the question literally gets me to find the radius of convergence from the series I mentioned and figure the behaviour of the series when [tex]z=-\rho[\tex]. I have added an image attachment of the question to clear things up hopefully.[/tex]
[tex] <br /> You can look at the two series obtained by setting x = a and x = -a (both of which have |x|=a---assuming a > 0).[/tex]
The use of z instead of x is probably a typo. I'd ignore it. And your series is not complete. It should have an n=0 term. What is it?
Thanks guys!
