Bell shrinking due to water pressure
13 replies · 3K views · last reply
semc
A bell of diameter 3m and bulk modulus of 14x1010N/m2 is toss into the ocean. By how much did the diameter decrease as it sank to a depth of 10km? The bell is assumed to be a sphere of diameter 3m.
Well o what i did was to calculate the pressure at the depth of 10km so P=Po+[tex]\rho[/tex]gh which gives me P=1.0135x105+1000x9.81x10000=9.82x107. Then Bulk modulus=[tex]\frac{P}{V/Vi}[/tex] where V is change in volume and Vi is the initial volume. This gives me change in diameter to be 0.267m however the answer provided is 0.722mm :cry: What is wrong ??
Hello rl! My working is in the post? Okie i guess my post is too messy haha sorry about that.
Okie here is what i didFirst i calculate the pressure at the depth of 10 km including the atmospheric pressure Po which is taken to be 1.013x105 Pa.
P=Po + [tex]\rho[/tex]gh
P=1.013x105 + 1000 x 9.81 x 10000 = 9.82 x 107 Pa
So using the formula of bulk modulas,
Bulk modulas = [tex]\frac{P}{V/Vi}[/tex]
14x1010=[tex]\frac{P}{V/Vi}[/tex]
Since formula for both volume are the same V/Vi is reduced to r3/ri3 where r is the change in radius and ri is the initial radius.
Using 14x1010=[tex]\frac{P}{V/Vi}[/tex] and the P i found previously, i got the change in radius which is r to be 0.267m
Yup basically that's how i did it :biggrin:
Vi = 4/3*π*R^3
V' = 4/3*π*( R - ΔR )^3
V/Vi = (Vi - V')/Vi = [R^3 - (R-ΔR)^3]/R^3
Expand the brackets and simplify to find V/Vi.
I don't get it. If we are looking for the change in radius why i can't just find the change in volume and from there calculate the change in diameter?
Find the difference in original volume and compressed volume.
Change in volume = Bulk modulus*Pressure* Original volume.
I am assuming you meant Change in volume = Bulk modulus*Pressure*Original volume? How did you get this? From my working I get Change in volume =[tex]\frac{Pressure x Original volume}{Bulk Modulus}[/tex] ??
Yes. You are right. It is typo.
So you mean that's the way to do it? But my answer is different from the answer provided
I am afraid i don't get you, this is my calculation and i can't figure out what's wrong with this and why do you keep asking me to post this?
[tex]\Delta[/tex]r3=[tex]\frac{9.82*10^7*1.5^3}{140*10^9}[/tex]
[tex]\Delta[/tex]r=0.1333m [tex]\Rightarrow[/tex] [tex]\Delta[/tex]d=0.2666m
Sorry. Your calculation is not correct.
Vi = 4/3π*r^3
Vf = 4/3π*(r - Δr)^3
Chane in volume =ΔV = Vi - Vf = ...?
Then ΔV = P*Vi/B gives you Δr.
ΔV = Vi - Vf
Δr = ri3-rf3
ΔV = P*Vi/B
Vi - Vf = (P/B)*Vi
[tex]\frac{4}{3}[/tex][tex]\Pi[/tex](ri3-rf3)=(P/B)[tex]\frac{4}{3}[/tex][tex]\Pi[/tex]ri3
(ri3-rf3)=(P/B)[/tex]ri3
Δr3 = (P/B)ri3
Δr3 = [tex] \frac{9.82*10^7*1.5^3}{140*10^9}[/tex]
Δr = 0.133 [tex] \Rightarrow[/tex] Δd=0.266
Whats wrong in my calculation?
Δr = (ri - rf)
Δr^3 is not equal to ri^3 - rf^3
In algebra
(a^3 - b^3) = (a - b)(a^2 + ab + b^2)
