Bell's Spaceship Paradox and Length Contraction
137 replies · 24K views
nosepot said:
From a relativity viewpoint your answer was fine. You're correct of course, if theories are consistent, then it's down to whatever sits right with you. I've always felt dismissing a medium which light (a wave) propagates in, to explain a phenomenon, when the medium can be retained and still explain the same and yet pose more tasty questions is the path I'd choose.
You can "believe" in the ether all you like. THe problem comes in when you start thinking you can actually detect it, just because you "belive in it".
People believed in the Ether for a long time. However, when it came time to conduct experiments, the expected effects due to the supposed "ether" just were not there. For instance, the Michelson Morley experiments.
As long as you don't confuse your "belief" with what the evidence is, you are fine. But almost invariably, people who "believe" in the ether believe it must be detectable (just because they believe in it - how can you believe in something when you can never actually detect it?). And this is where they run into problems with relativity, which predicts that the ether can *never* be observed.
If we did have an observation that DID detect the ether. we'd have to throw out relativity. So far, nobody has made such an observation, though - at least not one that is repeatable. (You might find an occasoinal person who claims to have made such observations, but when people try to verify it and reproduce the result, it turns out not to be the case).
Of course, if you're a "true beliver", none of this matters. You believe what you like, regardless of what the evidence says :-(.
nosepot said:
Can someone please clarify for me whether length contraction in special relativity is considered a physical effect (a contraction of a cohesive material) or a kinematic effect (applied to the space the material occupies)? I've been thinking about Bell's Spaceship Paradox this week and realized that it stems from a discrepancy between these two different viewpoints.
Any ideas? Thanks.
I read a few of your replies and think I see what you're asking.
-physical effect (a contraction of a cohesive material)
or
-kinematic effect (applied to the space the material occupies)
from just that; according to how you've put it, it's a kinematic effect. I'd prefer geometric, but saying "applied to the space the "material" occupies" seems the same-ish.
Wow PeterDonis I hope you teach beyond this forum, anything less is a disservice :smile:
nosepot said:
I'm sure SR accounts very well for most experimental observations (time dilations and mass increase), but I'm not sure that such an observation of length contraction has ever been made (?), and if so, I expect we would be left with the question I'm asking: "Why are the atoms bunching up like that? Isn't that weird!".
They are bunching up like that to maintain the constancy of mechanical physics. If they don't bunch up then there's a problem! Then it'd be weird! :-p
This constancy of mechanical physics goes well beyond the "constancy" you've become accustomed to with length & time. Specifically not "experiencing" these relativistic effects so clearly as described in this particular scenario/
PeterDonis said:
there is a measurable force exerted by the string on each rocket; in the original one, there wasn't. This is an obvious measurable difference and there's nothing mysterious about it at all.
Ok, good. So agree the string is contracting. If it is applying a force to the ships, which would otherwise maintain their distance, then it by definition is contacting.
PeterDonis said:
But the material of the string does *not* contract! Read my previous posts again, carefully. The length of the string in your chosen frame remains constant; there is no contraction of the string in this frame.
Oh dear. Now it doesn't contract. I think we need to clarify that the string is contacting in the frame which is not moving.
Let's reconcile all the examples we've visited so far and set up three experiments side by side to demonstrate different aspects of what's happening; each experiment contains a pair of rockets; so there are now six rockets. In Experiment 1 there is no string between the rockets. In Experiment 2 there is a very weak string joining them. In Experiment 3 there is a strong string. 3, 2, 1... Go!
The ships in Experiment 1 remain separated by a distance, say L. In Experiment 2, the string attempts to contract, but snaps; this conclusion could also be arrived at by changing to the rest frame of the rockets, and by the relativity of simultaneity, one rocket starts first and the other later, but the string's length is unchanged, hence *snap*. In Experiment 3, the strong string contracts and draws the ships closer.
The contraction effects are very real, as I now have two ships spaced a distance L apart, two with half of a broken string attached to each, and two more which have been drawn closer by the contracting string (and not the contracting space, as demonstrated by Experiment 1). Spacetime diagrams use the relativity of simultaneity to explain why the sequence of events would make sense for any observer in any frame, but spacetime diagrams depend on an actual object's length changing, for real, in that particular frame as the object gathers speed.
If you still can't see this contraction is real, imagine that we set up a Michelson-Morely like experiment using mirrors, etc, on three spaceships arranged to make an interferometer, and strings connecting ships to serve as the arms of this interferometer. If the strings don't contract in the direction of movement, I will obeserve the crew of the ship detect their speed relative to me by a shift in the interference pattern (in other words, they observe the speed of light for them is not isotropic); however, one string contracts drawing one ship/mirror closer and they get a null result. By the relativity of simultaneity we would disagree on when each beam reached each milestone along an interferometer arm, but we don't care about that as we are asking about whether the length contraction is real.
If we can't agree that the string contracts then I guess the discussion is reaching an impass. If we can agree, then why would the atoms of a moving object *appear* squashed together in my frame of reference? Relativity says there is no "why", it just is - this is a kinematic approach. Another philosophy would say that something about how interatomic forces work when the object gather speed must be causing it to happen - this is a dynamical approach.
I concede both seem equally valid, as any working theory would be, but the former leaves me feeling as empty as an etherless vacuum.
I agree. I'm ok with the notion that it may not be detectable, but it seems to leave fewer questions (for me!) than banishing it. Two obvious ones are: (1) What we have been discussing here about why length contraction is happening for an observer in some frame watching an object magically squish up?; (2) if light is an electromagnetic wave, what's doing the waving and what defines its speed?
Also, from a pedagogical viewpoint it would probably be more straight forward to teach. Most paradoxes which are raised in SR would be more easily explained using an ether and finite speed of light to explain length contraction. Bell's Paradox and the Twin Paradox would be more easily resolved. (Although, I've never seen a satisfactory answer to the Twin Paradox, and usually some double-think about the acceleration effects at the turnaround point, but that's another can of worms! :D )
Just a nitpick. Lorentz contraction is a disagreement between different reference frames about the length of something at a particular time. It is NOT a change in length at two different points in time. In Bells paradox it is a misnomer to call the change in length before and after the acceleration "length contraction".
Before the acceleration different frames disagree about the length of the string, that is length contraction. After the acceleration different frames disagree about the length of the string, that is also length contraction. In a single frame the length of the string may be different before vs after acceleration, this is NOT length contraction.
Yes, I understand what you are saying and agree. Once everybody is at their respective relative speeds, I think SR defines "length contraction" as what these apparent lengths are to each frame.
I think this is being confused (I'm to blame, I guess, for my choice of wording) with an actual length contraction. I should change my nomenclature to say "squishing" perhaps. This squishing causes the weak string to break, the strong string to pull the ships together. The squishing is required so that when everybody gets to their steady state speeds the speed of light in their frame appears to be the same in all directions... So what would appear to cause this squishing for my stationary observer?
Acceleration is a factor as it is required to get the object up to speed, but once the acceleration is removed, the object holds its squished state. Why?
The movement and shape of an object depends entirely on its initial state and the forces on each part of the object. Just like in Newtonian mechanics. It only maintains its "squished" state if that is how the forces act on it. If different forces are applied then it could just as well be stretched, or bent, or broken.
If Newtonian mechanics would explain the squishing of the object we would not be having this discussion. I don't think Newtonian mechanics would cause it to be squished into a single plane when it approaches the speed of light. We are asking the question of how materials are actually squished (and can break, as in the case of Bell's paradox), due to the change in the shape of their interatomic fields perhaps, when they increase their speed.
Given that the material is actually squishing along the direction of movement, then we would be forced to reconsider the null result of a Michelson-Morely-type experiment, as the poor guys didn't stand a chance if their inteferometer arms contracted. So sad.
In this *different* scenario, the string behaves differently. I'll defer the question of whether "contracting" is a good description of its behavior in this different scenario, because, as I said, I don't want to talk about that scenario because we haven't even gotten clear about your original scenario, which is simpler. All of my criticisms of the word "contracting" are directed at your original scenario, in which the distance between the ships, in your chosen frame, remains constant.
Oh dear. You can't even keep your own scenarios straight. :rolleyes: Please read the above and re-read my posts more carefully. You are mixing up different scenarios. No wonder you're confused.
We haven't even got your original scenario straight, and now you want to add a *third* one to the second one you already added that I said I didn't want to talk about? Sorry, I'm not playing. If you don't want to stick to the original scenario, I'll just bow out of the thread.
This is why I don't like multiplying scenarios; you can't even keep straight which one we are talking about, and you're the one who specified the scenarios. Once again, if you can't stick to your original scenario--two ships, keeping constant distance apart in your chosen frame, with a weak string between them that eventually snaps due to increasing tension--then I can't really add anything more to this discussion.
As I have pointed out repeatedly, it isn't.
Consider, once again, your original scenario: two ships maintaining a constant distance apart in your chosen frame, and a weak string between them that gets stretched more and more until it breaks.
In your chosen frame, the length of the string is constant. The lengths of the *ships* contract.
However, the string is the object that is subjected to increasing tension, until it breaks. The internal stresses of the ships remain constant.
So: the ships are undergoing length contraction in your chosen frame (btw, you also seem to be ignoring the fact that length contraction is frame-dependent), but they are certainly not being "squished": their internal stresses remain constant. The string is *not* undergoing length contraction in your chosen frame, but it *is* experiencing increasing internal stress--but the stress is *stretching*, not compression.
In short, you appear to have a mistaken view of what is going on: you keep on describing things as "contraction" that don't appear to fit that term at all.
nosepot said:
We are asking the question of how materials are actually squished ... due to the change in the shape of their interatomic fields perhaps, when they increase their speed.
I think your question was answered in post #27.
The first sentence is true, but not the second. Lorentz's theorem of corresponding states is, in a sense, the whole reason for the physical significance of systems of coordinates related by Lorentz transformations. The equilibrium configuration of a solid object, originally at rest in one standard system of inertial coordinates, when set into motion and allowed to reach equilibrium in another system of standard inertial coordinates, is found to be spatially contracted in terms of the original coordinates. Of course, in terms of the second system of coordinates the object was spatially contracted in its original state. The fact that the two things you mentioned BOTH represent length contraction is crucial for understanding special relativity.
I agree. I have been mixing terminologies. Length contraction as you know it is an apparent shortening in length when objects in different frames are moving relative to each other - transforming between frames on a spacetime diagram demonstrates this, but this is only an illusion because of the relativity of simultaneity. This is a consequence of attempting to measure the length.
We are now talking about "squishing", which is what happens to the object when it increases its speed. This is the inexplicable attraction of worldlines for an extended object on a spacetime diagram. This is not an illusion, as we know the string will break.
The stress comes from the spaceships resisting the string's attempt to squish. It's squishing, for sure.
Samshorn, you said the answer is in here somewhere:
Samshorn said:
It's because what you "know to be the laws of physics" is wrong. This was already known before special relativity came along. Lorentz had already shown by 1904 that the laws of physics (i.e., Maxwell's equations, the Lorentz force law, etc) imply that the equilibrium configuration of an object in motion is shortened in the direction of motion. In other words, if you have a "solid" object initially at rest and equilibrium in terms of one standard system of inertial coordinates, and then you impart some speed to the object (gently enough to avoid inducing any permanent plastic deformation) and allow it to reach equilibrium again at rest in some new standard system of inertial coordinates, it's spatial length in terms of the original system of coordinates is reduced. What Lorentz didn't clearly notice or articulate (but Einstein did a year later) is that the object in its original state was shorter by exactly the same amount in terms of the second system of coordinates.
I'm not sure I follow 'what you "know to be the laws of physics" is wrong'. Relativity expressly states that the laws of physics are to be the same for everyone in an inertial frame, but also that the speed of light is isotropic in that frame, everything else is a consequence of those postulates. If what we know to be the laws of physics (such as how atoms arrange themselves in a material included) is different, relativity is not doing its job.
You say, "Lorentz had already shown by 1904 that the laws of physics (i.e., Maxwell's equations, the Lorentz force law, etc) imply that the equilibrium configuration of an object in motion is shortened in the direction of motion.". I'm not sure your view would be accepted by many, although I would be inclined to agree with this, and this would make a satisfactory answer for me.
"What Lorentz didn't clearly notice or articulate (but Einstein did a year later) is that the object in its original state was shorter by exactly the same amount in terms of the second system of coordinates". True, but this is illusory, due to the relativity of simultaneity - this is very elegantly demonstrated on a spacetime diagram.
By the way, I've accepted several times above, that the SR explanation works, but it has holes. The one I'm poking my finger through at the moment is that it ignores the reality and mechanisms of how matter is arranged. It no better explaines beautful hyperbolic worldlines of the Rindler coordinates than to say, they must be so if the length must squish. When I look at that string squishing up, and in the case of Bell's Spaceship Paradox it breaks, it should be explainable by looking at relative speed of the string and the laws of physics holding the atoms of the string together in my frame.
There's a really nice explanation of a similar phenomenon when considering the barn-pole paradox, with the pole suddenly arrested inside the barn using a very sticky plank of wood:
http://arxiv.org/abs/0712.3891
The pole remains under immense squishing after being stopped in the frame of the barn. The author also explains how the relativity of simultaneity would explain the sequence of events from both frames, such that both disagree about how it happened, but both ultimately end up staring up at an exotically compressed pole, wondering why all those atoms managed to get so squished up when it was moving at speed.
The multiple scenarios are interjected to remove the urge to seek refuge in any of the usual places. They demonstrate that it's not resolved by a change of frame, nor by considering time dilation, nor relativity of simultaneity, nor by thinking that the space in between is squishing. After all are eliminated, we realize the string is really squishing and if not strong enough will break. It is a string made of atoms which are bound together. Moving at speed seems to make them bind together more closely. Relativity says, so it must be so the speed of light remains isotropic in any frame. The unexpected consequence is that real materials must somehow obey this prinicple. I'm asking how do they obey?
Excellent. Then we're done! (If you encounter anyone who doesn't think that's what Lorentz's 1904 shows, then just refer them to the paper. It isn't a controversial point.)
True but illusory? It is certainly true in the sense that it is a verifiable statement of fact with perfectly well defined operational meaning. One can choose to call any such empirical fact "illusory" if one is inclined to give precedence to some operationally baseless metaphysical notions, but that isn't what physics is about.
Above you said the facts about equilibrium configuations under the laws of classical electrodynamics "make a satisfactory answer" for you... but now you say there are "holes". This seems contradictory. Also, I would say those "holes" are not in evidence. Nothing you've said gives any indication of any "holes" in how the explanations of special relativity work.
Huh? I just explained (and you agreed) that the classical laws of electrodynamics do this, as Lorentz was the first to show in detail. And this is entirely consistent with special relativity - indeed it is the foundation of special relativity. Why are you back-sliding now? Is it just because you can find people on this message board who don't understand this, and you enjoy trolling them?
Sweet. I'm not sure it's as uncontroversial as you state. It certainly seems to be misunderstood. If you look at the Wiki page for Bell's Spaceship Paradox (no authority, I know) it's a dog's breakfast. The explanation for the string breaking by is not complete as it only considers events in the rest frame of the co-moving spaceships, the list of papers disputing whether the string even breaks at all is as long as your arm, and the "Talk" page looks like a battlefield.
Apologies. That point addresses what appears to be the view of other people, but not yours.
I'm not trying to troll (too much), and my original question was sincere. I'm trying understand why these paradoxes exist and persist (barn-pole and Ehrenfest paradoxes also rest on the dynamics effects within materials), and part of that is seeking a viewpoint from others who may have considered what I have not. The general consensus seems to be that there is no electrodynamic effect causing my length squishing, which you and I disagree with.
All that said, I'm still not clear why an ether theory was abandoned, just because it was considered to be immeasureable? It appears useful on a number of levels.
nosepot said:
jartsa: So you are saying it's related to the interatomic distances being compressed because of the acceleration?
No, I was saying it's related to the time schedule of delivery of kinetic energy to various parts of an object.
Let's consider an uniformly charged non-conducting human observer "falling" in a homogeneous electric field. The length axis of the observer is parallel to the electric field lines.
This observer feels his tendons are resisting some force that is trying to stretch him. And an "outside observer" says the person is contracting.
____________________________________________________________________Now let's consider an observer falling in a homogeneous gravity field. The length axis of the observer is vertical.
This observer does not feel any force that is trying to stretch him. But still an "outside observer" says the person is contracting.
Why the difference? Well let's see ... gravitational time dilation has an effect on the time schedule of the delivery of kinetic energy to various parts of a falling object.
Sorry, I was unclear. The equation which relates force to acceleration is different in SR than in Newtonian mechanics, but the concept is the same:
In both, the shape and movement of any object is entirely determined by the initial position and velocity of each part and the forces on each part. That is what I meant.
The answer is that in Bells paradox the string snaps because it is placed in tension. The formula for determining if something is placed in tension is the one PeterDonis linked to earlier. Conceptually, this is no different than in Newtonian mechanics, if you make a scenario in Newtonian mechanics where an inelastic string is placed in tension then it will snap.
The only difference is the formula which is used. Bells paradox merely hilights that the Newtonian equation must be wrong.
It is not inexplicable. It comes directly out of the equation that relates force to acceleration, which is somewhat different from the Newtonian equation.
nosepot said:
Thank you all for your answers. It's been fun and educational. This is a great forum - keep it up.
For anybody still watching, there is a very interesting paper I found which describes very well what I've fumbled to express:
http://philsci-archive.pitt.edu/987/1/Michelson.pdf
Thanks for providing the link to that paper. It was very interesting and informative.
However, since you claim that it describes very well what you've fumbled to express, then you should know that it describes very well what all the rest of us have clearly expressed, as you can read in the Final remarks, Einstein didn't err, he just provided a simpler approach than "the messier, less economical reasoning" that you want to take. And it's not that "the messier, less economical reasoning" cannot also be handled by Einstein's Special Relativity, it can, you just have to specify an incredibly more complex scenario. You can't just say that the string is inelastic or the spaceship is rigid, because, as I have stated earlier, the slightest acceleration of any part of those objects will instantly break or crush them. And until you are willing to recognize this as a problem with all the scenarios that you have presented, you are going to continue to think that you have an understanding that the rest of us are lacking, despite your ability to express your ideas.
Harvey Brown has made a career out of writing articles for philosophical magazines advocating the Lorentzian interpretation of special relativity. In the end, his arguments are all based on a misunderstanding of special relativity - a misunderstanding that was unfortunately encouraged by some misleading features of Einstein's 1905 paper (such as mislabeling the first section "The Kinematic Part" when the very first sentence places it squarely in the realm of dynamics). But Harvey's biggest problem (coincidentally the same as nosepot's) is that he mistakenly thinks if the laws of physics, expressed in terms of one system of coordinates S1, predict that physical phenomena will behave in a way (contracting, slowing, etc) that ensures they will satisfy the same formal laws in terms of a relatively moving system of coordinates S2 with a different simultaneity, then (so Harvey and nosepot contend) this proves that the S1 coordinates are the true coordinates and S2 are just mathematical artifacts. The obvious flaw in this reasoning is that it applies equally well to S2 as the true coordinates and S1 as mathematical artifacts. Lorentz himself credited Einstein with pointing out this "remarkable reciprocity", which reveals Lorentz invariance as a fundamental symmetry of nature, and makes it meaningless to argue for the primacy of S1 or S2 - at least in terms of the local physics. Neo-Lorentzians habitually conflate the possibility of a Lorentzian interpretation with its necessity or physical meaningfulness.
And none of this is what I've been talking about. I've been talking about invariants, like the observed internal stresses in an object.
Only it doesn't. As I've repeatedly said, the spaceships themselves have unchanging internal stresses, even though their measured length shortens in your chosen frame. So whatever is happening to them, they are not being "squished". If they were, they would show increasing internal stresses, and they don't.
No, the stress comes from the spaceships pulling on the string. If there were "squishing" going on, as I have repeatedly said, you would see evidence of it in the spaceships themselves, since there is nothing preventing them from squishing.
None of which I have attempted to take refuge in. You are not responding to what I'm saying. What I'm saying is that your model of what's going on doesn't explain what you claim it explains. I have repeatedly said why: if your model was really the explanation, you would expect the spaceships to experience increasing internal stresses. They don't. Can you address that point?
You left out a key qualifier: shortened in the direction of motion with reference to the original coordinates. The phenomenon you are talking about is frame-dependent, and Lorentz never claimed otherwise.
I accept it; I just don't agree that it means what you think it means. You are taking a frame-dependent phenomenon, the length of an object, and trying to relate it to a frame-independent, invariant phenomenon, the observed internal stresses of an object. That's not a fruitful procedure. If you want to understand the frame-independent internal stresses of an object, you need to relate them to a frame-independent feature of their motion: in this case, the expansion scalar.
PeterDonis: The entire point of this exercise was to understand how things would look to the original reference frame, and not from a frame independent perspective, and only Samshorn and yossell could confirm my intuition that the material would actually appear to contract, and Samshorn the only to state it was due to the electrodynamics of the atomic bonds.
I must admit, once I separated in my mind that "length contraction" is two different phenomenon (the squishing caused by reshaping of moving atomic fields as the object accelerates, and the apparent shortening of moving objects due to relativity of simultaneity) the whole thing becomes much clearer. And I agree, the symmetry is absurdly strange.
When I was schooled in SR, we only dealt with two frames of reference moving at a steady state relative to each other; which means we only touched on relativity of simultaneity. No mention of how why materials would contract when accelerated was ever made to us. As Samshorn says, an understanding of both is needed. I'm not sure many textbooks deal with both? Or maybe I had a garbagety physics lecturer! Perhaps that's why the ether is so hard to let go.
For me there is something easier to grasp when explaining these concepts with an ether, and there will always be the question of "what's doing the waving?", which would also add to the reluctance of an neo-Lorentizan to down tools.
That is, in my opinion, the most important message in the whole thread.
There is no need to "down tools" as long as you realize that your tools are not necessary and that there are other tools in the toolbox. I personally prefer the "block universe tool" because it makes identifying the invariants much easier as well as making the leap to GR easier. However, I still break out my "aether tool" to do Doppler problems. I think it is best to learn all of the tools and use the best one for the job at hand.
