Bell's theorem proof. Does it really proofs anything?
93 replies · 18K views · last reply
@0xDEAD BEEF
Maybe unfair to leave in an "outburst" like that... :blushing: you did ask me a specific question...
The "catch" (that your predefined photon polarization will never ever work), is because the relative angle between Alice & Bob can be anything between 0-360, but "your" photons doesn’t care one bit about this relative angle. The only thing that they will "respond" to is their own polarization and the setting of their own polarizer.
I.e. there is no "communication" or "link" between Alice & Bob in your "design", and this is crucial.
Don’t ask what this "communication" or "link" really is and how this works – no one knows.
There are two main "explanations" for this paradox. One is the so called non-locality, meaning some sort of "communication" between Alice & Bob is present (that we don’t know what it is). The other is non-separability, which means that the physical reality is not what we think; one object can be at two places at once, or something like that (I think it involves holism as well).
This is why I won’t get into details in your program; I know it will never work they way you hope. Yes, it’s "cocky and rough", but it’s the truth. You will win some substantial time if you first study the problem in detail, to learn everything, and then try to build something on your own. Just by guessing, you will not get anywhere.
Good luck & Take care!
0xDEAD BEEF said:
Ha ha! (irony, but maybe not).
So, how i see this-
Anna got polarization filter and Bob has. Standart setup.
What if we further extend this setup, so that Anna has 3 polarization filters all set at same angle...
If they are all set the same way, you can pretty well predict the results. Same all around, as any polarized photon can be sent through a series of similarly oriented splitters and nothing changes.
It would be helpful if you would ask a specific question. You are wandering all over the place and it seems as you ignore the rules I keep trying to explain. There is difference between entangled photons (emerging from a PDC crystal) and a pair of photons of known and identical polarization, such as emerge directly from a laser beam. You should learn this difference first, and understand their statistics.
0xDEAD BEEF said:
as i said, i would use black-box, so, whatever "polarization axis of respective polarizer" is, i can no know that! So - what output would i get?
I suppose that you mean you don't know polarization axis of photons (and they have different polarizations) not polarizers i.e. black-box is source not measurement equipment.
If that is so then you will have classical output like that:
N(a,b)=1/4+1/2*cos^2(a-b)
If we want to look at real life example we can take PDC source without walkoff compensators.
In that case we have only H and V polarized non-entangled photons. And result is like this:
N(a,b)=1/2*cos^2(a)*cos^2(b)+1/2*sin^2(a)*sin^2(b)
What is PDC source with with walkoff compensators?
Yes - my black box device would be photon source which would output two photons to Anna and Bob. These two photons would have same polarization (photon a polarization == photon b polarization), but those polarizations would change on random (photon a == photon b == random value).
Beef
So QM states, that particle can have only one "property" at time?
For example - i send p (particle) through 0 angle polarizer. It goes either up or down and now it has its 0 angle property set to up or down. Then (p) travels through another polarizer, this time set at 90 angle, so particle now forgets? its 0 angle and decides either to go up or down at 90 angle. And now if i send this particle through 0 angle polarizer again, then it could choose different direction to go this time, because previously it was measured against 90 angle detector?
Example:p --> (0) -- up/down --> (90) -- up/down --> (0) -- same as first time or different? --> (detector).
EDIT:
What i am aiming at is:
a) photons have some invisible quantum bound between them.
In such case (time line):
Alisa measures photon polarization at angle 0
Bob measures twin-photon polarization at angle 90
Alisa again measures photon polarization at angle 0, but gets different result, since Bob's measurement on his photon has made Alisa's photon to "forget" it's 0 angle polarization value.
Result - faster than light information exchange.
Setup (Alisa) -
Code:
BOB0  \
        p(0) \
BOB90 /
                p(0) <----- photon
BOB90 \
        p(0) /
BOB0  /
where BOB90 has 50% chance of firing, if Bob's polarizer is set at 90 degrees and 0% percent chance, when Bob's polarizer is at 0 degrees.
b) we are just measuring different properties of photon.
Bob measures photon polarization at angle 90
Alisa measures photon polarization at angle 90
Bob measures photon polarization at angle 0
-- Bob's and Alisa's all 4 measurements match, so there is actually no reason to have Bob at all and Alisa could have measured photon both on 0 and 90 angle bu her self.
Setup would be -
Code:
D0+90+ \
        p(90) \
D0+90- /
                p(0) <----- photon
D0-90+ \
        p(90) /
D0-90- /
So - if Alisa's D0+90- fires, that means, that photon had 0+ polarization and 90-.
If we have Bob in this scenario, then D0+90- or D0-90- should fire, when Bobs (90 angle) - fires and vice versa.
EDIT2:
I guess, there is also c) option.
c) Alisa can measure photon's polarization at one angle (and that is it), and Bob can also do so, so they both can measure different polarization values of "same" photon, which is cool, since we get more information about that photon, but that is it .
EDIT3:
There might also be option d).
Alisa measures her photon at 0 angle, so Bob's photon now can not be longer measured against 90 angle and vice versa.
Twin-photon hits Bob's polarizer always first.
In this case Alisa could have multiple detector chain
Code:
BOB0  \
        p(0) \
BOB1 /
                p(0) <----- photon   ------> p(0/90)
BOB1 \
        p(0) /
BOB0  /
so - if Bob DOES NOT measure his twin-photon polarization angle at 90, then Alisa always gets BOB0. If, however, Bob does measure his twin-photon's polarization before Alisa's photon enters Alisa's first polarizer p(0), then Alisa's photon starts giving random data when measured against p(0), so it should start hitting BOB1 detectors. In this case we would again clearly see at Alisa's end, that Bob has measured his photon (at 90) or has not, thus, we could make conclusion about Bob's setup -> faster than light information exchange.
So is it a), b), c) or d) ?Beef
It is usual source of polarization entangle photons.
Then I understood you correctly and my answers hold.
Example:
Different
Only if you talk about photons and polarizers then it's 0° and 45° not 0° and 90°. Photons that pass 0° polarizer are completely blocked by 90° polarizer.
No
No, because after first measurement photons are not entangled any more.
0xDEAD BEEF said:
c) Alisa can measure photon's polarization at one angle (and that is it), and Bob can also do so, so they both can measure different polarization values of "same" photon, which is cool, since we get more information about that photon, but that is it.
I would rather say no. It's not photon that behaves the same way. It's the wavefunction that behaves the same way. So you don't get more information about the "same" photon.
And you always get BOB0 irrespective of Bob's measurement.
So you are saying, that after first measurement photons are not entangled any more. If so - does it matter at all that they were entangled from very beginning.
Or maybe i am just getting this wrong, but - does entanglement gives any other extra properties to photons than just that they have all same properties?
In this experiment they use that crystal to create entangled photons with same polarization and send them to Alisa and Bob. Why would it make any difference if i replace "twin-photon crystal" with "black box", which also outputs same photons, only with difference, that they are "manually created" (two "light bulbs" and bunch of polarization filters) .
Apparently it matters. After first measurement they are not entangled but they are correlated nevertheless i.e. if you detect them results are correlated.
Well maybe it's better to take it as speculation but anyways I would say that entanglement is specific correlation of photon phase not only for paired photons but for whole ensemble.
In your "black box" setup you can't control phase of created photons.
Well, this is not an ensemble of personal speculations; it’s the current professional mainstream scientific view.
Trust me, or http://www.phy.mtu.edu/faculty/Nemiroff.html" :
https://www.youtube.com/watch?v=
<object width="640" height="505">
<param name="movie" value="http://www.youtube.com/v/KJhSP2zAfiI&fs=1&amp;hl=en_US&amp;rel=0&amp;color1=0x402061&amp;color2=0x9461ca"></param>
<param name="allowFullScreen" value="true"></param>
<param name="allowscriptaccess" value="always"></param>
<embed src="http://www.youtube.com/v/KJhSP2zAfiI&fs=1&amp;hl=en_US&amp;rel=0&amp;color1=0x402061&amp;color2=0x9461ca" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="505"></embed>
</object>
<param name="movie" value="http://www.youtube.com/v/tAwnR89rp3I&fs=1&amp;hl=en_US&amp;rel=0&amp;color1=0x402061&amp;color2=0x9461ca"></param>
<embed src="http://www.youtube.com/v/tAwnR89rp3I&fs=1&amp;hl=en_US&amp;rel=0&amp;color1=0x402061&amp;color2=0x9461ca" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="505"></embed>
</object>
There is a difference, and you can tell by an experiment. If you observe Alice and Bob at the same but *random* angles, the following pattern will emerge over a series of trials:
If Alice and Bob ARE entangled (PDC source), they will be 100% correlated.
If Alice and Bob are NOT entangled (black box source), they will be about 75% correlated.
Does that help? In both cases, the photon pairs are clones of each other in the sense that that have the same quantum properties. The difference is that entangled particles are in a superposition of states because the value of one or more of those quantum properties is not known. That leads to some rather unusual experimental situations as compared to particle pairs which are not in a superposition.
DrChinese
regarding -
But if i have blackbox, which outputs two photons (to Anna and Bob) having same polarization
Code:
+---------------- BLACKBOX -------------------|
|laser -> beam splitter -> polarizer for anna | -> anna's setup
|                      \-> polarizer for bob  | -> bob's setup
Should not hey both get 100% correlated, if "polarizer for anna" is set to same value as "polarizer for bob"?
Beef
P.S. I did not like that Dr. Robert Nemiroff stuff. It was too easy, too non chalenging. Too much facts, without proof/idea behind them. And I thought education quality is bad only at my country... :)
(Just a short temporary comeback ;)
Honestly 0xDEAD BEEF, I know communication can be hard sometimes, but it’s beyond my imagination why this doesn’t answer your question:
Why on Earth are you asking all this questions if everything is perfectly clear to you…??:confused:??
Because I want to understand, not to learn. (Edit: maybe also because i want to have chat with smart people... ;) )
Regarding relative angle between Bob and Alice - IN QM experiment increasing relative angle between Bob and Alice also increased mismatch rate. Same that would happen with "predefined photon polarization".
Say - i fire two photons with 0,0 angle polarization at Bob and Alice. Bob measures at 0 angle, so he gets 1, Alice measures at 90 angle so she gets 0. If she would measure at same 0 angle, then she would get same 1. Same would applie if i would fire my photons at differen angle (like 55). At 55 Bob would get 1, Alice 0. Still mismatch!
EDIT:
So here is what I don't like about this proof. And with don't like i mean - i don't understand it.
There are two entangled photons. Twin-photons. They are exactly same.
Now Bob and Anna does some measurements on them. That is cool. And i can not disagree with output of those measuremets, since they are what they are and what they tell us is something about those two photons being measured.
What I don't like (don't understand) is this non-locality stuff which somehow using just some "that should be so but is not so there is information exchange" functions is proven.
Furthermore - i don't understand - what is difference if these twin-photons "collapse" when hiting detector or collapse earlier.
I totally accept output of this experiment (data), but i don't understand, how one can conclude, that there was some information exchange between photons, when they hit detectors. To me it seems, that moment, when these photons exchanged information and became equal does not matter. Say - both photons where unknown about their state, but decided simulatenosly it, when hiting Anna's or Bob's detector. Or - both photons had their state known already prior this happening. What i think (can not understand) is that in both case experiment results should be the same. But if so - how can this experiment prove non-locality. I only see experiment measuring two photons. In fact - there should be many theories explaining this behavior. Maybe those photons carry only partial information, since they vere born from single photon and so they should not carry more information, that one, who created them (one hitting PDC crystal).
I really don't see, how one can conclude non-locality (instant information exchange) from this data. Yes - i see that A, B, C case and error stuff, but somehow i don't see, how it applies to this case. More over - we are dealing eith entangled photons not with ussual ones.
Sure, i am not going to discover America, but neither i am going to accept claim, that information "got" exhanged faster than light, when there is no actual evidence of that.
Say - if Anna would change her setting, and Bob would instantly start seeing more + at output, than 0 - one would say, that two photons have exchanged information. No doubt.
Only reason why i got interested in this experiment was because of it's loud announcment, that two particles stayed connected at 27km distance. Cool, right? So i checked internet and started actually searching for this experiment to get more information and understand, how could that happen.
But now all i see is that actualy i don't see particles excganging data. What i see is same particles from very beginning and I don't see "the reason" or "the catch" why should they change, when they got measured, if that should be similar to situation, where they did not exchange anything at all (maybe ar very begining). And btw - these two particles are born at middle of crystal, as i see that (402nm laser hits crystal and somwhere in crystal 901nm twin-particles are born). They still have to travel through that crystal to find exit. And crystal cerainly wants to know their polarization before it allows them to leve (they interact with crystal).
Beef
0xDEAD BEEF said:
DrChinese
regarding -
Code:
The answer is NO, and here is a specific example:
From your box emerges a pair of photons polarized at the same angle, which is 0 degrees. If I run each through a polarizering beam splitter set at 45 degrees, there is a 50% chance of a + and 50% of a -. But that applies independently to each. There are 4 permutations:
A correlation of 50%, not 100%. If you average at all angle settings (i.e. not just 45 degrees), you will actually get a 75% average.
If you did the same thing with polarization entangled photons, you would get 100% correlation. Regardless of the angle setting (as long as set the same for both Alice and Bob).
0xDEAD BEEF said:
EDIT:
Beef
This helps a lot to explain your view. I think I can answer a couple of things. There were 2 assumptions in the Bell derivation: a) no faster than light signaling; b) pre-existing values/formula/etc. for outcomes (since you have the perfect correlations). One of these assumptions MUST be wrong.
So take your pick. Then we are at the same place.
Very good! Now i really start to understand more! Thank you! :)
BUUUT! :)
But what I would like to say is, that -
if normal photon has angle x, then chance of it hitting detector with angle y is determined by formula - (x < y + 45) && (x > y - 45),
So should not it be so, that (simply) twin photon's chance is deterined by slighlty different formula since it is slightly "cooler" photon? Say
(x < y + 45 + "some value more likely to be 0, but can reach 90 as well") && (x > y - 45 - "same magic value")
Beef
Ahhh! This will definitely disqualify me; I’m not smart I just repeat what really smart people have written on the subject! :wink:
This is frustrating. :cry: We explain to you exactly how this works, and then you "forget" everything, and "act" as it never happened...
Check out https://www.physicsforums.com/showpost.php?p=3024599&postcount=28" and you see exactly what I mean.
This is my last sentence in this thread, guaranteed. Adios Amigo
I am thinking that my encouragement might help us both learn something: :smile:
BUT PLEASE NOTE that I am not a physicist; :blushing:; so where I am wrong, you and I will see where we are maybe both wrong together -- and so we would both learn something valuable together.
SO: I encourage you to work on understanding your good and simple experiment (that you have in mind, as I understand it). PS: If I misunderstand, then do what follows anyway, and soon.
Here's what you can learn from the model that you have in mind AS I SEE IT:
1. Your experiment is easily done USING a source of entanglement; even easier as a thought experiment: Simply sandwich an EPRB-Bell source (black-box) between two aligned and coupled polarizers which rotate, at random, but stepwise, in unison. This gives you your black-box source -- yours is just an EPRB-Bell black-box in a bigger black-box! That seems quite OK to me.
2. Then: Do your experiment in exactly the same setting as EPRB-Bell.
3. You will find the correlation to be exactly one-half of the EPRB-Bell correlation. So get someone to teach you the really simple mathematics of what is going on -- it's just old Malus' Law, twice.
4. The one-half reduction is explained by the fact that YOUR black-box [your sandwich] has REDUCED the correlation of the paired photons that are emitted from the inner -- EPRB-Bell -- black-box. That is:
5a. YOUR black-box is delivering paired-photons with a common polarization at some random orientation; that is all.
5b. BUT the EPRB-Bell black-box delivers magnificently paired photons whose total angular momentum is zero -- they are said to be "in the spherically symmetric singlet state". Get someone to explain that to you.
5c. SO in EPRB-Bell experiments with paired-photons (typically), each photon has its total angular momentum antiparallel to its twin. That is, for any common orientation whatsoever, over the whole of the ordinary 3-space of Euclid: If you measure the polarizations of EPRB-Bell twinned photons, they are ALWAYS the same. That is a fantastic degree of correlation!
PLEASE NOTE and understand: When you measure the polarizations of YOUR twinned photons, under the same conditions, i.e., for any common orientation whatsoever, or even just do this measurement over the 2-space orthogonal to the line-of-flight axis: They are NOT ALWAYS the same.
6. You can see, therefore, that your source delivers photon-twins with much less correlation; yet YOUR overall correlation result is pretty good, at exactly one-half of EPRB-Bell.
7. Then, in my opinion, after you really understand your model and experiment and its mathematics, you have your next experiment:
8. You remove the sandwiching polarizers; you see the that correlation doubles; you understand the much tighter correlation of the paired-photons (compared to those that came from your black-box); you join the club of convinced local realists, under a free trial membership; :wink:; you wait to be shown where you are wrong.
In the meantime, see if you can learn and understand the mathematics that yields the EPRB-Bell experimental results.
QED?
PS: You should ask someone to correct the title of your thread.
From -- Re: Bell's theorem proof. Does it really proofs anything?
To -- Re: Bell's theorem proof. Does it really prove anything?
Good luck! :!)
But the actual formula follows cos^2(theta), where theta=x-y for your example. Please notice that yours does not yield the same results. And it won't matter if one is "cooler" than the other (whatever that means) because when theta=0, there is perfect correlation.
DevilsAvocado said:
Mamma Mia :bugeye:
Just curious if that qualifies as a sentence.
Heh heh heh. :smile:
nope
no
period
and
only
two
words
that
looks
like
something
'italiano'
or
maybe
old
ABBA
on
acid
:smile:
Hmm. Ok, so i have "tuned" my program a bit and now i get more interesting results. Thought - i doubt that i have properly implemented photon physics in my program.
So - as i now understand it -
If those two photons would not be entangled twin-photons, then (for example), when Anna has her detector at 0 angle and Bob has his at 90, then photon flying in at 45 angle could cause Anna's detector to fire 0 and Bobs detector to fire 0, since now this photon has cos^2(45) probability hitting Anna's + sames as Bob's -, so some times this 45 degree photon should cause 0 for Anna and 0 for Bob, when they have 0 vs 90 degree setup, but since experiment shows, that Anna and Bob are always correlated at 0 angle delta and always 100% uncorrelated at 90 angle delta -> this proves that something strange is going on?
EDIT:
if that non-sense text was not clear, then here is another try to explain what i meant.
So, Anna has 0 setup, Bob has 90 setup. There is photon coming in at 45 degrees angle.
Sometimes we should se:
+- (more often)
-+ (more often)
But we see only:
So this is strange and proves non-locality. Right?
EDIT2:
Further more. (if mine understanding above was correct) -
Now one could start patching "theory" and try to come up with new formula, so, that photon has 100% probability going one way, if delta < 45. However soon one would discover, that no mater how hard he tries, but having photon always go up, when angle < 45, means, that it always goes down, when angle > 45, so cos^2(delta) formula can only be replaced with |delta| < 45. But if one does so and creates simulation, he sees, that correlations (mismatches) should form linear graph. But we see cos, so how is that possible?
Am i right?
Beef
0xDEAD BEEF said:
EDIT:
+- (more often)
-+ (more often)
But we see only:
Minor point. You don't see +- and -+ more often with photon polarization at 45°. According to your description you have sometimes photons with 45° polarization sometimes with 0° or 90° and sometimes another angle. So photons with 45° polarization will not contribute to correlation but photons with 0° or 90° will always contribute to correlation. When you sum up all angles it turns out that correlation is half of the maximum.
0xDEAD BEEF said:
EDIT2:
Am i right?
Yes, this is reasoning behind Bell theorem.
As a die hard local realist I would like to point out that other side of the story is experimental tests of theory that poses quite different questions.
What are key points how local-realism explains these experiments?
No! My configuration was different. It was - Bob 0, Alisa 90. Photons flying in sometimes have angle 45, so they sometimes must hit ++, --, +-, -+, BUT, we only get +- and -+.
BTW - thank you guys a lot! With every reply I grow smarter and smarter! :)
Beef
QM ! :smile:
DevilsAvocado said:
nope
no
period
and
only
two
words
that
looks
like
something
'italiano'
or
maybe
old
ABBA
on
acid
:smile:
You can put pepperoni on mine. And crank up some Steely Dan.
