Bernouli's Equation/Pressure Problem
  • Thread starter Thread starter alicemunro
The discussion centers on applying Bernoulli's Equation to determine the pressure difference between the inside and outside of a truck's tarpaulin while traveling at 27 m/s. The air density is given as 1.29 kg/m³. By substituting the known values into the equation, the pressure difference is calculated as 470 Pa, confirming that the pressure inside the cargo area exceeds the outside pressure by this amount. The solution effectively demonstrates the application of Bernoulli's principle in a real-world scenario involving fluid dynamics.
  • Understanding of Bernoulli's Equation
  • Knowledge of fluid dynamics principles
  • Familiarity with pressure calculations in physics
  • Basic algebra for solving equations
  • Study the derivation and applications of Bernoulli's Equation in various fluid dynamics scenarios
  • Explore the effects of varying air density on pressure calculations
  • Learn about the implications of fluid flow in different geometries
  • Investigate real-world applications of Bernoulli's principle in engineering
Students studying physics, particularly those focusing on fluid dynamics, engineers working with aerodynamics, and anyone interested in practical applications of Bernoulli's Equation in real-world scenarios.
alicemunro
Consider a truck with a tarpaulin on top of it. When the truck is stationary the tarpaulin lies flat, but it bulges outward when the truck is speeding down the highway. The truck is traveling at 27 m/s. The density of air is 1.29 kg/m^3. by how much does the pressure inside the cargo area beneath the tarpaulin exceed the outside pressure
bernoulis:
P(1) + 1/2pv^2 = P(2) + 1/2pv^2
i plugged in the density and but with two unknown pressures and one unknown velocity i don't know how you would find the difference
and i think the pgy's on either side of the equation cancel out because this is horizontal, so y=0.
I would consider the air inside the truck (under the tarpaulin) as stationary.
You can imagine the truck at rest and someone blowing some air on the outside.
When the truck is traveling at 27 m/s, the air above the tarpaulin is moving with the same velocity but in the opposite direction. The pressure inside this blowing air decreases. In side the tarpaulin air is at rest.
so if the air inside the tarpaulin can be considered stationary, you can use P(2) = P(1) + pgh. And the pgh would = 0, so the pressure inside would equal 1 x 10^5 Pa?
AH oh wait is this how you solve it:
P(1) - P(2) = 1/2p(v2^2 - v1^2)
P(1) - P(2) = 1/2(1.29)(27^2 - 0^2)
P(1) - P(2) = 470 Pacorrect??
Correct.
thanks profusely
15K
