Bernoulli's Principle density and velocity
The discussion centers on applying Bernoulli's Principle to calculate the pressure difference between two points in a fluid flow scenario. Given a fluid density of 1600 kg/m³ and velocities of 4 m/s at point A and 8 m/s at point B, the correct calculation yields a pressure difference of -7.7 x 10^4 Pa. The user initially calculated -3.84 x 10^4 Pa, but upon review, confirmed the answer key was incorrect, affirming their solution as accurate.
  • Understanding of Bernoulli's Principle
  • Knowledge of fluid dynamics
  • Familiarity with pressure and velocity relationships in fluids
  • Basic algebra for manipulating equations
  • Study Bernoulli's Equation in detail
  • Explore fluid dynamics simulations using software like ANSYS Fluent
  • Learn about the implications of fluid density on pressure calculations
  • Investigate real-world applications of Bernoulli's Principle in engineering
Students in physics or engineering courses, educators teaching fluid dynamics, and professionals involved in hydraulic systems design.
physgrl
The density of the liquid flowing through a horizontal pipe is 1600 kg/m3. The speed of the fluid at point A is 4 m/s while at point B it is 8.0 m/s. What is the difference in pressure, PB - PA, between points B and A?
a. -1.9 x 10^3Pa
b. -3.8 x 10^4Pa
c. +4.5 x 10^4Pa
d. +5.0 x 10^4Pa
*e. -7.7 x 10^4Pa
Pa+1/2*ρ*va2=Pb+1/2*ρ*vb2
Pb-Pa=1/2*ρ*va2-1/2*ρ*vb2
Pb-Pa=1/2*ρ*(va2-vb2)
Pb-Pa=1/2*1600kg/m3*(4m/s2-8m/s2)
Pb-Pa=-3.84x104Pa
and the answer key says its -7.7 x 10^4Pa
what did I do wrong? :s
The answer in the book is incorrect. You have the correct answer.
14K
