Best substance to dissolve in water to increase boilingpoint elevation
The discussion centers on the optimal substance for increasing the boiling point of water through boiling point elevation. Calcium chloride (CaCl2) is identified as a commonly used substance, but its high molar mass is a drawback. The best substance is defined as one that dissociates into the most ions while maintaining a low molar mass. For instance, a compound that dissociates into four ions is preferable to those that dissociate into three ions, regardless of their molar mass.
  • Understanding of colligative properties in chemistry
  • Knowledge of ionic compounds and their dissociation
  • Familiarity with molar mass calculations
  • Basic principles of solution chemistry
  • Research the dissociation properties of various ionic compounds
  • Learn about colligative properties and their applications in real-world scenarios
  • Investigate the molar mass of common salts and their effectiveness in boiling point elevation
  • Explore the effects of different solutes on boiling point elevation in aqueous solutions
Chemistry students, researchers in physical chemistry, and anyone interested in the practical applications of boiling point elevation in solutions.
member 508213
Boiling point elevation depends on how many ions dissociate in the solution. Typically CaCl2 is a good substance to use but it has a pretty high molar mass... I'm wondering what the best substance to use to increase the boiling point of water?
Thanks!
Chemistry news on Phys.org
Define "best".
The best would be the substance that dissociates into the most ions in solution with the lowest molar mass...for example a compound that dissociates into 3 ions and has a molar mass of 50g/mol would be better than a compound that dissociates into 3 ions and has a molar mass of 100g/mol..however, a compound that dissociated into 4 ions would be better than either of those compounds.
44K
19K
