Calculating Speed of Bicycle on a Hill | Mass, Height, and Distance Given
  • Thread starter Thread starter Aikenfan
    Bicycle Hill
The discussion focuses on calculating the speed of a bicycle at the bottom of a hill using principles of energy conservation. The total mass of the rider is 54 kg, with an initial speed of 5 m/s at a height of 1 m and a distance of 101 m down the hill. The potential energy (PE) is calculated as 5292 J, which is then equated to kinetic energy (KE) to find the final speed. The final speed at the bottom of the hill is determined to be approximately 14.177 m/s after accounting for the initial speed.
  • Understanding of potential energy (PE = mgh)
  • Knowledge of kinetic energy (KE = 1/2 mv²)
  • Basic principles of energy conservation
  • Familiarity with trigonometric functions and right-angled triangles
  • Study the conservation of energy in mechanical systems
  • Learn about the application of kinematic equations in inclined planes
  • Explore the effects of friction and air resistance on motion
  • Investigate advanced trigonometric applications in physics problems
This discussion is beneficial for physics students, educators, and anyone interested in understanding the dynamics of motion on inclines, particularly in the context of energy conservation principles.
Aikenfan
You ride your bicycle down a hill. Your total mass is 54 kg. At the top of the hill, your
speed is 5 m/s. The hill is 1 m high and 101 m long. what is
your speed at the bottom of the hill?
PE= mgh
(54)(9.8)(10)
= 5292
find the degree of the hill i think using tangent?
tan (10/100) ??
then solves for v
KE = 1/2 mv^2
Ik its something along those lines but I am a bit confused with the hill (do i use tangent, etc.) thank you very much, any help as soon as they possibly can is very much appreciated. thanks :-)
Well what happens is that at the bottom of the hill all the potential energy will be converted to kinetic energy (disregarding friction and air resistance). What you need to do is set the potential and kinetic energy equal to each other and solve for v. Remember to add on the initial 5m/s.
To find the angle, it depends on if the 100m relates to the hypotenuse or the distance from the start of the hill to the bottom. model the hill as a right angled triangle and remember your trigonometric ratios.
KE = 1/2 mv^2
5292 = 1/2 (54)v^2
and solve for V?
and then just add on the 5m/s to that?
For the length of the hill, i am guessing that it would be referring to the hypotenuse (because that would be the length that the bike travels).
Ok so what trigonometric function do you know that involves the opposite side (10m) and the hypotenuse (100m).
And yes just solve for v and add the 5m/s on.
KE = 1/2 mv^2
5292 = 1/2 (54)v^2
and solve for V?
V=196 + 5 = 201
but what do i do with the hill? it would be Tan-1 (10/100)?
Remember:
\sin(\theta) = O/H<br /> \cos(\theta) = A/H<br /> \tan(\theta) = O/A
where O = opposite, A = Adjacent and H = hypotenuse.
Sin = o/h
10/100
= .0017
would that b right? but how do i figure it out now, the speed at the bottom of the hill, once I've got those numbers? thank you i really appreciate all of the help!
Aikenfan said:
KE = 1/2 mv^2
5292 = 1/2 (54)v^2
and solve for V?
V=196 + 5 = 201
You forgot to take the square root.
You want to take sin-1 (10/100)
okay, now when i get both of those numbers what do i do with the angle?
thanks again
for taking the time to help me
Oh right. Nothing because you have used conservation of energy instead of kinematic equations so you don't really need the angle. I thought it was part of the question you'd neglected to post.
so the answer would just be the square root of 201 which would be 14.177
No the square root of 196 and then add the five.
Okay, thanks very much. just one more quick question...Why don't I do anything with the hill (as in tangent) because it is going down an incline, wouldn't that have an effect on the speed (speed it up)? sorry for all of the questions
If you were using the kinematic equations you'd have to find the component of force acting parallel to the hill and thus you'd need to use the trigonometric stuff. Since you've considered conservation of energy this doesn't matter because all you need to know is how far vertically the bike travels. this is because gravity is a conservative force.
Wow! thank you, you have been very helpful!
11K
