Bidirectional current switching with single type transistor
42 replies · 8K views · last reply
artis
So here is my dilemma. I have a test setup with multiple coils all lined up in parallel in such a way that one end of each coil is connected together while the other is connected to a switch (mosfet) the switches then connect each coil to ground but that ground can become + based on which coil is switched ON because one type of coils have current in one direction while the other have current in the opposite direction.
The coils generate the current within them from a primary source.
The problem is this , I have basically a row of parallel switches. A mosfet can easily conduct current in both direction but it also has the body diode into it.
This means that if my voltage drop across the mosfet is less than the threshold of the body diode it will stay OFF when other fet's are ON but if that voltage is above that it will conduct, if it also has the right polarity.
This means that those coils that have the polarity in the "right" way for the body diode to conduct will conduct without gate charge every time the PD across the switch increases above the body diode threshold.
Now having just one switch is the best solution but it doesn't work in this case.
What other solutions are there besides this ?
Back to back mosfet aka a two series mosfet bidirectional switch?
This solves the current conduction in reverse direction problem but now I have to drive two mosfet instead of one for every switch I need and I need a gate drive IC etc,
What about IGBT's ? They too have body diodes , most of them anyways
Some bipolar switches use SCRs or TRIACs, others use sampling bridges.
I would start by suggesting relays, or CMOS analog gates.
But first we need to know the magnitude of the problem.
Are the voltages across the individual coils bipolar ?
What is the maximum voltage present being switched ?
Does current flow both ways through an individual coil ?
What is the maximum current being switched ?
What is the maximum frequency of the coil current ?
How much time is available for switching ?
If this was the windings of a multi-phase PM rotor generator, then you could use diodes, allowing it to inherently switch itself. Use a MOSFET backwards, the body diode then conducts, the gate allows reverse conduction.
Some problems cannot be solved in an ideal way.
Let me make this easier by making a drawing.
My voltages are low, from couple of volts to double digits not more.
Assume I have two batteries with opposing polarities, I want to switch them through a load to create an AC current through it, say I have just two of them so two switches, the problem as already described.
Current could get high, so low loss/resistance would be beneficial in terms of switches.
My wish is so that I could create a simple driving circuit as I wish to use semiconductors for the switches because they are fast , relays are not an option.
So a fast switch , not necessarily high voltage , but one that can block reverse current when met with reverse polarity, so a single mosfet doesn't work.
I wonder what are the easiest most common alternatives?
Circuit schematic of two batteries with opposing polarity, each with a switch, feeding a LOAD block in a loop; battery polarities marked + and - in red.
Are you sure you would not be better off with a simple H-bridge instead?
TonyStewart said:
then learn everything about this half-bridge design
I certainly had not realised that artis was designing a self-resonant push-pull induction heater.
I thought something like this would be closer to the topological requirements.
Two circuit schematics side by side: left, a CMOS inverter with NMOS M2 and PMOS M1 driven from control, batteries V1 and V2, diodes D1 and D2, and load R1; right, a half bridge or CMOS inverter with PMOS M3, NMOS M4, diodes D3 and D4, batteries V3 and V4, and load R2.
The load may be changed to resistive but then needs a dual clock with dead-time to prevent shoot-thru (short circuit on DC.) This (fault) will happen to your circuits when "control" Vgs > Vgs(th).
All CMOS logic is designed this way but unipolar, such that the RdsOn is limited by the Vdd and controlled for each family , but with a 50% tolerance for Vol/Io=R i.e. "controlled shootthru" such as 50 ohms for 5.5V logic and 25 ohms for 3.6V logic. Whereas old CD4000 was much higher RdsOn and made for high voltage (<18V)
@TonyStewart
You should identify who you are addressing with your comments.
This is not a social media free-for-all.
I believe you are making this discussion more complex than it needs to be at this stage, by posting circuits that are quite inapplicable to the situation, and so derailing this thread.
Please get back in your box, and give the OP time to work out what they want to do.
With respect;
I do understand the problem of commutating Nch FETs all the same type ( vs complementary) and how to clamp one side off when driving the other using an inductive load.
known: user has a row of "like transistors (FETs)" and multiple coil load and a commutation problem
unknown:
purpose of this design, engineering specs, logic diagram
understood: there are many basic types of commutation, inductive feedback with diode clamps (aka also known as ZVS oscillator) and logic-level forward-commutation with dead-time control using PWM on low side to generate Vboost voltage for high side Nch. It all depends on type of load and purpose of the design. There are also mono and bipolar supply designs.
Baluncore said:
@TonyStewart
I thought my comments were directed at everyone, including your simplified half-bridge models.
missing: a reference to my schematic. [my bad]
https://christianmalherbe.com/Induction Heater.html
@TonyStewart I appreciate your effort but indeed @Baluncore is right that we need to slow down a bit here. You took my MS Paint made analogy which is a simple analogy to my actual problem and thought that I'm trying to make a half bridge switching network, this is not the case.
Although I can be partly blamed for not making a better case explanation in the first place, for that I apologize.
What I actually have and what I tried to make clear in the simple analogy is a single wire (literally a wire) that passes through a changing B field periodically , so a current is generated due to Lorentz Force , this creates a voltage across the wire.
In the end of the wire/conductor there is my switch, you can just imagine a single mosfet.
The problem is this , with a single FET when current/voltage is in one direction the mosfet can shut OFF aka control the current , when the voltage reverses, the MOSFET is continually ON due to the body diode.
So there came my problem how to create a switch with transistors that can be applied to a single wire in which current/voltage changes direction.
It is essentially a switch for an AC wire, the closest I know is the so called "solid state relay" where two N mosfets or P mosfets (usually N due to simple driving and lower RdsON) are connected back to back but such a two FET switch is more complex to control and requires twice the parts.
So my curiosity was can one make something simpler , is it even possible
Putting the switch inside a bridge is simple, in some ways. Extra diode voltage drops and difficult FET drive are issues though.
Handwritten circuit schematic of a diode bridge with four diodes in a diamond layout, an input terminal on the left and output terminal on the right, and a transistor symbol across the top and bottom nodes in the centre.
@DaveE I think that this configuration doesn't differ from a two switch series bidirectional switch, because either way one gets two diodes in place of the other transistor which together is either equal or higher of a series resistance isn't it?
I think you must define all inputs and out waveforms and relevant spectral parameters better before choosing any design with a logical diagram (schematic).
Remember that a transistor is only bipolar if biased on some DC current otherwise unipolar and flyback effects reverse in voltage not DC current.
@DaveE 's suggestion will rectify bipolar source current from a unipolar switch since it interfaces with a full wave rectifier. Is that all you need? That is just a simple concept.
We need a much clearer problem definition.
- you initially said " multiple coils all lined up in parallel "
Yes. I think you're right if you only have one transistor. Most topologies will use two transistors (usually in series) for this reason.
But no (if I understand your comment), transistors, properly selected, will have a lower voltage drop than diodes. Synchronous rectifiers are a good example of this. If you need low voltage drop, you may want to replace your diodes with FETs. Of course, the MOSFET Rds(on) becomes an issue at very high currents. But then you can switch to BJTs, SCRs and such.
TonyStewart said:
With respect;
unknown:
There is often great value in focusing on the fundamental question/concepts in answering questions. We know you know a lot about complex circuits, you don't have to prove that at the expense of clear communication about the OPs question. Your half-bridge resonant converter schematic looked familiar to me, but my immediate reaction was "I don't care. It's too complicated for this thread." He asked about a switch topology, that is all.
You are better at filtering through the extraneous information in your examples than any of us are. There is also an advantage that you can do that once for many people, instead of expecting every reader to figure out what your fundamental point is.
Good educators start simple and query the questioner for what to say next.
Did you follow how alternating current follows from DC using Full-Bridges using single supplies and Half-Bridges from dual supplies? There is also a need to have a dead time during transitions that depends on load reactance and current to avoid shoot-through failures.
Did you follow my link from my ZCS Oscillator (zero-crossing switch) example in #4?
When coils or chokes or transformers are used, several options exist but most popular are single driver with centre tap high , also used in stepper motors, or bipolar H-bridge drivers. Bipolar drivers can be both active or using a flyback diode for inductive loads. These topologies are common to SMPS as well.
There are many books on this subject. and short links https://www.wikiwand.com/en/H-Bridge
I would probably just put two N-Mosfets in series. Either with the drains connected or the sources connected together, depending on your gate drive circuit choices. You can either use the body diodes or you can turn them both on together to get lower voltage drop.
Much of this design will depend on how you want to design the gate drive circuits. It's probably best to have the G-S nodes in a part of the circuit that doesn't generate a big dV/dt across the isolation barrier during switching, I think. Although that isn't necessarily possible or even optimal, depending on the application. There are lots of options here.
Note that many comments related to half bridges aren't really bidirectional switches, topology wise; which is fine if that works for you too.
Your array of wires is like a Y or star-connected motor which can be as many phases as your want, typically 3 or more. Thus is defined as a "half-bridge" for each phase or wire with dead-time commutation.
If your power is low, it is pretty uncomplicated to simulate if you have interface specs.
OK, changed my mind. Since you have lots of coils each being switched to a common node, I guess I would opt for the easy gate drive option. This would be an N-FET and a P-FET in parallel each with a series blocking diode to prevent reverse current. Then all of the sources can be at a common node which will make the control circuit much simpler.
I don't think those diodes will prevent shoot-through @DaveE .
Spreading fear, uncertainty and doubt about other member's suggestions is not of value here at PF. You seem to delight in immediately undermining suggestions made by other members. We do not need that destructive behaviour here.
You need to come up with positive suggestions directly related to the thread.
If you must be critical, then practice self-criticism, before you post.
Sorry, I guess I should have drawn a schematic for you. When it's on everything "shoots through". When it's off, nothing "shoots through". It's a bidirectional switch, that's what it's supposed to do. Where does the current "shoot" to when you turn the switch on? IDK, that's not our problem, yet.
Hand-drawn schematic of a bidirectional switch with two MOSFETs in series, each with a body diode, connected between two AC terminals, with a common gate drive line.
The OP hasn't really described the rest of his system in any detail. Perhaps we could be more helpful if we didn't assume we know the details of his application. He can ask for more if he needs it, you know, unless he's fed up at this point.
@TonyStewart can you please just pause first? Once in a while there is a PF member who just throws the whole cyclopedia on a topic , even if you have the actual experience of building and working with every schematic and topology you have mentioned , it still is somewhat overkill to just throw it all out there on a topic that has no association with that.
I already said, please excuse me if I wasn't clear enough from the start , the reason for that is that I wanted to make the problem as simple and reduce it to the main part as much as possible, that caused some confusion.
I am also familiar with switching topologies to a certain level but my problem doesn't deal with any switching topology.
Shoot through is only a problem for switching topologies because of the stored DC energy in the caps, I have no caps, no DC, no transformer , no flyback voltage no nothing. Just a tiny bit of inductance and some capacitance , no more than a typical transmission cable would have.
I as @DaveE correctly said ,I actually need the "shoot through" to happen.
The idea is basically this, I have many parallel wires, each wire has a switch in it, the wires carry bidirectional current. That's it. If it makes it simpler for you @TonyStewart imagine many mains phase wires all in parallel and all of the same phase, current goes forth current goes back, put a switch across such wire and you need the capability to block current in both directions which with a single mosfet isn't possible due to the body diode. That is it, this is all the problem.So what I was originally looking at, and still am is this
How to switch bidirectional current with
1) as little of switch resistance as possible
2) as simply as possible (low parts count)
3) the switch driving to be as simple as possible
At the same time I can paraphrase Einstein, I need the switches and driving to be as simple as possible but not simpler.... in other words, to just do the job.
The simple two FET back to back series configuration is known to me, I have implemented that already in a solid state relay in an amplifier output.
The reason I was asking is because that kind of configuration needs a more complicated gate drive circuit, no problem for a once on , once off amplifier output relay, but becomes trickier for many parallel switches that also need fast switching.Maybe I can sacrifice a little bit of that RdsON switch resistance by omitting a switch and putting instead a fast recovery diode in it's place or something like that.
I thought about this, but I think there are two problems, possibly, first is that there actually isn't a common node on either part of the switches, because there are additional devices "down the line" so whenever current reverses there would a PD of some couple of tens of volts that also reveres across any closed switch.
Secondly , isn't it the case that all P fet's have higher RdsON than their N channel counterparts due to the inherent structure of the device itself?
Doesn't this affect voltage drop for low voltages ?
I doubt you'll get all of that. It'll be a trade off.
Schottky diode then? Lower Vf and I think you said it's a low voltage application.
low voltage yes, but high current, will have to look into it, don't know from the top of my head but IIRC schotky's were usually in low power applications?
Yes, they suck, mobility wise. So you pay more and buy a bigger die, or you use NMOS with a more complex circuit.
I don't know the V, I, P you are working with, but there are definitely big Schottkies, current wise.
https://www.vishay.com/docs/94171/vs-243nq100pbf.pdf
Power MOSFETs often have a Schottky diode in parallel with the body diode.
If you use the body diode of a MOSFET as a forward conducting diode, you can turn on the MOSFET while the diode is conducting to reduce the diode voltage drop. That is the principle of an ideal diode, or as used in a synchronous rectifier.
Since this is high-current low-voltage, if you connect two N-channel MOSFETs source to source, and gate to gate, do you not have a bidirectional switch between the drains, controlled by ±15 volts on the common gate terminal?
