Bijective function from naturals to primes
  • Context: Undergrad
  • Thread starter Thread starter asmani
    Function Primes
The discussion revolves around the concept of establishing bijective functions between sets of natural numbers and prime numbers, as well as between rational numbers and natural numbers. Participants explore various proposed mappings and their properties, including injectivity and surjectivity, while also referencing related mathematical concepts and examples.
  • One participant suggests a trivial solution mapping natural numbers to the nth prime.
  • Another participant questions the triviality of this solution, noting that it relies on the assumption that the number of primes is infinite.
  • Several participants request examples of complex functions related to the topic.
  • A participant proposes a mapping from rational numbers to natural numbers using the formula m/n --> 2m3n, claiming it shows a bijection from a specific subset of rational numbers to natural numbers.
  • Another participant challenges this claim, stating that the proposed mapping is injective but not surjective, providing a counterexample that highlights primes greater than three are not included.
  • A clarification is made regarding the mapping being a bijection from rational numbers to a set W, which is defined as all numbers of the form 2m3n for coprime m and n, and then from W to natural numbers.
  • A later reply suggests that the proposed mapping could also utilize a standard diagonalization scheme, referencing an external paper on the topic.
Participants express differing views on the nature of the proposed mappings, with some asserting the existence of bijections while others contest the completeness of these mappings. The discussion remains unresolved regarding the validity of the bijections and the implications of the proposed functions.
Limitations include assumptions about the finiteness of primes and the specific definitions of the sets involved. The discussion also reflects varying interpretations of injective and surjective properties in the context of the proposed functions.
asmani
What's the problem with this trivial solution: n --> n'th prime.
None.
asmani said:
When I googled what I found were mind boggling functions...
Can you give an example?
Your solution does of course use the result that the number of primes is not finite, so depending on what can be assumed known, that solution may not be "trivial".
I was thinking about bijection from Q to N. here is what I came up with: m/n --> 2m3n
And it's easy to show there's a bijection from the set "2m3n for all coprime n and m" to N.
Edit: This is Q+ to N. Does it work?
It's an embedding (injective), but is is no surjection.
Can you give a counterexample?
The map is into and not onto, e.g. you don't hit any prime greater than three.
Oh I see what you mean. Let me clarify: It's a bijection from Q+ to W, and then from W to N, where W is the set of all 2m3n for all coprime n and m.
Here is the bijection from W to N: Map the smallest member of W to 1, the second smallest member of W to 2, and so on
This will do, I guess, but then you could as well use the standard diagonalization scheme.
Here's an interesting paper about the repetitions in it:
http://www.cs.utexas.edu/users/sandip/acl2-09/presentations/rationals-talk.pdf
  • · Replies 19 ·
  • · Replies 24 ·
  • · Replies 26 ·
  • · Replies 22 ·
