Is there a test for binary numbers divisible by 2^n - 1?
To determine if a binary number is divisible by 2^n - 1 for even n, one can use the sum of its base 2^n digits, which is divisible by 2^n - 1 if the number itself is. The discussion highlights that even powers are generally not prime, relating to Mersenne primes. Additionally, methods for testing divisibility by 3 in binary involve alternating addition and subtraction of bits, similar to base 10 divisibility rules. Examples illustrate how to apply these tests effectively. Overall, while various techniques exist, the speed of calculation for these tests remains uncertain.
kurtulmehtap
Dear All,
I have to test if a binary number is divisible to
2^n - 1 where n is even.
Is there a test available for binary numbers like to test a divisibility by 3.
Thanks in advance...
You are talking about what, in general, is studied as Mersenne primes. Even powers are generally not prime. That's not hard to show.
The sum of the base 2^n digits is divisible by 2^n-1 iff the number is, so you could use that. But I'm not sure how much of a speedup that gives.
I interpreted the question as "how can I tell if N is divisible by 2^n-1" rather than "how can I tell if N divides 2^n-1".
in my case n is even, not odd or prime
Testing if a binary number is divisible by three is like testing if a number base 10 is divisible by 11. Alternately subtract than add the bits together and if your answer is divisable by three than the whole string was divisable by three.
1100101 1-1+0-0+1-0+1=2 not divisible by 3
1100110 1-1+0-0+1-1+0=0 divisible by three.
3 is a funny number, since it's 2^1 + 1 and 2^2 - 1. You can use either type of test: add digits in blocks of two, or alternately add and subtract digits.
10101011 = 10+10+10+11 = 1001 = 10 + 01 = 11 = 0 (mod 3)
10101011 -> 1-0+1-0+1-0+1-1 = 11 = 0 (mod 3)
The first preserves residues (not just divisibility) mod 3; the second works with smaller numbers (though twice as many).
You can test if a number base 4 is a multiple of three the way you test if a number base ten is a multiple of nine. I saw your earlier post and decided to add some additional information. I don't know which approach , if either, gives you any calculating speed up.
  • · Replies 26 ·
