Calculating Magnetic Field at a Point Using Biot-Savart Law
The discussion focuses on calculating the magnetic field at point O using the Biot-Savart Law for a system involving a long wire segment and a quarter circular arc. The current (I) is given as 7.5A and the radius (a) is 0.69 m. The initial calculation using the formula B = μ0 * I / 2a yields an incorrect result, prompting a deeper analysis of the Biot-Savart Law, specifically the integral form B = (μ0 / 4π) ∫ (I dl × ȳ) / |r|². The importance of considering the arc's contribution and checking units is emphasized for accurate results.
  • Understanding of the Biot-Savart Law and its integral form
  • Basic knowledge of magnetic fields and current-carrying conductors
  • Familiarity with vector calculus, particularly cross products
  • Ability to perform unit analysis in physics equations
  • Study the derivation and applications of the Biot-Savart Law in electromagnetic theory
  • Learn how to apply vector calculus to solve problems involving magnetic fields
  • Explore the concept of magnetic field lines and their visualization
  • Investigate the effects of different geometries on magnetic field calculations
Students and professionals in physics, electrical engineering, and anyone involved in electromagnetism who seeks to understand magnetic field calculations in complex geometries.
Eva01
A long (effectively infinite) wire segment
is connected to a quarter of a circular arc with
radius a. The other end of the arc is connected
to another long horizontal wire segment. The
current is flowing from the top coming down
vertically and flows to the right along the pos-
itive x-axis. I have included the image below.
I = 7.5A, a = 0.69 m. Find the magnetic field at O?
B = μ0 * I / 2a
As far as I understand since we only consider the arc part then I use the formula from above but I am not getting the right answer.
B = 4∏ * 10^-7 * 7.5 / 2*0.69 = 6.8295 N/m
Hello Eva01,
Firstly you need to consider the origin of your equation :
B = μ0 * I / 2a
which is the Biot Savart law.
B = \frac{\mu_{0}}{4 \pi}\int \frac{(I dl \times \hat{r})}{ |\vec{r}|^{2}}
For your system you do only need to use the arc system but you should find out why..
For the arc itself, consider the law above. Clearly the I and the denominator are constant. So we need to solve
\int (dl \times \hat{r})
Remembering that a chord (r) connecting the point O to the arc will always be perpendicular to an infinitesimal length of the arc. This should give you a similar equation to what you have been using but it requires an additional factor somewhere.
I would also advise that you check your units at some point.
Hope this helps
Thank you for your help!
  • · Replies 18 ·
10K
