Black hole matter accumulation
284 replies · 38K views
Passionflower said:
By the way MTW says he same as I do. On page 847:
Hence, to the distant astronomer, the collapsing star appears to slow down as it approaches its gravitational radius: light from the star becomes more and more red-shifted. Clocks on the star appear to run more and more slowly. It takes an infinite time for the star to reach its gravitational radius; and as seen by the distant astronomer the star never gets beyond there.
Emphasize the word 'seen'. Why is this seen? Because of an event horizon. What is the state of the matter inside the star? Any application of GR says the matter has collapsed to a singularity.
Consider a time when a collapsing mass has gone dark. It has an apparent radius. From its history, we know there is matter inside this radius. The idea that the manifold ends at or just below the visible surface is untenable.
Consider the definition of an event horizon. The surface from which no light can ever reach infinity. At this time (for an outside observer, when the star has gone completely dark), it is clear that light epsilon inside the dark surface can never reach infinity. Thus the event horizon already exists.
Once the outside observer passes the surface of last influence, unless a different law than GR is used, the matter inside the event horizon will collapse quickly to a singularity.
PeterDonis said:
The qualification, in bold, is crucial, as I said. For any given state of motion, there is a "correct" way to define simultaneity that respects the Einstein clock synchronization convention (which is what "isotropic speed of light" refers to). However, that only applies to that particular state of motion. A different state of motion can have a different "correct" simultaneity convention.
For example: if an observer is hovering at a constant radial coordinate above a black hole's horizon, there is a "correct" simultaneity convention for him, which is the one used in the Schwarzschild interior coordinates. However, if an observer is freely falling towards the hole, there is a different "correct" simultaneity convention for him, which is the one used in Painleve coordinates.
What this means is that the "lines of simultaneity" for Schwarzschild coordinates are *different lines* than the ones for Painleve coordinates. "Different lines" is an invariant, coordinate-free statement; the two sets of lines of simultaneity are different geometric objects. And it's perfectly possible for different sets of lines to cover different regions of spacetime; in this case, one set happens to reach into a region of spacetime that the other set does not. See below.
The problem here is that coordinates does not give clear picture about this geometry of simultaneity.
But I want to check that this geometry of simultaneity is consistent between two coordinate charts (Schwarzschild and Painleve). I have gut feeling that these two geometries are incompatible (they correspond to two physically different situations). And I either want to get rid of that doubt or confirm it.
For now I have only the things that I explained in my post #237. From that reasoning it seems that simultaneities corresponding to of black hole and white hole can not be jointly realized in single coordinate system (when we include region behind EH) and therefore they are mutually exclusive. But the only difference between black hole and white hole is this geometry of simultaneity.
PeterDonis said:
Yes, certainly. But the conversion only has to be possible in a region of spacetime that is covered by both frames ("coordinate charts" would be a better term). If one chart does not cover a region (such as the black hole interior), then there is no requirement that other charts have to be able to convert to or from it in that region.
Of course when we compare Schwarzschild and Painleve coordinate charts we should leave out black hole interior.
PeterDonis said:
There are certainly different charts, with different simultaneity conventions. However, you have not shown that any of them are contradictory. All you have shown is that the different charts cover different regions of the spacetime, and that the "coordinate lines" on the different charts, such as the lines of simultaneity, are different geometric objects. None of this is in any way contradictory.
Interiors of black hole and white hole are contradictory and that is only because of different geometry of simultaneity.
PeterDonis said:
This is not correct. The *geometry* of the interior is not disconnected from the geometry of the exterior. They are connected, as can be easily seen by analyzing covariant or invariant objects like geodesics, curvature tensors, etc.
It is true that the interior Schwarzschild *coordinate patch* is disconnected from the exterior Schwarzschild coordinate patch; that is what is meant by statements about the "infinite future" and whether anything is "beyond" it. But that statement does not support your argument, because it only applies to a particular coordinate system; it is not a statement about the underlying geometry, which is what is important for the physics.
Physical interactions is the thing that is important in physics. Round trip for light to EH is infinite and in Schwarzschild chart forward trip is equal to backward trip. So there can be no physical interactions between interior and exterior of Schwarzschild black hole.
Sorry but your arguments about *geometry* are just hand waving.
DrGreg said:
But do you think that "inside" of a Rindler horizon exists for a Minkowski observer? If yes, then your interpretation of "existence" is observer dependent?
Well, yes observer dependent "existence" does not sound good.
I would like to say that existence of "real" things is observer independent.
But I suppose that in reality we have other things that we can consider to make our conclusions more likely correct. For example we might decide that one set of observers gives more contrived global picture than the other set of observers.
DrGreg said:
The Rindler time coordinate approaches ∞ as you approach the Rindler horizon, and coordinates can't go beyond ∞, so you are right. (The Rindler time coordinate equals the Rindler observer's proper time along his own worldline, and locally represents Einstein-simultaneity for any other observer at rest relative to the Rindler observer.)
Not sure that you understood my question. But I checked that unclear point myself and it turned out that my doubts where false.
Q-reeus said:
Issue now, following #241, is to nail down just what property/operation of ET actually yields tangential contraction.
The tangential pressure components of the stress energy tensor. There is no tangential pressure in the vacuum region, there is in the matter region.
Here is a arxiv paper you may like. It uses an analytical model for the shells, so it is not the usual "step function" you would normally consider, but it describes things like the radial and transverse pressures:
http://arxiv.org/abs/0911.4822
DaleSpam said:
OK, I think that the concept you are trying to describe here is a congruence, which is essentially a family of worldlines. For example, you could associate one worldline with each spatial location in Schwarzschild coordinates. This would give a family of timelike curves which could each represent a stationary observer relative to the central mass. Then this set of observers would all share the same "infinite future" region.
The existence of one congruence which share the same "infinite future" does not in any logical way forbid the existence of another set of congruences which share a different "infinite future". Your line of reasoning seems to be that there is a timelike congruence which ends up in the usual "infinite future" therefore all timelike congruences must end up in the same "infinite future". This is not sound logic.
I'm not sure I can make myself clear by I will try one more time.
It does not make sense to speak about different "infinite futures" or the same "infinite future".
Infinity is just an abstract idea to help one say how function or series or whatever behaves when it is extrapolated without limit.
If you get different results when you extrapolate function then they are different functions and not extrapolations with different "without-limits".
And if we look back with what it started then it is pointless to say that some function will acquire different properties if we extrapolate it beyond "without-limit".
PAllen said:
Q-reeus example has nothing to do with black holes. He is claiming Minkowski geometry inside a spherical shell and Schwarzschild outside somehow leads to a contradiction. This whole topic is really a hijacking of the original purpose of the thread - to discuss implications of the inability of a black hole interior (if it exists) to influence the outside.
Agreed that's what I'm on about, but I strongly disagree it has nothing to do with BH's, as my opening salvo in #138 outlined. But I accept it could be taken as hijacking, and will therefore start my own thread just on that issue. Feel free to participate there. It will be titled "How does GR handle metric transition for a spherical mass shell?"
PeterDonis said:
Some clarifications:...
Peter - thanks again for useful input, but I'm taking PAllen's hint and vacating this thread. Hope we can continue this discussion in the new one. Cheers
No problem, looking forward to it.
Schwarzschild coordinates don't, that's true; that's because their lines of simultaneity (the lines of constant Schwarzschild time t) all intersect at the horizon. But that is not true of other coordinate charts.
It depends on what you mean by "physically different situations". Both sets of lines of simultaneity are in the same spacetime--the same global geometry--but they are two *different* sets of lines. The Schwarzschild lines of simultaneity only cover the exterior region of the global geometry. The Painleve lines of simultaneity cover both the exterior region and the interior region, and the horizon.
The black hole and the white hole *can* both be "realized" in the same coordinate system: the maximally extended Kruskal coordinates. In those coordinates, the lines of simultaneity in the white hole region and those in the black hole region are "parallel"--they belong to the same global set of lines of simultaneity--but they are different subsets of the global set of lines of simultaneity, that don't overlap.
However, in an actual spacetime where a black hole is formed by the collapse of a massive body, the white hole region is not present; only the exterior, the "future interior" (the black hole region), and the non-vacuum region occupied by the collapsing massive object are present. As far as I know, the full spacetime geometry described by the maximally extended Kruskal chart, which includes the white hole region (and also a second "exterior" region), is theoretical only, and no one claims that any actual physical spacetime contains all the regions that are present in that theoretical spacetime.
Yes, because the Schwarzschild chart (the exterior one) doesn't cover the black hole interior (or the horizon). But even in the exterior region the lines of simultaneity in the two charts are different sets of lines, "pointing" in different "directions".
Physical interactions don't require a "round trip" causal influence, just one-way is enough. Causal influences can still propagate into the interior from the exterior.
If you really can't grasp the geometric way of describing the physics, there are other ways. They take a lot longer to talk about, which is why most physicists prefer the geometric description, at least for GR. But if you're getting hung up on the word "geometry", you're missing the point.
Sure it does. If you have any timelike congruence of curves simply parameterize each curve by the proper time, find the surface formed by all of the congruence curves at a given proper time, and then take the limit of that surface as the proper time goes to infinity.
Again, that is only true if you have a 1D function. I.e. it is true for a single curve in a timelike congruence, but not for the whole congruence. If you have a function of multiple dimensions then you can easily have different infinite limits.
In any case, the Schwarzschild solution is valid for more than a single observer, so taking different infinite limits is reasonable. There is no reason to restrict ourself to a single observer or even a single timelike congruence.
And now you even does not speak English as it seems. The part "inter-" in the word "interaction" stands for "two-way".
From wikipedia:
"Interaction is a kind of action that occurs as two or more objects have an effect upon one another. The idea of a two-way effect is essential in the concept of interaction, as opposed to a one-way causal effect."
Sure, now you gave definition and the term acquired sense. :wink:
You can't find directly limit at infinity for a function of multiple dimensions.
Intermediate step is to express it as single-dimensional function. And depending on how you do that you will have different single-dimensional functions.
There are reasons to restrict ourselves to single timelike congruence. One reason is simplicity of calculations. We might benefit from timelike congruence that is spatially static in respect to gravitating object.
Other reason is consistency of global observations. Actually I think that consistency of global observations is the way how we can meaningfully speak about "correct" geometry of simultaneity.
From wikipedia:
All right, if you don't like the word "interaction" in reference to one-way causal influences, I'll just say "causal influence", and I'll dispute your claim that two-way "physical interactions" are what are important in physics. I think that "causal influences" are what are important in physics, whether they are one-way or two-way. That was the point I was trying to make.
