Mentor
- 50,923
- 26,957
TrickyDicky said:Peter, the exponentials for the coefficients are used precisely to avoid that kind of dimensional swapping,IOW to distiguish clearlybetween the spacelike and the timelike coordinates, whose nature is determined a priori, not based on an arbitrary relabeling.
No, the nature of the spacelike and timelike coordinates is *not* determined a priori. That's the whole point. If you claim that they are, then please read the proof I posted and tell me which specific parts of it are not valid for r < 2m. If my proof is valid for r < 2m, then it is valid for t both timelike *and* spacelike (and for r both spacelike *and* timelike).
TrickyDicky said:To make more precise what I was saying in #254, whether a coordinate is temporal or spatial is predefined for a given line element
Not for all charts. You can certainly *define* a coordinate in a way that requires it to be timelike or spacelike (or null), but there's nothing that requires you to. In the case we're discussing, the Schwarzschild r and t coordinates are *not* defined in a way that forces them to be timelike or spacelike or null. You have to *figure out* which they are by looking at the line element. And if the line element is valid in different regions which have different signs for the coefficients, then the coordinates can be timelike (or spacelike) in one region and spacelike (or timelike) in another.
TrickyDicky said:When ambiguities can affect the results it is better to use the coefficients in exponential form, when MTW says that in the general case there is no such constraint on sign, it means exactly that, the general case, not the Schwarzschild's case, otherwise they could skip using the exponential form at all.
You are misreading MTW (and it doesn't appear that you've been reading my previous posts very carefully). MTW specifically use the exponential form in deriving Birkhoff's theorem, i.e., in discussing the *Schwarzschild vacuum* case. I have pointed you several times now at MTW's proof *and* at my own proof, which I've linked to; in both places it is explicitly stated that the proof applies for 0 < r < 2m (i.e., r timelike and t spacelike) as well as 2m < r < infinity (r spacelike and t timelike). And my proof is even written without the exponentials and *still* shows a change of sign in the metric coefficients for 0 < r < 2m. Either point out specifically where MTW's proof and my proof do not apply for 0 < r < 2m, or stop making these incorrect claims.
TrickyDicky said:Try using the Schwarzschild metric in isotropic cordinates and you'll see the fact r is < or > than 2GM doesn't change the sign ofthe coefficients.
Yes, that's because isotropic coordinates do not cover the interior region; instead they double cover the exterior region. The range 0 < R < M/2 (R is the isotropic radial coordinate, and R = M/2 is the horizon) covers the *same* region of spacetime as M/2 < R < infinity. Which proves absolutely nothing about any other coordinate chart.
TrickyDicky said:If the isotropic coordinates can be used in region II and t is still timelike, why use the coordinates that may produce far-fetched consequences?
See above. Isotropic coordinates do not cover Region II. The same comment applies to your further comments about isotropic coordinates. Others have made a similar comment; MTW is another reference that discusses this.
But there's an easy way to see it for yourself: pick two values of R, R1 and R2, such that R2 = M^2 / (4 * R1). For example, R1 = M and R2 = M/4 will work. Now compute the physical area of a 2-sphere at isotropic radial coordinates R1 and R2. You will find that they are the same; in other words, both R1 and R2 label the *same* 2-sphere, and it is a 2-sphere *outside* the horizon, since the physical area is greater than that of a 2-sphere at the horizon. You will *not* be able to find *any* value of R that labels a 2-sphere inside the horizon (i.e., with area less than the area of a 2-sphere at the horizon). This proves that isotropic coordinates only cover the exterior region.
Edit: I suppose I should explicitly write down the line element in the isotropic coordinates I was assuming above:
[tex]ds^2 = - \frac{\left( 1 - M / 2R \right)^2}{\left( 1 + M / 2R \right)^2} dt^2 + \left(1 + \frac{M}{2R} \right)^4 \left[ dR^2 + R^2 \left( d\theta^2 + sin^2 \theta d\phi^2 \right) \right][/tex]
TrickyDicky said:Of course if one is convinced beforehand that inside the Schwarzschild radius there is no timelike KVF
I was not "convinced beforehand". I explicitly *proved* it, following the *proof* that MTW give. Either refute these proofs specifically or stop making this incorrect claim.
TrickyDicky said:I find the attempt to derive something physical or geometrical from the Schwarzschild coordinate anomaly for r<2GM as misguided as trying to derive physical or geometrical consequences from the purely coordinate singularity at r=2GM. Guys, there is no real singularity there!
Yes, we all know that. So what? We're not deriving anything from the presence of the coordinate singularity; none of what we're saying depends on there being a coordinate singularity at r = 2m in Schwarzschild coordinates. Again, have you read MTW's proof, or the proof I posted?
