Blank diameter for a torispherical dish?
  • Thread starter Thread starter lingesh
    Diameter
The calculation of the blank diameter for a torispherical dish involves using the outer diameter (OD) of 1332 mm and a constant thickness of 6 mm. The process requires assuming that the plate thickness remains constant and that volume is conserved. To derive the blank diameter, one can take a diametral section through the dish and 'unroll' it back to a flat shape. For critical applications, manufacturers may conduct test pieces or rely on past experience to adjust the blank diameter closer to the required size.
  • Understanding of torispherical dish geometry
  • Knowledge of volume conservation principles
  • Familiarity with metal forming processes such as pressing and spinning
  • Basic algebra for geometric calculations
  • Research "torispherical dish calculations" for detailed formulas
  • Learn about metal forming techniques like pressing and spinning
  • Explore methods for conducting test pieces in manufacturing
  • Study the impact of thickness on the geometry of formed dishes
Engineers, manufacturers, and designers involved in the production of torispherical dishes or similar geometries will benefit from this discussion.
lingesh
Hi,
How can i calculate the blank dia required for a torispherical dish?Please share any formulas if you have..
OD=1332 MM
THICKNESS 6MM
Using a lot of algebra. Have you tried assuming the plate thickness is constant and that volume is conserved?
yes, thickness is constant and volume is conserved..
Google ' torispherical dish calculations '
It's not actually all that difficult .
Take a diametral section through the dish and 'unroll' it back to flat .
If dish is made by any normal process which preserves constant and original thickness then diameter of blank as derived above will be on safe side of minimum needed .
In production or for one off's that were critical a manufacturer would either do a test piece or use experience of many previous jobs and trim basic blank diameter to get a little nearer to exact size needed .
lingesh.
Will you shape the flat circle into a torispherical dish by pressing, by metal spinning or by some other process?
10K
  • · Replies 22 ·
