Block Acceleration up an Inclined Plane
In summary, a 200kg block is being pulled up a 30 degree incline at 9.81m/s with a 3.5kN force acting on it.
nobodyuknow
64
A cable is pulling a 200kg block up an inclined plane elevated at 30 degrees with 3.5KN of force. How fast is the block accelerating at?
θ = 30
g = 9.81
m = 200kg
μ = 0.35
F = kN
F = ma
Wasn't sure how to do this problem, I somehow got this...
ma = m*g*sinθ - μ*m*g*cosθ
But don't know how to implement the 3.5kN force into it.
θ = 30
g = 9.81
m = 200kg
μ = 0.35
F = kN
F = ma
What you have written is the force equation. It gives the sum of all forces on the body, in direction of the incline, to be equal to the acceleration(in that direction) times its mass, from Newton's second law. Do you see where your 3.5kN force would join in now?
Remember that forces are vectors and can act in different directions. Think about which forces act in which direction (Up or down the hill) in the problem. The 3.5kN work to accelerate the block ... the hill, gravity and friction work to accelerate the block ... the hill. Together they make a net force in a certain direction.
Good approach is to draw fbd.
so basically, what I would do is use that equation I've got down there:
200a = 200*9.81*sin(30) - 0.35*200*9.81*cos(30)
a = 1.9315 down hill
Then... F = ma... = 200 * 1.9315 = 386.3
3500 - 386.3 = 200*a(uphill)
a = 15.5685m/s^2
Which is ridiculously fast, but, is a fair call because it's only a 200kg mass with a 3.5 tonne force.
So 15.5685m/s^2...?
Take azizlwl's advice and draw a force diagram.
That being, if you don't know, a simplified picture of the situation showing planes, masses and forces and any relevant angles and figures. In this case you would draw a box sitting on an inclined plane, fill in the angle of the plane and any known figures (The mass of the block, for example)
Having drawn this, think about all the forces in the situation and in which direction they act. Clearly you understand that gravity acts downwards and a component of this equal to mgsinθ acts down the hill. You also clearly understand that the resistance force as a result of friction is equal to mg0.35cosθ.
You've given your equation as ma = m*g*sinθ - μ*m*g*cosθ
Questions; Which direction does the resisting frictional force act? Is it the same or different direction to the weight force? Do forces acting in the same direction combine with or cancel each other?
In which direction does the 3.5kN force act? Is it the same or difference to the weight and frictional forces?
How can you mathematically represent the different directions in which a force acts?
^ Hopefully that jogs your mind along a little. Additionally, I'd avoid referring to force in terms of mass "3.5 tonne force".
a = 15.5685m/s^2
So 15.5685m/s^2...?
Your frictional force is going uphill.
Which is direction of the motion.
Don't make it too easy..
So instead of
it should be...
ma = m*g*sinθ + μ*m*g*cosθ
Which'll give me 1925N of force downwards...
Then doing the same thing, I'll have
3500 - 1925 = 200a
a = 9.625m/s^2
Yes.
Ugh all because of one mistake which I thought wasn't D: Thank you so much!
Could I use the same principles for this question? http://img844.imageshack.us/img844/6641/f5fec6746b9c42289610ba1.png
Yes, however don't expect any help from me on that one. I could sit down for a while and try it but I'm by no means a physics guru like some of the people here. While you can apply the same principles, there's a few other principles you need to apply. Like force to overcome static friction etc. And the whole thing is made slightly more complicated by the lack of workable figures.
Mm, because, I have no idea really on how to implement static as well as kinetic friction into this problem :/
Well static friction is the frictional force between the mass and the plane when the mass is stationary. For example if I had a 10kg mass and a Us of 0.1, the frictional force would be mg0.1. We'll take that to equal 10N because I'm feeling lazy and 9.81 is just too much.
So the frictional force is 10N, and that acts in resistance to the pulling force. Assuming The weight force down the incline is equal to say, 30N, we would need to apply a force of >40N to get the object moving.
Then, however, Us becomes invalid. We have to apply Uk. If Uk was equal to 0.05, making the resisting frictional force 5N only, the force required to accelerate the mass is >35N. Applying a force equal to 35N would merely keep the mass moving at its velocity at that instant.
Make sense?
Should I actually be getting a figure here as an answer or an equation?
Equation.
1. How does the angle of the incline affect the block's acceleration?
The angle of the incline does affect the block's acceleration. As the angle increases, the component of the weight of the block that acts down the slope also increases, resulting in a greater acceleration. This means that the steeper the incline, the faster the block will accelerate.
2. Does the mass of the block affect its acceleration up an inclined plane?
Yes, the mass of the block does affect its acceleration. According to Newton's second law of motion, the acceleration of an object is directly proportional to the force acting on it and inversely proportional to its mass. This means that a heavier block will have a slower acceleration compared to a lighter block when pushed up the same inclined plane.
3. How does friction play a role in block acceleration up an inclined plane?
Friction does play a role in block acceleration up an inclined plane. Friction is a force that acts in the opposite direction of an object's motion, and it increases as the incline becomes steeper. This means that a block will experience more friction and have a slower acceleration when pushed up a steeper incline compared to a less steep incline.
4. How can the acceleration of the block be calculated when going up an inclined plane?
The acceleration of the block can be calculated using the following formula: a = (F - mgsinθ) / m. In this formula, F is the applied force, m is the mass of the block, g is the acceleration due to gravity (9.8 m/s²), and θ is the angle of the incline. This formula takes into account the forces acting on the block, including the component of the weight of the block that acts down the slope and the force of friction.
5. Is there a maximum angle at which the block can be pushed up an inclined plane without sliding back down?
Yes, there is a maximum angle for a block to be pushed up an inclined plane without sliding back down. This is known as the critical angle. The critical angle is dependent on the coefficient of friction between the block and the incline's surface. If the incline is too steep, the force of friction will not be strong enough to prevent the block from sliding back down. The critical angle can be calculated using the formula θ = tan⁻¹(μ), where μ is the coefficient of friction.
