Block in an incline connected to a spring
The discussion focuses on a physics problem involving a block on a frictionless incline connected to a spring. The incline's angle is 28 degrees, the spring constant is 692 N/m, and the block's mass is 4.95 kg. The participant successfully derived the equation mg(sin28) = 1/2kx to find the distance x the block moves down the incline before coming to rest, ultimately calculating x to be 0.066 m. The participant also addressed the acceleration at the lowest point using Newton's second law, emphasizing the importance of directionality in force calculations.
  • Understanding of Newton's laws of motion
  • Familiarity with spring mechanics and Hooke's Law
  • Knowledge of trigonometric functions, specifically sine
  • Ability to manipulate algebraic equations
  • Review the application of Hooke's Law in dynamic systems
  • Study the principles of energy conservation in mechanical systems
  • Learn about the effects of incline angles on force components
  • Explore advanced topics in oscillatory motion and spring dynamics
Students studying physics, particularly those focusing on mechanics and dynamics, as well as educators looking for examples of problem-solving in inclined plane scenarios.
Warmacblu
Supposed the incline is frictionless for the system. The angle of inclination is 28 degrees, the spring constant is 692 N / m and the mass of the block is 4.95 kg. The block is released from rest with the spring initially unstretched. The acceleration of gravity is 9.8 m/s2.
How far x does it move down the incline before coming to rest?
Choosing down the incline as the positive direction, what is its acceleration at its lowest point?
For part A - mgh = 1/2kx2
h = xsin28
I plugged h into the equation and got:
mg(xsin28) = 1/2kx2
I cannot seem to solve for x.
I do not know if this equation is correct.
Thanks for any help.
You have to be careful, when doing inclines, to keep your directions clear and separate. I recommend using x and y for the untilted world and x' and y' for the incline.
I don't entirely understand what you are saying but when I drew out the diagram I set the positive x direction pointing down with the block moving down the incline and I don't even think a y direction has to be taken into account.
Perhaps I misunderstood your setup. You have x being positive down the incline. Where is h? You might also say something about the level of the course this is for since the answer is more mathematically involved than the question seems to suggest.
Here is a link to the exact question I am doing but I wanted to try and solve it for myself before looking at this thread:
https://www.physicsforums.com/showthread.php?t=212572
I did glance over it and I got the same equation for the first part but he seemed to be able to solve for x and I could not. I think it's an algebra problem.
mg(xsin28) = 1/2kx2
The equation is fine. Try dividing both sides by x.
mg(xsin28) = 1/2kx2
mg(sin28) = 1/2kx
mg(sin28) / 1/2k = x
Does that look okay?
Warmacblu said:
mg(xsin28) = 1/2kx2
mg(sin28) = 1/2kx
Looks good.
I am going to try out this answer in a few minutes, I will report back.
Okay, my x value (distance moving down the incline) turned out to be .066 m. I managed to solve b by using a Fnet equation and an acceleration equation given by my professor. My Fnet equation looked like this:
Fnet = mgsin22 + kx
After solving for F, I plugged that into F / m (mass) = a
However, my answer should be negative because it is moving up the slope at its lowest point.
Thanks for the help on part a.
Good.
That "acceleration equation" is just Newton's 2nd law.
Fnet = mgsin22 + kx
Careful with the direction (and thus the sign) of those forces. Which way does gravity act? Which way is the spring pulling?
(Also, is 22 degrees a typo? Before it was 28.)
  • · Replies 27 ·
10K
  • · Replies 52 ·
