What is the Effect of Angular Acceleration on a Block on a Conical Surface?
The discussion centers on the effect of angular acceleration on a block positioned on a conical surface. Participants clarify that the frictional force acts along the cone's surface, and the net acceleration of the block is defined by the equation a = rα û + ω²rñ. The key point is that while the angular acceleration is described as increasing slowly, it cannot be approximated as zero, as this would negate the continuous increase in angular velocity critical to the problem. The maximum angular velocity before the block slips is the primary concern.
  • Understanding of free body diagrams
  • Familiarity with angular acceleration and velocity concepts
  • Knowledge of circular motion dynamics
  • Basic principles of friction on inclined surfaces
  • Study the dynamics of objects on conical surfaces
  • Learn about the equations of motion in rotational dynamics
  • Research the effects of friction in circular motion scenarios
  • Explore the concept of critical velocity in physics
Physics students, mechanical engineers, and anyone interested in the dynamics of rotating systems and frictional forces on inclined surfaces.
danago
http://img357.imageshack.us/img357/6476/80028206ag6.gif
This question had me a little confused. I started by drawing a free body diagram of the block:
http://img246.imageshack.us/img246/9121/59804825wo9.gif
Where W is the weight, N is the normal force and F is the friction force.
Because the cone is spinning, does that mean there will also be a frictional force in the direction extending out/into the page?
Since the block will effectively be moving in a circular path, its net acceleration will be given by:
<br /> <br /> \overrightarrow {\bf{a}} = r\alpha \underline {\widehat{\bf{t}}} + \omega ^2 r\widehat{\underline {\bf{n}} }<br /> <br />
The question states that the angular acceleration increases very slowly? Can i approximate this to be zero?
Thanks in advance for any help.
Dan.
Yes, the frictional force will apply along the surface on the cone. The question asks you the maximum angular velocity with which the cone can be spinning so that the block does not slip. The angular velocity is said to very slowly increase just so that we may assume it is continuous, and can take every angular velocity before the critical velocity at which the block slips. You can not approximate it with zero because then the angular velocity doesn't increase at all, which is critical to the question. Sadly, I know enough to tell you what's wrong, but not enough to tell you how to proceed =[ .
You'll have to, because they don't tell you what it is.
9K
  • · Replies 20 ·
