lone21
- Messages
- 3
- Reaction score
- 0
A 2.00 kg block is at rest at the top of a frictionless inclined plane. The block
is released and collides with another 1.00 kg block at the bottom of the ramp. The two
blocks experience a perfectly elastic collision and the 1.00 kg block goes frictionless loop
with a radius of 5.00 m. After exiting the loop, the blocks slide along a surface where the
1. If the 1.00 kg block just makes it around the loop, what was the speed of the block?
2. What was the speed of the 2.00 kg block that was sliding down the ramp just before
3.What was the initial height of the 2.00 kg block before it started to move?
4. How far will the two blocks slide before coming to rest after exiting the loop?
K=1/2mVi^2
Velocity around the loop = sqrt(rg)
1/2mVi^2 + mgh = 1/2mVf^2 + mgh
Elastic collision
m1V1i+m2V2i= m1V1f+m2V2f
I solved the first part of the problem by taking the velocity around the loop
which is 7m/s
then using the other equation solved for the velocity when the block is not in the loop
so it becomes 1/2 (1) (7m/s)^2 + (1)(9.8)(10) = 1/2 (1)Vf^2 + (1)(9,8)(0)
see the initial velocity will be 7m/s at the height of the loop and i want to figure out the final velocity when the height is at zero.
I solve for vf and get 15.65m/s
After this i get stuck, I know that the veloctiy at zero before and after the loop are the same for the 1kg block, but I don't know how to solve for the Vinitial or Vfinal in the elastic collision equation.
2kgV1i=1kg(15.65m/s) - 2kgV2f
also there's the conservation equation
1/2m1(V1i)^2=1/2m1(V1f)^2+1/2m2(v2f)^2
I'm not sure where I should go from here, I've tried substituting for variables but I still get stuck with bad answers, please help
