Blocks with a 'x' force and a 'y' acceleration
The discussion centers on calculating the magnitude of the second force acting on a 2.8 kg object accelerating at 3.8 m/s² in the positive y direction, with a known force of 6.5 N acting in the positive x direction. The correct approach involves using Newton's second law, expressed in component form: ƩFx = max and ƩFy = may. The magnitude of the second force, f2, is determined using the equation |f2| = √(f2x² + f2y²), where f2x and f2y are derived from the net forces in the x and y directions, respectively.
  • Newton's Second Law of Motion
  • Vector decomposition of forces
  • Basic algebra for solving equations
  • Understanding of force and acceleration units
  • Study vector decomposition in physics problems
  • Learn how to apply Newton's laws in two dimensions
  • Explore examples of force calculations in different directions
  • Practice solving problems involving multiple forces and accelerations
Students studying physics, particularly those focusing on mechanics, as well as educators looking to enhance their teaching of force and motion concepts.
Robertoalva
1. Two forces are the only forces acting on a 2.8 kg object which moves with an acceleration of 3.8 m/s^2 in the positive y direction. One of the forces acts in the positive x direction and has a magnitude of 6.5 N.What is the magnitude of the other force f2?
F=ma
I suppose that to get the second force i just have to multiply F[SUB/]2[SUB/]=ma=(2.8kg)(3.8m/s^2) right?
No. In the equation F = ma, F is the net force (the vector sum of all of the forces acting on the object). For a problem like this, it will be a good idea to express the second law in component form:
ƩFx = max
ƩFy = may
Robertoalva said:
Problem statement:
F=ma
I suppose that to get the second force i just have to multiply F2=ma=(2.8kg)(3.8m/s^2) right?
[Took the liberty of fixing up some format errors.]
That gets you almost half way there. :smile: But not all of the way there. :frown:
Is there a non-zero component of the object's acceleration in the x-direction? What does that say about the sum of the forces in the x-direction?
[Edit: Tsny beat me again. Serves me right for typing too slow.]
so basically, the whole thing is accelerating in a sum vector ? that i have to find with f2=sqrt(fx^2 + fy^2)?
Yes. See if you can find f2x and f2y.
well, I already have fx and now i have to get fy= m*ay and then i just substitute the values of fx and fy in f2=sqrt(fx^2 + fy^2) am I correct?
I think so. Just to make sure you're going through the reasoning correctly, the equation ƩFy = may would be expressed as f1y + f2y = may, right? But then you already know the value of f1y, so you can find f2y. I believe that's how you are thinking, just wanted to make sure.
no! i had another reasoning. i was going to just get fy= ma=(2.8 kg)(3.8m/s^2) and then because they give me already fx = 6.5 N ia was just going to get the vector sum, F= sqrt(fx^2 + fy^2)
it was very different!
Oh, not good. There are two forces acting on the object: f1 and f2. Each force is a vector. You need to find the magnitude of one of those forces, namely |f2| = √(f2x2+ f2y2) .
So you need to find f2x and f2y. You are not given either of those. But you can find them by setting up ƩFx = max and solving for f2x and setting up ƩFy = may and solving for f2y.
I think you are both talking about the same thing. TSny's notation is less ambiguous though.
oh! yes, we're talking about the same thing, but the only thing that i didn't quiet understood in TSny's notations were the f2's. i thought that TSny's was trying to tell me that i had to get 2 forces which were f1 and f2 and each one was fx1=m*ay and f1=m*ax, and for fy2=m*ay and fx2= m*ax. but know i see that he's just telling me that:
|f2| = √(f2x2+ f2y2)
f2x= Fx /m = ax
f2y= Fy=m*ay
right?
Robertoalva said:
f2x= Fx /m = ax
f2y= Fy=m*ay
right?
I'm afraid that's not right at all. Think about it...How can a force equal an acceleration? They don't even have the same dimensions (units). Also, it's not clear what the symbols Fx and Fy mean here.
Let's take it kind of slowly. Consider the fundamental equation ƩFx = max. Can you write out the left hand side of the equation using one or more of the symbols: f1x, f2x, f1y, and f2y?
f2x-f1x=m*ax ?
Robertoalva said:
f2x-f1x=m*ax ?
That's close, but why the minus sign on the left? The notation ƩFx means to add together all of the x-components of all of the forces acting on the object. That gives the total x-component of force acting on the object and it's that total x-component of force that equals max.
So, what should the equation ƩFx = max look like?
fx1+fx2=m*ax
Robertoalva said:
fx1+fx2=m*ax
Very good. Now, what is the unkown quantity in this equation for which you want to solve? What are the numerical values of all of the other quantities?
dude! i already solved this equation ! i just did the following thing:
f2=sqrt((f given)^2 + (mass*acceleration y)^2)
i got it right
Getting the right answer is one thing, clearly understanding the solution is another. Do you feel that it is all clear now?
i think that what you were trying to teach me was deriving all the formulas to get what i did right?
Yes, I just wanted to make sure you understood the thought process.
For example, suppose f1 was still 6.5 N but in a direction of 30o above the positive x-direction. Everything else in the problem is kept the same. Would you still be able to solve for the magnitude of f2? If so, then I think you are understanding it.
  • · Replies 33 ·
  • · Replies 21 ·
