Body thrown with v0 - find v0 that doubles prev max height
The discussion centers on determining the initial velocity, v0, required to double the maximum height attained by a body thrown vertically. The maximum height is expressed as h = v0²/64, where gravitational acceleration is g = 32 ft/s². To achieve double the height, the equation v² = 64h must be manipulated, leading to the conclusion that the new velocity, v2, must equal v1 multiplied by the square root of 2, resulting in v2 = 8√(2h1). This method provides a clear path to calculating the necessary initial velocity for the desired height.
  • Understanding of kinematic equations, specifically vf² = vi² + 2as.
  • Knowledge of gravitational acceleration, particularly g = 32 ft/s².
  • Familiarity with algebraic manipulation of equations.
  • Basic concepts of projectile motion and maximum height calculations.
  • Learn how to derive maximum height equations in projectile motion.
  • Study the implications of gravitational acceleration on vertical motion.
  • Explore the use of kinematic equations in different contexts, such as horizontal motion.
  • Investigate the effects of varying initial velocities on projectile trajectories.
Students studying physics, educators teaching kinematics, and anyone interested in understanding the principles of projectile motion and height calculations.
physicsnnewbie
A body is thrown into the air with an initial velocity of v0. What initial velocity is required to double the maximum height previously attained?
I found the max height v02/64 at v0 by solving for 't' in the velocity equation when 'v' = 0, and subbing that for 't' in the height equation and solving. I then multiplied this by 2 and set it to the height and tried to solve for v0 and ended up with v02 = -512t2 + 32tv0. I then solved for v0 and ended up with v0 = 16t. Do I need to somehow find 't' or did i stray off course somewhere and end up with the wrong answer?
hi physicsnnewbie! :smile:
wouldn't it be easier to use the other constant acceleration equation, vf2 = vi2 + 2as ? :wink:
You were good up until here. Now, all you need to do is figure out what number you need to multiply v0 by in order to make the maximum height double.
in other words: find a constant C such that (Cv0)2/64=2(v02/64)
tim, I tried the formula you mentioned but couldn't obtain the correct answer. Maybe I did something wrong. Beaker, it took me a while to figure out your equation, because i kept reading it as CV02/64 = 2V02/64 without paying enough attention to the parenthesis and i was thinking doesn't c just equal 2? :p.
Tim's method also works, and may be of greater use to you in the future rather than the perhaps easier yet less universal method presented instead.
Under your initial condition of v0 yielding a height, h, and noting that at the maximum height, vf=0, you have v0^2=2*a*h (because you assume the displacement, h up, is in the positive direction, a is then negative). Then in the second case, you have a new velocity, C*v0 and a height 2*h. Working with the same idea and using the relationship you established in the first case, you can solve that as well.
A quick way to get the answer. (I'll put some subscripts on the variables.)
You found that throwing some body vertically into the air with a velocity, v1,
will cause the body to attain a maximum height, h1, (which is the height of the body, when the velocity becomes zero).
Your solution was: h1 = v12/64, which is correct for a gravitational acceleration, g = 32 ft/s2.
Since you solved this for arbitrary initial velocity, it's true that in general that a maximum height, h = v2/64 will be attained by a body thrown up vertically with velocity, v.
Solve this equation for the launch velocity, v, needed for the body to attain a height, h, above the ground.
v = √(64 · h) = 8·√(h).
Specifically, v1 = 8·√(h1).
So if you want h2 = 2·h1, then :
v2 = 8·√(h2)
= 8·√(2·h1)​
To get a decent looking answer divide this equation by v1 = 8·√(h1).
11K
  • · Replies 18 ·
