Books on differential geometry with proofs and exercises
9 replies · 5K views
WittyName
As the title says. Can anyone recommend me some good books for differential geometry(preferably ones with proofs and examples/exercises)?
What level should the books be?? Undergrad, grad? Do you know topology, analysis, linear algebra,...??
jedishrfu said:
https://www.amazon.com/dp/0486667219/?tag=pfamazon01-20
or take your pic:
and an ebook to get started right away:
http://samizdat.mines.edu/difgeom/Shr3b.pdf
Thanks i'll be sure to check them out.
It's an undergrad course but i want to do some preliminary reading. Yes to both analysis and linear algebra, but no to topology.
I also like do Carmo for the basic curves and surfaces stuff. Once you learn a little topology (not much) you should check out Spivak (especially Volumes 1 and 2). Spivak's differential geometry books are awesome.
The book by Do Carmo was pretty good. I used it as a supplement in my differential geometry course in college, although it was a little bit advanced for me because it was the first time that I had ever seen any of the material.
A great introductory book is Barrett O'Neil's Elementary Differential Geometry. It has a lot of worked problems and solutions in the back so you can check yourself.
For more problems, try the Schaum's Outline of Differential Geometry
There isn't a perfect overlap of content and notation between these books, but I found that it was more than enough to do well in differential geometry. One thing to remember (which I learned the hard way!) is that 80% of the difficulty is understanding notation! So, the more resources, the better.
If you're coming at this from a physicist's point of view, both Nakahara's and Chris Isham's books on differential geometry are great. (Google is your friend, etc.)
