Boolean Algebra Proof Statement
The discussion revolves around proving a Boolean algebra identity: AD' + A'B + C'D + B'C = (A' + B' + C' + D')(A + B + C + D). Participants express difficulty in simplifying the left-hand side and suggest using algebraic manipulation and DeMorgan's Theorem. A K-map is referenced, indicating that both sides of the equation are equivalent, but members struggle to find a straightforward algebraic proof. Suggestions include focusing on replacing ANDs with ORs and using brackets to simplify the expression, yet confusion remains about achieving the proof without ANDs. The conversation highlights the complexity of Boolean proofs and the need for clarity in algebraic manipulation techniques.
cyenko
Prove the identity of the following Boolean equation using algebraic manipulation:
DeMorgan's Theorem: (A + B)' = A'B'
I tried simplifying the equation to the following:
AD' + A'B + C'D + B'C = A'D + A'B + C'D+ B'C + (A'C + A'D + B'A + B'D + C'A + C'B + D'B + D'C)
However, this doesn't appear to be going anywhere. What kills me is the fact that I have no way of knowing whether or not the path I'm following will turn out or not.
My TA mentioned that the left hand side should be modified with OR statements (+), however I'm not sure where to begin. Any help would be greatly appreciated.
Interesting. I can easily see w/ a Kmap that the statement is true, but like you, I draw a blank when trying to prove it algebraically. DeMorgan doesn't seem to help and I don't know what else to try. There's probably something simple that we're both forgetting or overlooking.
I'm glad I'm not the only one who would have difficulty solving this proof. The problem is still open, for anyone who is willing to help me!
Bumping for help.
Well, from the K-map they are both equal to (ABCD + A'B'C'D)', which we know immediately anyway from applying DeMorgan a couple of times to the RHS.
The K-map shows us there is plenty of overlap in the RHS, so we could try to unravel that...
(A'+B'+C'+D')(A+B+C+D) = A'B + A'C + A'D + B'A + B'C + B'D + C'A + C'B + C'D + D'A + D'B + D'C
What we might do is show that (for example) B'A is covered by AD' + C'D + B'C. So:
AD' + C'D + B'C
= AD' + AB'D' + C'D + AB'C'D + B'C + AB'CD
= AD' + C'D + B'C + AB'(D' + C'D + CD)
= AD' + C'D + B'C + AB'(D'+D)
And we can similarly conjure the other terms required out of the LHS. But it's a long, long way round to do them all explicitly; there probably is a better method. Perhaps you could do this with some kind of general analysis of PQ'.
Focus on the left side, AD' +[/color] A'B + [/color]C'D +[/color] B'C
♦ Replace each AND with OR, you'll need to bring in some brackets
♦ Replace each red OR with AND
♦ Remove the brackets (i.e., "multiply it out") and tidy up, and you'll be left with the OR of two simple terms
You should see your way to be able to finish now. :wink:
I'm confused. If you have the term
A AND NOT B
How, in terms of just the variables A and B, can you create an equivalent with no AND but any number of ORs ?
Neat. I like it, 6 lines or so.
A AND NOT B
by using DeMorgan's rule: AB' = (A'+B)'
A and not-B = not-(not-A or B)
well, yeah, but there is then a NOT over the whole thing, so you haven't quite separated out the terms individually. That's what I meant. As I said in my original post, I don't see how DeMorgan helps, but apparently I'm missing something.
There is indeed a NOT over the whole thing - but no ANDs, which is all that was promised. :wink:
Here's the first step of NascentOxygen's method, for enlightenment:
AD' + A'B + C'D + B'C = (A' + D)' + (A + B')' + (B + C')' + (C + D')'
