Born-Oppenheimer approximation confusion
  • Context: Graduate
  • Thread starter Thread starter VortexLattice
    Approximation Confusion
The forum discussion revolves around the Born-Oppenheimer approximation, which allows for the treatment of ions as stationary relative to faster-moving electrons in quantum mechanical systems. Participants clarify that the potential energy terms, such as ##V_{ei}## and ##V_{ii}##, can be treated as multiplicative operators, affecting the wavefunctions of both electrons and ions. The confusion arises regarding the placement of these terms in the eigenvalue equation, specifically how they influence the separation of the wavefunction into electronic and nuclear components. Ultimately, the discussion emphasizes the importance of understanding the approximation's implications on the Hamiltonian and wavefunction formulation.
  • Understanding of quantum mechanics and wavefunctions
  • Familiarity with the Born-Oppenheimer approximation
  • Knowledge of Hamiltonian mechanics in quantum systems
  • Basic concepts of potential energy in multi-particle systems
  • Study the mathematical formulation of the Born-Oppenheimer approximation
  • Explore Hamiltonian mechanics in quantum systems
  • Learn about the implications of potential energy terms in quantum mechanics
  • Investigate the role of wavefunction separation in quantum chemistry
Students and researchers in quantum mechanics, particularly those studying molecular dynamics and quantum chemistry, will benefit from this discussion. It is also relevant for physicists and chemists interested in the mathematical foundations of the Born-Oppenheimer approximation.
VortexLattice
Hi, I'm reading about the Born-Oppenheimer approximation for a solid and they're doing the formalism of it. They say that we can basically consider the ions stationary with respect to the electrons because they move so little and so slowly in comparison to them.
They say that ##R_i## are the positions of the ions and ##r_j## are the positions of the electrons, ##P_i## are the momenta of the ions, ##p_j## are the momenta of the electrons (all vectors but I'm just writing them like this here). Then they say that we'll look at "core" electrons separately from "valence" electrons, because core ones just hang out by the nuclei while valence ones move around. Given all this, the hamiltonian is:
##H = \sum\limits_i \frac{P_i^2}{2M} + \sum\limits_{j = cond. elecs} \frac{p_j^2}{2m} + \sum\limits_{i,i'} V_{i,i'}(|R_i - R_{i'}|) + (e^2/2) \sum\limits_{j,j'=cond. elecs} \frac{1}{|r_j - r_{j'}|} + \sum\limits_{i,j} V_{ei}(|r_j - R_i|) + E_{core}##
(where ##E_{core}## is the energy of the "core" electrons that are "attached" to the nuclei.)
Then they rewrite this as:
##H = T_i + T_e + V_{ii} + V_{ee} + V_{ei} + E_{core}##
Then they say that we can write the full wavefunction as a combination of two functions (here, ##r## and ##R## are the sets of the positions of all the electrons/ions, not single ones):
##\Psi(r,R) = \sum\limits_n \Phi_n(R) \Psi_{e,n}(r,R)##
Then, they just do the eigenvalue equation, ##H\Psi = E\Psi##:
##(T_i + V_{ii} + E_{core})\Psi + \sum\limits_n \Phi_n (T_e + V_{ee} + V_{ei})\Psi_{e,n}(r,R) = E\Psi##
In the second term, the part with the explicit sum, they put ##\Phi_n## out in front because the operators directly following it "only operate on the electron part of the product wavefunction", according to my book. But here's my confusion: doesn't ##V_{ei}## act on the ion part of the wave function? It was defined as ##\sum\limits_{i,j} V_{ei}(|r_j - R_i|)##, which has that ##R_i## in it. What am I missing?
Thank you!
VortexLattice said:
What am I missing?
You are more or less missing the Born-Oppenheimer approximation itself. Recall what you said in the beginning:
So your assumption is basically that your electron distribution does not drag your ions around. The distribution of the ions will stay as it is. Therefore you can treat the position of the ions as a parameter instead of a variable. So the potential will only depend on these positions, but not act on them.
If you want a more intuitive explanation, what you do is not solving the coupled system of ions and electrons, but getting a solution for the electron system for a fixed set of ion positions.
No, up to what VortexLattice has described, the whole wavefunction is still completely general and the BO approximation has not been invoked, yet.
V_ei clearly acts also on the nuclear wavefunction, but as it is a multiplicative operator, it does not matter whether it appears in front or after ##\Phi_n##.
Oh sorry. Maybe I misread and should stop posting after midnight.
Hmmm, this doesn't seem consistent though. If ##V_{ei} = \sum\limits_{i,j} V_{ei}(|r_j - R_i|)##, I see what you're saying about the order of the operator ##R_i## not mattering (that's what you're saying, right?), but then what about ##V_{ii}##? That also just has multiplicative factors of ##R##: ##V_{ii} = \sum\limits_{i,i'} V_{i,i'}(|R_i - R_{i'}|)##.
So why isn't that in the second term as well?
Thank you!
Feel free to put it there!
But the ordering chosen is not a matter of mathematical necessity but depends on the approximations which will probably introduced in the continuation of the argument.
Hmmm, but that changes the final result! The final result they reach for this is separating ##\Phi_n## and ##\Psi_{e,n}## by separating this equation:
and after doing many manipulations, get:
##(T_i + V_{ii} + E_{core} + E_{e,n})\Phi_n = E_n\Phi_n##
and
##(T_e + V_{ee} + V_{ei})\Psi_{e,n}(r,R) = E_{e,n}\Psi_{e,n}(r,R)##
So, the placement of ##V_{ei}## makes it end up in either the nuclear or electronic equation.
V_ei depends on both nuclear and electronic coordinates. You want an equation for ##\Phi_n## which does not contain electronic coordinates. Likewise you want an equation for ##\Psi_{e,n}## which does not contain derivatives with respect to R.
