Undergrad How Do Boundary Conditions Change When a Beam Is Fixed at x=L Instead of x=0?
This discussion addresses the boundary conditions of a one-dimensional beam fixed at different points along its length. When a beam of length L is fixed at x=0, the boundary conditions are defined as u(0)=0 and SE(L) du/dx(L)=F for tension, and SE(L) du/dx(L)=-F for compression. Conversely, if the beam is fixed at x=L, the conditions change to u(L)=0 and SE(0) du/dx(0)=-F for tension, and SE(0) du/dx(0)=F for compression. The sign of the force F is critical, with conventions varying based on the direction of the forces applied.
  • Understanding of one-dimensional beam theory
  • Familiarity with boundary conditions in structural mechanics
  • Knowledge of Young's modulus (E) and its application
  • Basic principles of tension and compression forces
  • Study the implications of boundary conditions in finite element analysis (FEA)
  • Learn about the effects of varying boundary conditions on beam deflection
  • Explore the concept of axial loads and their impact on beam behavior
  • Investigate different conventions for force direction in structural analysis
Structural engineers, mechanical engineers, and students studying mechanics of materials will benefit from this discussion, particularly those focusing on beam analysis and boundary condition effects.
papanatas
Hi! I have a question related to boundary condition in a one dimensional beam subject to compression and traction efforts.
In my class notes I have the following: If we consider a 1D beam of length L which is fixed at x=0 and subject to an effort F at x=0 we have the following boundary condition depending if the effort is a compression or a traction effort:
u(0)=0 ; SE(L) \frac{du}{dx}(L)=F if F is a traction effortu(0)=0 ; SE(L) \frac{du}{dx}(L)=-F if F is a traction effort
Where S is the beam section and E is the Young constant.My question is the following: what happens with boundary conditions if the beam is fixed not in x=0 but in x=L? In my opinion it would be the following:
u(L)=0 ; SE(0) \frac{du}{dx}(0)=-F if F is a traction effortu(L)=0 ; SE(0) \frac{du}{dx}(0)=F if F is a traction effort
What I did was simply put "0" instead of "L" and change the F sign: in this situation F would be positive if we have a compression effort and negative if we have a traction one. Is this correct?
Thank you very much and sorry for my English...
the proper term here in English is tension, not traction.
In my class notes I have the following: If we consider a 1D beam of length L which is fixed at x=0 and subject to an effort F at x=0 we have the following boundary condition depending if the effort is a compression or a traction tension[/color] effort:
u(0)=0 ; SE(L) \frac{du}{dx}(L)=F if F is a traction tension[/color] effortu(0)=0 ; SE(L) \frac{du}{dx}(L)=-F if F is a traction compression[/color] effort
S is the area of the beam's cross section, usually called 'A'.
u(L)=0 ; SE(0) \frac{du}{dx}(0)=-F if F is a traction tension effortu(L)=0 ; SE(0) \frac{du}{dx}(0)=F if F is a tractioncompression effort
What I did was simply put "0" instead of "L" and change the F sign: in this situation F would be positive if we have a compression effort and negative if we have a tractiontension one. Is this correct?
assuming forces pointing right are positive and left negative, then, yes. Other conventions assume that tension forces are positive and compression forces are negative. That's why it's best to show the direction of the forces in a sketch.
No apology necessary.
  • · Replies 22 ·
