Is B(X,Y) a Vector Space of Bounded Linear Operators over the Same Scalar Field?
To show that B(X,Y) is a vector space, one must verify that it satisfies the four axioms of a vector space, including closure under addition and scalar multiplication. The discussion emphasizes defining the operations for bounded linear operators, specifically how to express the sum of two linear transformations and the zero transformation. Participants explore whether the properties of associativity, commutativity, and the existence of additive inverses hold for these operators. The relationship between the vector spaces X and Y over the same scalar field is also clarified, indicating that this shared field is essential for establishing L(X,Y) as a vector space. Ultimately, the conversation revolves around confirming the necessary conditions for B(X,Y) to be a subspace of L(X,Y).
gtfitzpatrick
Show L(X,Y) is a vector space. Then if X,Y are n.l.s. over the same scalar field define B(X,Y) = set of all bounded linear operators for X and Y
Show B(X,Y) is a vector space(actually a subspace of L(X,Y)
im not sure if i have taken this question down properly.
To prove some set is a vector space you have to show the 4 axiom of a vector space hold. namely-for u, v, w be arbitrary vectors in V, and a, b be scalars in F
1. u + (v + w) = (u + v) + w.
2. v + w = w + v.
3. There exists an element 0 ∈ V, called the zero vector, such that v + 0 = v for all v ∈ V.
Inverse elements of addition For all v ∈ V, there exists an element w ∈ V, called the additive inverse of v, such that v + w = 0.
4. a(v + w) = av + aw
Im not sure how to progress with this
Well, how about doing what you just said!
If F and G are linear transformations from vector space X to vector space Y, F: u-> F(v) and G:u-> G(u), how would you define "F+ G"? F+ G would map a vector u in X to what vector in Y? Does that satisfy F+(G+ H)= (F+ G)+ H for any linear transformations, from X to Y, F, G, and H? Do that satsfy F+ G= G+ F? What would the "0" linear transformation be? What would the adidtive inverse of linear transformation F be?
If F is a linear transformation from X to Y, F:u->F(u), and a is a number how would you define aF? aF would map vector v in X to what vector in Y?
Does that satisfy a(F+ G)= aF+ aG for linear transformations F and G?
Im not sure how to show these axioms hold. When it says the are over the same scalar field it is saying the they are more or less the same? so if X is a vector space and Y is a vector space, then because they are over the same scalar field L(X,Y) is also a vector space?
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 43 ·
