What Are the Miller Indices for the Bragg Reflections?
  • Thread starter Thread starter cepheid
    Bragg Reflection
The discussion revolves around calculating the lattice parameter and Miller indices for an alkali halide using the Debye-Scherrer technique and provided Bragg angles. Participants express confusion regarding the relationship between the angles, the diffraction data, and the calculation of the lattice parameter 'a'. The Bragg condition and the formula for d-spacing in cubic lattices are noted as essential for solving the problem. There is uncertainty about whether the lines correspond to reflections from the same or different atomic planes. The thread concludes with a mention of the professor providing solutions, but they are not available for sharing.
cepheid
Staff Emeritus
An alkali halide is studied with the Debye-Scherrer technique and Cu K_{\alpha} radiation. The Bragg angles for the first five lines (in degrees) are 10.83, 15.39, 18.99, 22.07, and 24.84. Calculate
(a) The lattice parameter
(b) The Miller indices for the planes producing the mentioned diffraction beams
(c) The Miller index for the line(s) producing the largest allowable Bragg angle.
Added in by the prof as an afterthought:
\textrm{Take} \ \ \lambda[\textrm{Cu} \ K_{\alpha}] = 1.542 \ \ \textrm{\AA}
As far as I can tell they are:
The Bragg condition for diffraction:
2d \sin \theta = n \lambda
A previously derived result that for a cubic lattice with lattice constant a, the spacing between successive (hkl) places is given by:
d = a[h^2 + k^2 + l^2]^{-\frac{1}{2}}
I'm pretty lost here. Is the lattice parameter (cubic unit cell dimension) 'a' supposed to be arrived at somehow independently of the diffaction data?
The Debye-Scherrer technique was never discussed in class. I looked it up and discovered that rather than varying the angle of incidence of a single beam on the crystal face, the beam is shone at a sample of many ground up crystals of random orientations in order to cover all incidence angles simultaneously (or something like that!) This leads me to wonder how you can tell which line is due to which angle, but I'm not going to look into it further. I think the whole idea is that the specific experimental technique used to produce the data is not relevant to the problem, which is why the prof didn't have a problem introducing terminology he hadn't defined (although he doesn't have a problem doing that anyway! )
As for part b, the logical thing to do would seem to be to try and use the data to calculate n. But how is that done without knowing what d is? Which requires knowing a...
I don't even understand how x-ray diffraction works. Is each line associated with a different angle (one of the five given)? If so, does each line correspond to reflection off the *same* atomic plane, but just a different incidence angles? Or is each line produced by reflections from different planes with different Miller indices!
Hey everyone,
Don't worry about it. It's too late. The prof has handed out solutions though. I can post them here if anyone else is curious.
Thanks.
could you please post the solution!
Thanks
No, I can't, because this thread is three years old!
18K
