Brainstorming concept for mobile solar array
In summary, this project sounds like it could be a lot of work. It sounds like you might want to think about different options for storing and deploying the panels.
yahastu
79
Hello! I'm in the early process of brainstorming plans for a roof mounted mobile solar array as a DIY project. The host vehicle will be a 8.5'x20' cargo trailer. On the roof I can fit an array of 6x solar panels that is almost exactly 8.5x20. However, I actually want to create 3 such arrays, which will either fold out or roll out to the sides, so there will be a total of 18x panels when fully deployed (it will be about 10 kw). There are a few interesting engineering challenges here that I will outline below:
1) Reinforcing of the roof to handle the load. The weight of the panels and some minimal racking comes out to about 1000 lbs. To support this load I plan to reinforce it, probably using aluminum I-beams. If anyone has suggestions on the best way to frame out the support structure (from a theoretical structural perspective), I'd be happy to hear it, as well as any tips for how I might select I-beam size in order to achieve the necessary load bearing capacity.
2) The biggest question I am still pondering is the best way to store and deploy the panels. Each "super" panel will be basically 8.5x20 feet long, and will weigh approximately 350 lbs (including some minimal racking necessary to connect them). There are a few different configurations I'm considering:
a) I could mount 1 super panel on the roof, and 2 super panels on either side of the cargo trailer, attached by heavy duty hinges at the top edge. To deploy the side panels, I'd just have to lift them up 90 degrees and then fold out support legs. This would be the simplest to build, but I'm not a huge fan of this because the panels would cover any windows or doors on the side of the cargo trailer when done, in addition to attracting a lot of unwanted attention when hauling the trailer around.
b) I could have the two side panels fold out from the roof. This keeps my windows and doors unobstructed, but my main concern with this approach is the potential difficulty of deployment. I would have to climb up on a ladder to access the roof to unfold them, but with each super panel weighing about 350 lbs, it wouldn't be easy to life them up and fold them down. They could have legs that drop out from a gravity assist, so that would help, but lifting these panels up and gently opening them 180 degrees in a controlled manner would be difficult. Perhaps it would be possible to design some sort of pulley/winch system, although I don't have any specific idea of how that would look.
c) I could have the side panels on linear tracks that allow them to slide out horizontally from the roof. The advantage here is that they don't need to be physically lifted and rotated, so potentially easier to deploy given their large weight. It would be difficult to make them slide out from 100% overlap to 0% overlap, and one would need to be careful to deploy support legs before it gets to 0% overlap so there isn't too much stress put on the edge. I'm also not sure about options for a linear track that would be strong enough to support this weight, and not add excessive height.
Thanks for listening. I welcome any insights or ideas you might have!
Likes Greg Bernhardt
That sounds like an interesting project. But it sounds to me that mounting them into super panels creates more problems than it is worth. I'm thinking of exactly the problems you said with weight and size.
Have you considered a lightweight frame that would allow you to remove the panels one at a time for storage, then collapse the frame?
Weather could be a factor. The wind forces on a 8x20 super panel during a storm could be very powerful. Have you considered that?If you do mount them into super panels, you many need leverage or power to manipulate them for storage. Perhaps something like hydraulic or pneumatic actuators. The engineering design for that is not trivial. What experience do you have in mechanical design?
If you not in a hurricane area, you can use a design wind load of 25 pounds per square foot to get started. In a hurricane area, use twice that. That wind load is trying to tear the panels off, push the trailer away, tip the trailer over, or even make it fly. You need to design for all of those cases. Keep in mind that the wind can come from any direction.
If you mount it to the roof of the trailer, you may also need to reinforce the walls. I strongly suggest that you calculate the height of the center of gravity before towing it.
Likes anorlunda
1. What is a mobile solar array?
A mobile solar array is a portable device that can generate electricity from the sun's energy. It is typically made up of solar panels, a battery, and an inverter, and can be easily transported and set up in different locations.
2. How does a mobile solar array work?
A mobile solar array works by converting sunlight into electricity through the use of photovoltaic cells. These cells are made of silicon and absorb the sun's energy, which is then converted into direct current (DC) electricity. The inverter then converts the DC electricity into alternating current (AC) electricity, which can be used to power devices or stored in a battery for later use.
3. What are the benefits of using a mobile solar array?
There are several benefits to using a mobile solar array, including its portability and versatility. It can be used in remote locations or during emergencies to power devices or provide electricity for basic needs. It is also a sustainable and renewable source of energy, reducing the reliance on fossil fuels and minimizing carbon emissions.
4. What are some potential applications for a mobile solar array?
A mobile solar array can be used for a variety of applications, including camping or outdoor activities, disaster relief efforts, powering remote or off-grid locations, and providing temporary electricity for events or construction sites. It can also be used as a backup power source for homes or businesses in case of power outages.
5. Are there any limitations to using a mobile solar array?
One limitation of a mobile solar array is its dependence on sunlight. It may not be able to generate electricity on cloudy or rainy days, and its efficiency may vary depending on the location and time of day. Additionally, the initial cost of purchasing a mobile solar array may be higher compared to traditional energy sources, although it can provide long-term cost savings and environmental benefits.
  • DIY Projects
  • DIY Projects
  • Mechanical Engineering
  • Mechanics
  • Electrical Engineering
9K
