Understanding Gauss's Law: Where Does the Argument Break Down?
The discussion revolves around the application and implications of Gauss's Law in the context of a uniform charge density extending through all space. Participants explore the theoretical underpinnings, assumptions, and potential breakdowns of the argument when considering infinite charge distributions, examining both the integral and differential forms of Gauss's Law.
  • Some participants argue that by symmetry, the electric field should be zero in all space for a uniform charge density, but this contradicts Gauss's Law, which suggests a non-zero divergence.
  • Others propose that the integral form of Gauss's Law assumes the average charge density outside a closed surface is zero, suggesting a modified approach that incorporates an average charge density term.
  • Some participants question the justification for introducing the average charge density term, ##\rho_0##, arguing it seems artificial and only relevant in the context of infinite charge distributions.
  • There is a discussion about the choice of Gaussian surfaces and the symmetry assumptions made regarding the electric field, particularly in the limit of infinite radius.
  • One participant mentions the concept of a "non-neutral Coulomb gas" in statistical physics, relating it to the problem at hand and discussing cutoffs in calculations.
  • Several participants express skepticism about the assumption that the average charge density can be considered negligible or zero, questioning its validity and implications for the argument.
  • Some assert that Gauss's Law is exact in classical electrostatics, while others contend that it is an approximation that may not hold under certain conditions, such as relativistic or quantum effects.
Participants do not reach a consensus on the validity of the assumptions surrounding Gauss's Law or the role of the average charge density term. Multiple competing views remain regarding the nature of the argument's breakdown and the applicability of Gauss's Law in this context.
The discussion highlights limitations related to the assumptions made about charge density, the implications of infinite distributions, and the conditions under which Gauss's Law is considered valid or approximate. The nature of the average charge density term, ##\rho_0##, remains ambiguous and contentious among participants.
  • #61
This question is actually of significant historical importance, but in the context of Newton's gravity, rather than Maxwell's equations. The basic issue for static electric fields is of course the same.
Newton assumed the universe should be infinite and homogeneous, and he came to the same resolution as NFuller, that the gravitational field should be zero by symmetry arguments-- if it doesn't know how to point, it must be zero. He regarded that as a deeper principle than the equations he was solving, so although the issues about the problems with applying symmetry arguments to Gauss' law that have been raised are entirely valid, Newton, who knew the necessary version of Gauss' law (i.e. that a spherically symmetric mass distribution had to produce a field toward the origin that depended only on the enclosed charge), felt the symmetry argument supercedes the mathematics of forming a proper solution. Perhaps it could be said he felt the boundary condition must be whatever is necessary to produce a zero field, because a field that doesn't know which way to point must be zero. The point is, Newton felt his gravity was consistent with a static universe, and this mistake caused him to miss that the universe should be dynamical.
Of course general relativity reaches a different conclusion about an infinite homogeneous mass distribution, but that's a different theory, so it's easy to overlook that Newton could also have realized the universe should be dynamical. I have always felt that Newton was basically wrong, in the sense that even if Newton's own theory of gravity were applicable, the gravitational field should not be taken to be zero, and the universe could not be static. I think the problem is in the implicit assumption that the field must be a "thing," handed to us without our input or participation, so must be unique. But this is never actually required in empirical sciences-- we only need the observations to come out as predicted, including whatever input or participation we need to supply. The observation is that a homogeneous mass distribution that is bounded and stationary undergoes contraction, and the timescale for density increase is given by 1/sqrt(rho*G). A similar expression would hold for the expansion of a homogeneous charge distribution with fixed charge-to-mass ratio. Notice this timescale depends on the local density, so the global scale is irrelevant and should exhibit no problems even when extended to infinity. The contraction/expansion timescale is what must be unique, not the fields, because observing fields requires a somewhat arbitrary calibration procedure, which may need to dovetail with the frame of reference or perspective of the observer.
So I think the physical problem here is in the implicit assumption that the field must be unique. It seems odd that the field you calculate could depend on where you set the origin, but that's not odd if the behavior you are trying to understand (contraction or expansion toward or away from some origin) also depends on where you set the origin-- the timescale for the contraction or expansion does not depend on where you set the origin. Also, the OP was bothered by the increasing magnitude of the field as you go away from the origin, but this can depend on the calibration procedure you use to measure fields, and there is no rule that says the field cannot depend on the calibration, nor that it cannot grow without limit if that's how you choose to calibrate it. All that has to be satisfied in an empirical science is that once you choose your origin (i.e., local reference frame), and once you have a self-consistent procedure for obtaining correct results to all your measurements from that perspective, then all observers must get the results they predicted, even if those results depend on the procedure used.
In short, I feel we should never have assumed the field must be unique, as that assumption is more than we get to assume when using empirical science. I agree with Newton that the physical outcome should always trump the formal mathematical issues, but I would add that a physical outcome is a description by an observer using a given procedure, and is not in and of itself something that needs to be unique. This is very much the perspective of relativity, so I feel that relativity has already solved the issue even without replacing Newton's gravity with Einstein's, which is reasonable because the solution can hold even at times when the speeds are much less than the speed of light. Hence I'm saying not only that I agree the solution is allowed to depend on implicit boundary conditions, but also that different boundary conditions are allowed within the same physical problem, if they dovetail with different procedures by different observers. Relativity basically says that it is only necessary that the observers be right, not that they agree!
  • #62
NFuller said:
If we consider a uniform charge density ρρ\rho extending through all space
Other people have basically mentioned this, but the divergence theorem (and Stokes' theorem in general) only holds when ##V## is a compact subset of ##\mathbb{R}^n##. ##\mathbb{R}^n## itself is not compact. Thus you aren't guaranteed that
$$\int_{\mathbb{R}^n} \nabla\cdot{\bf F}dV=\int_{\partial \mathbb{R}^n} {\bf F}\cdot {\bf dA}$$
So you can't make the claim that ##\nabla\cdot\bf E=\rho/\varepsilon_0##. I'm not even clear if it's possible to formulate the meaning of ##\partial \mathbb{R}^n## in a coherent way.
  • #63
Ken G said:
So I think the physical problem here is in the implicit assumption that the field must be unique ...
... and is not in and of itself something that needs to be unique. This is very much the perspective of relativity, so I feel that relativity has already solved the issue
Field equations for the electric field do have unique solutions if boundary conditions are included.
Changing the boundary or boundary condition usually changes the physical problem.
  • #64
Which is my point-- it is appropriate to change the physical problem when one changes the observer's perspective/procedure. So it's not a mathematics problem, or a symmetry problem. It's a physics problem, so requires a physics solution, by which I mean, a solution that merely connects the observer to their own predictions, with no need to use an absolute language about what is happening.
  • #65
Ok, sorry, then somehow I got you wrong
  • #66
There could be an important difference between Newton's gravity and Coulomb's electric force, in that all matter has the same gravitational charge-to-mass ratio, whereas we can build instruments with various different charge-to-mass ratios. Hence, one does not say that the Coulomb force admits to an equivalence principle. Still, that issue doesn't seem to be the crux of the problem with using Gauss' law in the gravitational context, so it seems a similar solution as relativity finds in the gravitational case should be possible in the Coulomb case, even in the limit of taking c to infinity so no new theory would be needed. We would only need to relax the requirement that physics regard itself as enabled to make absolute statements like "what is the actual field here."
ETA: Let me express this point in terms of a trivial but interesting theorem that applies to any sphere of constant charge density. Let the origin be at the center, and then the usual electric field is equal to -x, where x is the displacement vector from the origin (and the charge density is suitably scaled). Similarly, the field at y is -y. But now let us regard y as a new origin for our coordinates, such that the coordinates at x become x-y. If an observer at y simply adds y to every field we calculated before, then the field at x is -x+y, which again obeys the same rule-- it is negative the displacement from the new origin! What this means is, if we have a spherical homogeneous charge distribution, we can regard any point within it as the origin where the field is zero, and use Gauss' law around that point, ignoring all charges outside the Gaussian sphere, as long as we are willing to have a field that differs from the original by a fixed vector y. All we then need is a way to regard that fixed field difference as an ignorable difference (stemming from the different perspectives of the observers), and we allow all observers to correctly infer what they will observe, without any need for a concept of an "absolute field," or any machinery other than the integral form of Gauss' law.
Notice this is the 3D homogeneous analog to the points made above in 1D involving an arbitrary constant of integration, but my point is that this constant of integration is not a different boundary condition in the sense of a different physical situation, it is a different constraint reflecting a different point of reference within the same physical situation. Hence we should not say the nonuniqueness of the field stems from insufficiently describing the physical situation, we should say it is nonunique because we have insufficiently described the point of reference of the observer, and what aspects of that observer's reality that we are allowed to regard as ignorable differences between observers. That solves Newton's problem and gives rise to the equivalence principle, but for electric forces, the problem seems perhaps trickier because an equivalence principle may not exist. (Yet people do seek ways to unify gravity with electric forces, so perhaps it is indeed a similar situation)
  • #67
Orodruin said:
I said that you have to put boundary conditions that are compatible with the differential equation.
This is what is not making sense to me. Generally speaking, you can set the boundary condition to whatever you want: a constant, a sine function, a spherical harmonic, etc. I don't need to pick a boundary condition that makes a particular solution work. I can pick anything, and the solution must conform to that boundary condition.
Orodruin said:
That is not how infinity works. Look at the (spatially) one-dimensional case E′=κE′=κE' = \kappa, where you obtain E=κx+AE=κx+AE = \kappa x + A. A behaviour at infinity that fixes AAA will be of the type limx→∞[E(x)+E(−x)]=E0limx→∞[E(x)+E(−x)]=E0\lim_{x\to \infty} [E(x) + E(-x)] = E_0 and set A=E0/2A=E0/2A = E_0/2 and therefore single out x=−E0/2κx=−E0/2κx = - E_0/2\kappa as the point with E=0E=0E = 0. Your constructions in the three-dimensional case will look similar and instead of the sum of two points involve integrals over the spherical harmonics.
Again, it is not clear how the origin is set here. Am I at the origin, or is two meters to my right the origin? I see that you have found where ##E=0## with respect to the origin, but you have not defined where that origin actually is.
  • #68
I've read about this before but did not really understand it. Could you explain more about what a compact subset is? I'm not very familiar with this terminology.
  • #69
A compact subset in ##\mathbb{R}^n## is a closed and limited subset, meaning it has a boundary and is 'finite' in the sense that it does not stretch out to infinity. There is a more general topological definition, but that's not the matter here.
The divergence theorem holds in general only for compactly supported ##\nabla \cdot \mathbf{F}## or equivalently only on compact subsets of manifolds, because this (plus continuity) ensures existence of the integral. ##\mathbb{R}^n## does not have a natural boundary a priori.(and of course it is not compact, because it stretches out to infinity).
  • #70
Metmann said:
That's indeed true. I am curious: Does this 'derivation' break down somewhere during the transition from the local statement (localized point charge) to the global statement (uncountably infinite number of point charges spread to infinity)?
The 1/r^2 Green's function pre-assumes that the field of the point charge vanishes at infinity. The integrals you will obtain from this will clearly not be convergent (working in the potential now, which is usually much more convenient than working with the fields). This is just the point you noticed about the total potential energy.
This is not generally true. Take f’(x) = 1/x. Having a boundary condition f(0) = 1 is clearly incompatible with this differential equation. Just an example.
The origin is arbitrary. The natural choice would be the point where E=0. If not you will end up with a different boundary condition. The boundary condition is not invariant under translations.
As already stated, this is not what is done when going from the integral form of Gauss’s law to the differential form. You only need the divergence theorem for compact volumes to do that.
  • #71
I'm not sure I understand. I thought this was the divergence theorem for compact volumes.
  • #72
But then my statement was right. Gauß's law in differential form is not valid for an infinitely stretched constant charge density.
But you can perform this transition only when the integrals are well-defined. For the infinitely stretched constant charge density this is not the case. Resp. in other words: In my opinion you can use Gauß's differential form only in those cases, where the integral formulation is also well-defined. The differential formulation is a local formulation which holds within certain domains only, not globally! It holds, where the integral formulation is defined.
  • #73
TeethWhitener said:
I'm not sure I understand. I thought this was the divergence theorem form compact volumes.
The argument roughly goes as follows: Assume that Gauss's law holds for any compact volume ##V##, i.e.,
\frac{Q}{\epsilon_0} = \frac{1}{\epsilon_0} \int_V \rho\, dV = \oint_S \vec E \cdot d\vec S = \int_V \nabla \cdot \vec E dV
where we have only applied the divergence theorem for a compact volume ##V##. Now, take a series of smaller and smaller compact volumes ##V_i## containing the point ##\vec x_0##, spheres centred at ##\vec x_0## with decreasing radii will do. Essentially by the multi-dimensional equivalent of the mean value theorem for integrals, you find that
\rho(\vec x_i) V_i/\epsilon_0 = (\nabla \cdot \vec E)|_{\vec x = \vec x'_i} V_i
for some points ##\vec x_i## and ##\vec x'_i## in ##V_i##. Cancelling the volumes on both sides and noting that both ##\vec x_i## and ##\vec x'_i## must approach ##\vec x## as ##i## increases gives you ##\rho(\vec x_0)/\epsilon_0 = (\nabla \cdot \vec E)|_{\vec x = \vec x_0}##. Nowhere is the divergence theorem for the entire space necessary.
Edit: Addition. In essence, the differential version of Gauss's law essentially follows from the infinitesimal version of the divergence theorem, not the extended one.
  • #74
As stated above, the differential formulation holds only locally! It is valid within domains given by the integral formulation, in general not outside of them!
What's the infinitesimal version of the divergence theorem? Divergence theorem = Stoke's Theorem = Integrals, at least to my knowledge. Maybe I am missing something.
  • #75
I was saying that the divergence theorem doesn't apply over the whole space. Are you saying it can be done?
  • #76
I do not see where you think that I have claimed anything else. Nowhere have I used the global properties. The point ##\vec x_0## in #73 is arbitrary.
  • #77
Yet we should not lose sight of the fact that Gauss' law in an infinite homogeneous charge distribution with fixed charge-to-mass ratio allows you to pick any origin you like, and correctly deduce the differential equation for the time dependence of the vector displacement r between any two points, which will be d2r/dt2 = 4*pi*rho*r/3 for unit charge-to-mass ratio and charge density rho. That is true if you keep all speeds much less than c, and assume an arbitrarily large charge distribution-- it need not be infinite, merely so large that any boundaries are far away compared to the r values of interest. So it would seem that the concern about the mathematics of infinity cannot be part of the physics problem-- physics problems should give reasonable results even when we are agnostic about the possibility of an infinite distribution of charge. So Gauss' law is doing something right, even if the observer cannot know where the "true center" of the charge distribution is, or even if there is any meaning to such a true center (as there isn't when dealing with gravity in a homogeneous universe).
The physics question that I see as remaining unsolved is what will happen to clumps whose charge-to-mass ratio deviates from unity in a truly infinite charge distribution. These clumps (or test charges) could be used to determine the "true field" in a way not possible with gravity, and perhaps one would need to know the boundary conditions to understand what happens to such clumps. One could then say that simply saying you have an infinite homogeneous charge distribution leaves something unspecified, but in a way that only appears if you allow test charges to deviate from the prevailing charge-to-mass ratio. It thus seems that unlike with gravity, here Gauss' law is only sufficient to give r(t) in the homogeneous dynamics, but further information is needed to know what instruments that are equipped with test charges of large charge-to-mass ratio will detect for the "actual field."
  • #78
By this I mean what follows when you take region around a given point and let its volume approach zero and how this relates to the surface integral. In essence, for a small enough volume ##V##
\oint_S \vec F \cdot d\vec S = (\nabla \cdot \vec F) V,
where ##S## is the bounding surface of ##V##.
  • #79
Orodruin said:
I do not see where you think that I have claimed anything else. Nowhere have I used the global properties. The point ⃗x0\vec x_0 in #73 is arbitrary.
Ah yes, I get your point, sorry, I messed something up. I've got to sort myself.
Ok, didn't know it under this name.
  • #80
NFuller said:
So, this has been bothering me for a few days and I'm having trouble understanding where the fault is. If we consider a uniform charge density ##\rho## extending through all space, then by symmetry, I would argue that ##\mathbf{E}=0## in all space. However, this does not agree with what a naive application of Gauss's Law would predict since ##\nabla\cdot\mathbf{E}=0\ne\rho/\epsilon##. So where exactly is the argument breaking down? Is there something unusual about describing a vanishing divergence over infinite space?
MMMM, I see your quandary? Perhaps it's the lens from which you are seeing, don't forget you are in the here and now looking back in retrospect? Or perhaps you are not allowing yourself to see it through the lens of Gauss? Perhaps he was the seed, why else would you be asking the question?
  • #81
Orodruin said:
Assume that Gauss's law holds for any compact volume VVV,
Isn't the validity of this assumption part of the argument though? I will admit that I am not familiar with some of the mathematical terms you and others are discussing so forgive me if I'm overlooking the obvious.
Is the field not unique then?
Well, if my initial assumption was wrong, I guess it's comforting that I did no worse than Newton.:smile:
  • #82
The question that post answered was ”can you go from Gauss’s law on integral form to the differential form only from its validity for compact volumes?”
Given an origin and a corresponding boundary behaviour the field is unique. However, if you change the origin you will not have the same boundary behaviour. This is why the boundary behaviour breaks translational invariance.
Anyone who has an advanced physics education and says this problem has never puzzled or bothered them is lying or did not think about it enough. :rolleyes:
  • #83
Even for ##\rho=0##, the equation ##\nabla {\bf E}=0## has an infinite number of nontrivial solutions
$${\bf E}=E_x{\bf e}_x+E_y{\bf e}_y+E_z{\bf e}_z$$
where ##E_x##, ##E_y## and ##E_z## are arbitrary constants.
  • #84
There are many more solutions than that even. As discussed in posts #35 to #38.
  • #85
So if you change the origin the boundary conditions change?
Working off of post #58, let's say that the boundary condition is ##\lim_{x\rightarrow\infty}[\mathbf{E}(\mathbf{x})+\mathbf{E}(-\mathbf{x})]=E_{0}\hat{r}##. Then ##\mathbf{E}=\rho\mathbf{x}/\epsilon_{0}+E_{0}/2\hat{x}##. The thing I still don't get is where is ##\mathbf{x}=0##? Metaphorically speaking, if I had a meter that measured the electric field, and I was somewhere in this space, what would the meter read?
  • #86
Yes. This would be the very essence of the boundary conditions not being translationally invariant.
This is not the appropriate generalisation of the boundary condition (the correct generalisation would involve integrals of spherical harmonics). Your origin does not have to be anywhere in particular. You are free to pick whatever point you want as the origin and whatever compatible boundary conditions that you prefer. However, there are going to be different choices where only some correspond to the same physical situation.
Regardless, the question in itself is rather unphysical and you will not find a physical situation where it can be applied - even as an approximation.
  • #87
Forgive me for not having read the past 5 pages of debate, but I have a few thoughts.
First, we can stop arguing about whether this is a problem of the differential form of Gauss's law. The derivation of the differential form from the integral form uses the divergence theorem which holds in this case. In fact you can show that the "charge" has to be 0 everywhere from the integral form alone. Take a cube Gaussian pillbox with two faces perpendicular to our constant E, then Gauss's law in integral form says that ## E \cdot A - E \cdot A = Q_\text{in_cube} = 0 ##, the cube was arbitrary so the charge is zero everywhere.
Anyway, it seems to me that the issue we are having is "how is there a nonzero electric field when there is no charge?" I don't see a problem. You picked an aphysical field and got an aphysical result. The next question is "then why do our toy models of infinite plates and line charges with finite charge density not give aphysical results?" The answer is that they are completely aphysical but model certain situations that can actually occur (i.e. are the limit of other situations), such as the electric field along the axis of a large charged circular laminar surface. On the other hand, the situation in question of a uniform electric field throughout space does not model any realistic scenario.
  • #88
I agree, I was totally wrong.
E doesn't have to be constant.I think, we should discard every solution that leads to infinite (total) field energy and which breaks the symmetry of the problem (yes, spontaneous symmetry [here I just mean: solution doesn't share the symmetry of the problem] breaking is a well-known concept, but maybe if possible we should try without in classical physics). With symmetry I mean here: Isotropy around every point. If we assume these two conditions, the only solution in both cases (##\rho=0## and ##\rho=\text{const}##) is ##\vec{E}=0##, and hence automatically ##\rho=0##.
What do you think about this?
  • #89
Metmann said:
I think, we should discard every solution that leads to infinite field energy and which breaks the symmetry of the problem (yes, spontaneous symmetry breaking is a well-known concept, but maybe if possible we should try without in classical physics). If we assume these two conditions, the only solution in both cases (##\rho=0## and ##\rho=\text{const}##) is ##\vec{E}=0##.
##E=0## does not solve ##\nabla E = \rho = \text{const} \neq 0##
The symmetry of the problem is not completely specified w/o boundary condition. Given ##\rho = \text{const} \neq 0## there are two choices:
1) a boundary condition compatible with ##\rho = \text{const} \neq 0##; then the allowed solutions obey ##E \neq 0##
2) a boundary condition compatible with ##E = \text{const} = 0## following your idea; but then ##\nabla E = 0 \neq \rho ##, so there is no solution
  • #90
tom.stoer said:
=0E=0 does not solve ∇E=ρ=const≠0
No, but it would show, that the constant has to be zero, because else the both conditions would not be satisfied.
Well, the symmetry given by constant ##\rho##, is: isotropy and homogeneity or equivalently: isotropy around every point.
  • · Replies 29 ·
