Breaking Bad Pizza Throw Physics Calculation.
The discussion focuses on calculating the force required to throw a pizza onto a roof, as depicted in the famous scene from Breaking Bad. The pizza is estimated to weigh approximately 3 kg, with a landing height of 2.5 meters and a horizontal distance of 3 meters from the thrower. The maximum vertical height reached by the pizza is about 3 meters, and the total time of flight is estimated at 1.5 seconds. The average force exerted during the throw is suggested to be around 100 N at an angle of 75 degrees above the horizontal, with the calculation based on the release velocity and the thrower's hand height.
  • Basic understanding of projectile motion principles
  • Familiarity with force calculations in physics
  • Knowledge of angles and trigonometry
  • Ability to interpret physics equations related to motion
  • Research projectile motion equations, specifically for calculating launch angles and forces
  • Learn about the physics of force and motion, focusing on Newton's laws
  • Explore the concept of release velocity in projectile dynamics
  • Investigate the impact of height and distance on projectile trajectories
This discussion is beneficial for graphic designers working on science-themed projects, physics enthusiasts, and educators looking to incorporate real-world examples of physics into their teaching materials.
bala_phy
Disclaimers: I am a graphic designer working with science popularisers to make interesting posters/designs based on science. Apart from High School physics (which was more than 10 years ago) I do not have a physics background so part 2 and 3 (equations and attempt at a solution) might be blank. Please bear with me.
We are making a poster about the famous Pizza throw in Breaking Bad season 1.
Remembering what little I could about projectiles, this is the tentative design proposal I came up with.
But I thought it would be great if I could actually calculate the force required to throw a party pizza onto the roof and include that in the graphic somehow.
From what I can tell the pizza might be approx 3kg (it is huge)
Height at which pizza lands from the ground is approx 2.5 meters.
Horizontal distance between Walter and the Pizza landing spot is approx 3 meters
Maximum vertical height of pizza is say 3 meters.
Total time taken from launch to landing is say 1.5 seconds.
I am guessing these are all the relevant variables needed.
Thanks a lot in advance for any help. It would be much appreciated.
Nice poster, good luck with it! The force required to throw the pizza all exists during the motion of the throwers hand and arm from its low start position to the release point of the pizza , say about a meter and a half. The average force during that distance can be calculated when you know the release velocity , and the force will be directed along the release angle, theta, tangent to the initial path of the curve. You should show it that way. I think when you gave distance above ground you meant distance above the hand at release, since the thrower,s hand could be in itself 2 meters above ground. I am not sure why you want to assign a value to it instead of just labeling it as F, but it might be on the order of 100 N directed at about theta = 75 degrees above the horizontal, based on your numbers.
  • · Replies 25 ·
  • · Replies 446 ·
34K
  • · Replies 27 ·
  • · Replies 18 ·
