Brine-ish Question with Linear Equations
The problem involves a tank containing 400 liters of water with a certain amount of chlorine (Cl). Fresh water is being pumped in at a rate of 4 liters per second while water is being drained at a rate of 10 liters per second. The objective is to determine the amount of Cl in the tank as a function of time.
  • Participants discuss the setup of the problem, particularly the rates of water flow in and out of the tank. There is confusion regarding the rate of Cl entering the tank, with some questioning whether it should be considered zero. Others explore the implications of this on the differential equation governing the system.
Some participants have provided insights into the formulation of the differential equation, suggesting that while the rate in is zero, the rate out must be accounted for. There is acknowledgment of the equation being separable, and participants are exploring the implications of the differing rates of flow.
Participants express uncertainty about the clarity of the problem and the responses received, indicating a desire for further guidance or clarification on specific points of confusion.
justine411
we have a tank with 400L of water with Cl, 0.02kg of Cl. Fresh water is pumped in at 4L/s and out at 10L/s. Find the amount of Cl in the tank as a function of t.
Use of differential equations
I set up V(t)=400-6t in Liters and seconds. then I want
dy/dx=(rate in)-(rate out) for Cl flowing. But no Cl is coming in correct? So rate in ends up being zero, which confuses me because then everything ends up equalling zero from what I've done.
If you want to see more of what I've done, please post. Am I wrong to say rate in is 0?
rate in= (4L/s)(0g/L)=0
rate out=(10L/s)(y(t)/(1000-6L))
then dy/dt-(10y)/(1000-6t)=0
I(t)=(1000-6t)^-10/6 (took a few steps to find, but I think it's right).
sorry...it seems like a lot of people have looked at my problem...what is unclear about it? Why can't anyone help? Is there something I could do?
I end up with integral ((400-6t)(y))prime=integral 0dt, and that can't be right.
PLEASE I AM DYING TO KNOW WHAT I'M DOING WRONG!
Why would "everything end up being 0"? Yes, there is no Cl flowing in, but there certainly is Cl flowing out. Let X(t) be the amount of Cl in the tank at time t seconds. The volume of water at that time is, as you say, 400-6t so the concentration of Cl is X/(400-6t) kg/liter. Since the water is flowing out at 10 l/min, Cl is flowing out at 10X/(400-6t) kg/min.
dX/dt= -10X/(400-6t). Looks like a simple separable equation to me.
By the way, don't get upset if no one responds within a few minutes- some of us have lives to live!
Thanks! I wondered if it was a separable equation, but because the rate in is different from the rate out, isn't it linear, but not separable? That was sort of also holding me back...
Actually, it is both linear and separable.
