Buffer solution preparation
  • Thread starter Thread starter Nanu Nana
    Buffer Preparation
The discussion revolves around the preparation of a buffer solution with a target pH of 4.00 using acetic acid and sodium acetate. Participants explore the calculations involved in determining the required volumes and amounts of each component based on given concentrations and pKa values.
  • Homework-related
  • One participant outlines the calculations for preparing the buffer solution, including the use of the Henderson-Hasselbalch equation and the relationship between the concentrations of acetic acid and its conjugate base.
  • Another participant points out an inconsistency in the calculations regarding the moles of acetic acid, noting that 0.008519 moles does not equal 0.01 moles.
  • There is a reference to a previous example provided by a teacher, which involves a different buffer system (NaHCO3 and NaOH), prompting questions about the methodology used in that case.
  • Participants discuss the differences between mixing a weak acid with its conjugate base versus mixing an acid with a strong base, highlighting the source of the conjugate bases in each scenario.
  • Clarifications are sought regarding the definitions of conjugate acids and bases in the context of the buffer solutions being discussed.
Participants express disagreement regarding the correct interpretation of the required moles of acetic acid. While some acknowledge the calculations are on the right track, there is no consensus on the correct values or methodology, particularly in relation to the teacher's example.
Participants note potential misunderstandings regarding buffer preparation and the definitions of components involved, which may affect their calculations and conclusions.
Nanu Nana
So I have prepare a buffer solution of 100 mL with ph of 4.00 .I have to use acetic acid and NaAc (sodium acetate ) to do so . The sum of the concentration of weak acid and its conjugate base is equal to 0.10 M
ca + cb = 0.10 M
How much volume of acetic acid and NaAc should I use to make buffersolution with ph of 4.00
Pka of acetic acid is = 4.76
Also information given :
NaAc (molar weight = 82.08g/mol ) and 100 % m
HAc (mw= 60.05) (density = 1.05 ) (100 % m)
[/b]
ph = pka - log (HAc/Ac-)
[/b]
I tried solving it but I'm not sure if its correct
4.00 =4.76 - log(HAc)/Ac-)
4.00-4.76 = - log ( Hac/ Ac-)
[HAc]/ [Ac-] = 10^0.76 = 5.754
we know ca +cb = 0.10 M x 0.1 L = 0.01 mol
nAc- + 5.754 x n Ac- = 0.01 mol
6.754 nAc- = 0.01 mol
so nAc- = 0.01/ 6.754 = 0.00148 mol nAc-
HAc = 0.01 - 0.00148 =0.008519 mol HAc
SO we have to use 0.01 mol of HAc and 0.001480 mol of NaAc
HAc
c=(100% x 10 x1.05 g/ml)/ 60.05 g/mol = 17.458 M
c= n/v
17.458 M= 0.01 mol/ V
V= 5.71 x10^-4 L => 0.57 ml We going to add 0.57 ml of HAc
and for NaAc = 0.001480 mol x Mw ( 82.08) = 0.121520 g NaAc
Is this correct ??Please explain if its not ??
0.008519 is not 0.01.
But in general you are one the right track (and the mass of sodium acetate looks OK to me).
But my teacher used 0.01 mol for HAc last year . Thats why i 'm confused
He used the total mol
Not sure what you mean.
You have correctly calculated you need 0.008519 moles of the acid, but in the next line 0.008519 miraculously became 0.01 moles. Why?
The following buffer problem is solved by my teacher .
300 ml ph =9.90 c= ca+cb
We're going to use NaHCO3 and NaOH
ph = 9.90 = pka - log nHCO3-/ n CO32-
pka = 10.30
nHCo3-/ n co32- = 2.51
n HCO3- +n co32- = 0.500 x 300 ml = 150 mmol
2.51 n co32- + n co32- = 150
nco32- = 150/ 3.51 =42.7 mmol
How much NahCo and NAoh do we have to use to make that buffer solution
His answer was 150 mmol NaHCO3 and 42.7 mmol NaOH
Our teacher wrote this answer . Why did he use total mol ( 150 mmol) for NaHCO3 why not 150-42.7 mmol ??
These are different cases. In one you mix a conjugate acid and conjugate base, in the other you mix an acid with a base to neutralize it - and produce the conjugate base.
I guess your mistake is based on a common misunderstanding of the buffers. Can you tell what are the conjugate acid and base in each case?
Ac- is conjugate base and HAc weak acid
on second one
HC03- = acid
c032- = conjugate base
OK.
Where does the CO32- (base) come from?
Where does the Ac- (base) come from?
Do you see why these are different problems?
Yes Ac- came from Sodium acetate but on second case we added strong base NaoH . Naoh completely deprotonate weak acids .
So is it clear now why these questions are solved a bit differently, and why your solution is incorrect?
Yeah thank you very much
  • · Replies 23 ·
13K
