Build a Coin-Throwing Catapult in 2 Weeks
  • Thread starter Thread starter mcoy
    Catapult
The discussion revolves around designing a catapult capable of launching a 5 cent coin exactly 2 meters. Participants are exploring various design options, including counter-weight systems and elastic mechanisms, while emphasizing the need for calculations to inform their construction.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Some participants discuss the importance of counterweight size, arm weight, and moment arms in determining the catapult's effectiveness. Others suggest using energy approaches to calculate launch parameters, such as the angle and height needed for the coin to reach the target distance. There are inquiries about measuring energy stored in elastic bands and how to calibrate the initial velocity of the catapult arm.
The discussion is active, with participants sharing insights and personal experiences related to catapult design. Some have provided formulas and rough approximations for calculating range, while others are seeking further clarification on specific measurements and calculations needed for their projects. There is no explicit consensus, but various lines of reasoning are being explored.
Participants are working under constraints such as time limits for construction and specific rules regarding energy sources for launching projectiles. There are also mentions of homework guidelines that restrict certain methods of energy application.
mcoy
I need to make a catapult in less than 2 weeks... it has to be able to throw a 5 cent coin (aust coin) on exactly 2 metres... its not much but i can't figure out what design I'm going to make, since i need to be able to do calculations beforehand and make the catapult using my calcs...
so now i need a good and easy-to-make design... i.e. making a catapult that doesn't need any gears... i was thinking of a counter-weight type but that would be too much for a 5 cent coin... i think...
somebody help me please??
Doesn't that rather depend on the size of the counterweight, the weight of the arm, and the moment arms involved?
Calculations will only give you an approximate result. I would suggest that you use an energy approach.
You have to determine the angle at which the coin leaves the catapult. Then determine how high the coin has to go. Calculate the change in energy of the catapult arm and counterweight between initial and final positions. Assume the energy loss of the arm is gained by the coin.
If you use a spring or elastic band, you have to measure the spring constant and measure the load distance to find the energy stored in the spring. You also have to take into account the kinetic energy of the arm after the coin is released.
AM
Once I was really into building catapults with counter-weights. they are called trebuchets. you can see a movie of one of the big ones (6-feet+) fireing at my site. I also made small ones out of lego and cardboard that shot for small distances (though if you plan it right I know from experience that you can make a 1-foot trebuchet that can shatter a marble on a wall from over 10-feet) a rough approximation for the distace that a trebuchet can shoot is:
Range = 2 * h * (M_{cw}/m_{p}) were h is the distance that the CW falls. You can start with that and then make small changes until it works just right. You can learn a lot about building them on the web.
yeah but firing a coin doesn't need a trebuchet setup... I've done some calculations, but i just need the design, and to callibrate it... i don't have any idea how create and calibrate the initial velocity of the arm (the throwing bit) of the catapult...
Pls help me Calculation on distance
I'm doing a Assignment is to conststruce a captapult that will launch a marshmallow(Large size) at target on the floor at the other end of the classroom.
I designed catapult. the rules saing the energy;; to launch the marshmallow cannot come directly from the motion of a human being.so i used elastic band .
but, they saing to calculate the distance.
so, i use an energy approach. so I determine the angle at which the mashmallow leaves the catapult.then I assume then energy loss of the arm is gained by the marshmallow.but I ued elastic band, but, i don't know how to measure the load distance to find the energy stored in the elaastic band.how to i take into this measure ments...coz, I don't know the formula of the elasticband energy stored.
just i used this formula to find the velocity.
Mgh = 1/2*M*V^2
but I don't consider the elastice band energy :frown:
please anyone could me help to solve this probelm
I need the full foumula how to fine the calculation...
pls sent me to desitamil@gmail.com
Thanks for look through my post.
  • · Replies 21 ·
10K
35K
13K
  • · Replies 73 ·
11K
