Do I need a ground connection in a tank circuit?
10 replies · 8K views
Idea04
I'm building a tank circuit and I need to know if a ground connection is needed.
You need to give us more details.
There are many different types of tank circuits.
The tank circuit is a L/C parallel filter.
From what I was reading is that the tank circuit creates a high impedance towards frequencies outside the resonace frequency of the circuit. So wouldn't the circuit cause frequencies outside the resonant frequency to die out rapidly. So would there need to be a ground connection or would the high impedance in the circuit have no need for a ground connection.
Any response for the question.
Thank you for the information, but this circuit is only a capacitor and inductor in a parallel circuit, with an input and output. But I'm not sure if i need a ground connection for the circuit to operate properly. Am i right to think that the high impediance in the circuit toward frequencies outside the resonant frequency of the circuit will cause those frequencies to die out rapidly and not affect the output signal. or does the circuit need a ground terminal to direct unwanted frequencies out of the circuit.
You need to draw a schematic and post it. A parallel L/C circuit appears as a low impedance anywhere except at resonance. So, it depends on how the tank circuit is arranged relative to the rest of the circuits.
3 elements in a network allows you to tune it and impedance match it to the load.
I can't get the picture to post on the site. but I can tell you that there are no other circuits arranged with this circuit. All it is, is a capacitor and inductor in parallel to one another with an input and output. I don't know if that answers your question.
It is exactly what you said it is: A tank circuit. Until you hook it to something else, it behaves exactly how I described in my previous post. Where does this 'input' come from and where does the 'output' go to?
