Bullet Enters/Exits Mass, Mass Slides
  • Thread starter Thread starter myxomatosii
    Bullet Mass
The discussion focuses on a ballistics problem involving a 25 g bullet traveling at 1200 m/s that penetrates a 35 cm thick target weighing 350 kg and exits at 850 m/s. Key equations include the conservation of momentum and kinematic equations to determine the bullet's time in the target and the average force exerted on the target. Participants emphasize the need for clarity in the equations provided by the professor, as well as the challenge of calculating the time of impact accurately. The average force can be calculated using the change in momentum divided by the time of impact.
  • Understanding of momentum conservation principles
  • Familiarity with kinematic equations
  • Basic knowledge of impulse and average force calculations
  • Ability to manipulate and solve algebraic equations
  • Study the conservation of momentum in collision problems
  • Learn how to apply kinematic equations to find time of impact
  • Explore impulse-momentum theorem for average force calculations
  • Review examples of ballistics problems for practical application
Students studying physics, particularly those focusing on mechanics and ballistics, as well as educators seeking to clarify complex problem-solving techniques in these areas.
myxomatosii
In a ballistics test, a 25 g bullet traveling horizontally at 1200 m/s goes through a 35 cm thick 350 kg stationary target and emerges with a speed of 850 m/s. The target is free to slide on a smooth horizontal surface.
(a) How long is the bullet in the target?
(b)What average force does it exert on the target?
(c) What is the target's speed just after the bullet emerges?
It would be nice to have some more equations, my professor gave the class four pages of equations scribbled in his horrible hand-writing, to help us... I guess. Instead of giving us the basic equations that we can use to plug-in to create our own equations he already solved them all out into the forms he understands, which means we have to un-solve them to try to make sense of them, so really I have no idea what other equations to put here since he has no clear division between which equations go with which section of the book.
momentum of system before = momentum of system after ||| Pi=Pf
I already solved part C using the equation provided.
Part A I attempted something that I knew wouldn't work but gave it a try anyway and I know I need part A to solve B so I haven't gotten around to trying to solve B yet.
I seem not to be able to resist applying simple mechanics to complex problems just to see if I can knock it out of the way. Anyway I did this to solve for B, it was obviously going to be wrong but I submitted it anyway.
B: I tried to say that the
DT=0.35m
Vavg/DT=? Then that gave me seconds so I took s-1. Yea, it obviously was just bs, but that is how lost I am.
LowlyPion said:
Here are some kinematic equations anyway.
https://www.physicsforums.com/showpost.php?p=905663&postcount=2
As for determining the force, recognize that Δ in momentum divided by the Δt should give you your average force.
Thanks, getting to work on things now. Hopefully I can make some progress without having to ask too much here.
My problem is finding the time, the Δp (momentum) is a joke to find.
0.001seconds doesn't seem like a bad impulse time, considering the average of the problems I've been working with is 0.005 seconds, but it won't accept it, I'm not sure what else to do even since I've posted this because no one mentioned time.
I'm given it decelerates from 1200m/s to 850m/s in the distance of 0.35m.
Finding the time should be cut and dry like I found it, but its not, so I'm confused.
Tried.
a) Use the equation Δx=1/2(Vo+V)t, so t=(2Δx)/(Vo+V)
From.
http://qaboard.cramster.com/physics-topic-5-218055-cpi0.aspx
Got 0.0003seconds, didn't accept it.
Also read all of
https://www.physicsforums.com/showthread.php?t=200285
He seems to think the part I think is hard is elementary =(
So I learned nothing from that as well.
I recalculated the time he declared to be right using the formula I tried using on mine(the same one I tried right above this in this very post), it gave his same answer. Meaning I am calculating time right, assuming he was, and he did get the right answer. Anyway, I am getting really annoyed with my "online" system when I am almost positive my answer is correct.. am I wrong?
Start with determining the deceleration through the material.
That you can get from Vf2 = Vi2 - 2*a*x
In your case that would be 12002 - 8502 = 2*.35*a
Now armed with a you can determine t, from x = 1/2*a*t2
That arrives at a number a bit larger than .0003 sec.
  • · Replies 26 ·
  • · Replies 21 ·
